Anyone know the stock spring rate for 2nd gen Bandit 1200 shocks? - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Brakes and Suspension
Brakes and Suspension Anything to do with fabricating and modifying brakes and suspension goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > Anyone know the stock spring rate for 2nd gen Bandit 1200 shocks?
Old Streetfighter Motorcycle Forum Post 10-22-2019, 07:11 PM   #1
makenzie71
Local Time: 03:03 PM
makenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to all
Default Anyone know the stock spring rate for 2nd gen Bandit 1200 shocks?
title says it
makenzie71 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 10-22-2019, 11:21 PM   #2
Default Re: Anyone know the stock spring rate for 2nd gen Bandit 1200 shocks?
I looked on Racetech and they had ZERO info, however, the later Gsxr1100W’s have 8.5kg/mm springs. The Bandit and the Gsxr have a very similar linkage setup so I would think that should at least get you in the ballpark.
‘74 Kawasaki H1-500 Project
‘76 Kawasaki Kz900 'Strip-fighter Project
‘78 Kawasaki Kz1000 Project
'80 Cx500 Cafe/Brat Project
‘83 Kawasaki Gpz750 (Turbo Converted) Project
Streetfighterkz is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 10-22-2019, 11:29 PM   #3
makenzie71
Issue I'm having is finding the right springrate for my Hyosung. No one knows the stock spring rate for the GT650R, but the Bandit 1200 shock has been touted as being a straight swap and upgrade. If the B12 and GSXR1100 have similar setups then that should put the Hyosung needing the 9kg area. I just dropped in a K5 GSXR1000 shock and if my reading is accurate it has an 8.1kg spring. Would 1kg/mm really make that big a difference? The K5 shock on the GTR is super soft.
Old Streetfighter Motorcycle Forum Post 10-23-2019, 12:03 AM   #4
1kg/mm = 56lb/in
Seems like a lot but really 3.5lbs to compress the spring 1/16”.
I looked at your thread but can’t remember; are you using the exact same geometry as the Hyosung with your swap?
Thank you for viewing Anyone know the stock spring rate for 2nd gen Bandit 1200 shocks? in the Brakes and Suspension section of our streetfighter motorcycle forum. I hope you found it useful!
Brakes and Suspension - Anyone know the stock spring rate for 2nd gen Bandit 1200 shocks? on Custom Fighters Streetfighter Motorcycle Forum
