Is Smoking Permitted? - Page 250 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Is Smoking Permitted?
Old Streetfighter Motorcycle Forum Post 12-23-2018, 02:55 PM   #2491
Smoker
BLACK BELT
Local Time: 07:22 AM
Flip Offs: 35
Default Re: Is Smoking Permitted?
Originally Posted by rex_saugerty View Post
Well mine is 80cc same engine base as JDM nsr80, would like to have some power for city fun
You're not going to get it from a boost bottle.
Bore & stroke, porting & headwork, larger carbs, custom pipes.
Smoker is online now   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Smoker!
Old Streetfighter Motorcycle Forum Post 12-23-2018, 02:59 PM   #2492
rex_saugerty
V four honda whore
Local Time: 05:22 PM
Flip Offs: 3
It will get new piston, porting, pipe, different carb, maybe new CDI. Not sure about bottle, just researching around
This user High Fived rex_saugerty!
Old Streetfighter Motorcycle Forum Post 12-23-2018, 05:57 PM   #2493
shinyribs
Local Time: 10:22 AM
Flip Offs: 58
This is a real deal dyno print out of a Banshee engine with & without a boost bottle:
IMO I don't think Yamaha would have bothered with the R&D, manufacture & installation of boost bottles if it didn't have benefits. I read that it improves low speed running by allowing mixture to enter a chamber until it's needed rather than passing back through the carb and picking up even more fuel on it's way back into the engine, causing a rich condition.
LMAO!! That fucking curly q at end hahaha
Old Streetfighter Motorcycle Forum Post 12-24-2018, 03:48 PM   #2494
TURNIP
CF Lover
TURNIP's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 1
Flipped Off 1 Time in 1 Post
TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!
Yeah I came back to say this exact thing buddy
Isaac Newton was a bastard when he invented gravity!
TURNIP is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-05-2019, 01:02 PM   #2495
Smoker
BLACK BELT
Flip Offs: 35
Trying to grab as many parts as I can for the engine rebuild.
Still not sure if the +7mm stroker plan will happen. Asking Ed Erlenbach and Tony Dukas for help with that. Can't start buying big parts until I get all the info.
In the mean time, I asked MBD about the straight cut water pump gear and drive gear set. Not available at this time. Don't really need it, but thought it would be a cool mod. Searching for another source.
Also want the shift star and detent arm (bearing) & spring mod. Trying to determine what brand/style is best.
Also need to look at uprated bearings, o-rings & seals. Not sure what's available. EE and Jeff H like and use ceramic bearings. Might be my last engine build, so maybe I'll use those where I can. No idea where to get them, yet. Pretty sure I've seen improved YPVS seals/o-rings. Just have to find them.
Then there's the dry clutch parts. No idea if this will work, or leak oil, or maybe destroy the new engine.
Been going through the dry clutch parts. Not sure exactly how it goes together, so been at it like a jigsaw puzzle. Have most of it figured out, using the RZ and Ducati schematics. The TINY o-ring seal looks very sketchy. Wondering if an uprated rubber or teflon seal could be found/used? I'll post some good pics of the dry clutch assembly.
Old Streetfighter Motorcycle Forum Post 01-10-2019, 01:18 PM   #2496
Smoker
BLACK BELT
Flip Offs: 35
Bad idea #2...can you just route the hose elsewhere?
Received more info on this suggestion.
Got helpful photos from a two-stroke super OG.
Photo shows how to run the hose between the carb boots, in FRONT of the upsized reed flanges. Good idea to make it work.
Unfortunately, it's not the clean, simple look I want for this engine. Also, I made a very cool rubber-mounted carburetor support which occupies the same space.
May not be using larger reedcages on this engine.
Old Streetfighter Motorcycle Forum Post 01-10-2019, 01:35 PM   #2497
RS_Raz
Dickhead
Senior Fighterer
Local Time: 03:22 PM
Flip Offs: 10
The V forces will flow enough and I think your bespoke reed spacers will be enough bling in that area.
This user High Fived RS_Raz!
Old Streetfighter Motorcycle Forum Post 01-10-2019, 07:32 PM   #2498
busa1300
CF Lover
busa1300's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 1
Flipped Off 5 Times in 3 Posts
busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!
Fighter of the Month Fighter of the Month Fighter of the Month
That engine looks packed pretty tight in that RS250 frame.
Space is at a premium for sure...
2019 winter build off bike RZV500R
https://www.customfighters.com/forum...d.php?t=136718
__________MY TWO STROKE ADDICTION_____________
RGV VJ21 L____________GT 750 J__sold _____
RGV VJ22 FL_________ GT 750 long term cafe project___
RGV VJ22 N ______________RS 250 Cup Bike_________
RGV VJ23 T__________And one for the water...SX-R 800_
RZ 350_______________The cherry popper...KD 80_____
___________________RZV500R____________________
busa1300 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-11-2019, 01:51 AM   #2499
Smoker
BLACK BELT
Flip Offs: 35
RZ engine fits the same in my Aprilia SXV, very tight.
Replacing a V twin engine with a parallel twin.
There's video of that bike on Isle of Man.
Old Streetfighter Motorcycle Forum Post 01-11-2019, 09:17 PM   #2500
Smoker
BLACK BELT
Flip Offs: 35
The deal is done.
Jeff Henise will be making pipes for this bike. Stainless or titanium.
I'll be making silencers.
We compromise on the design. I want more custom. He wants more speed.
Working well, so far.
Tags
ewoks stole my boxers
Thank you for viewing Is Smoking Permitted? in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Is Smoking Permitted? on Custom Fighters Streetfighter Motorcycle Forum
