software 2 - what do you want to see? - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Off Topic > Open Discussion
Open Discussion Anything non-motorcycle related goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > software 2 - what do you want to see?
Old Streetfighter Motorcycle Forum Post 03-05-2018, 10:15 PM   #1
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
sebwiers's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 03:07 PM
Flip Offs: 21
Flipped Off 36 Times in 19 Posts
sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!
Default software 2 - what do you want to see?
I'm working on some (free) software to calculate the changes to various dimensions (rake, trail, wheelbase, neck height, axle-crown length) that would result from fork length change, tree rake, neck chop / up / out, and wheel size changes. The software would then diagram either or both setups (overlayed) so you can get an vague idea of stance, etc. And yeah, its more aimed at chopper type mods... but also would work fine for fighters doing custom trees, wheel\ swaps, fork swaps, etc. Math is the same in both cases.
https://sebwiers.github.io/motorcycl...trail_001.html
I have a few questions about what people might want from such a package.
First, are the changes it calculates useful? In theory I think those are enough that you can set up a build jig, but I'm not sure just what values a jig uses. I'm also assuming that when people talk about a change to neck angle (such as +3 degrees) this is a chage to the frame itself, basically cutting the frame and inserting 3 degree wedge (which would also result in some small amount of up / out) and does not necessarily mean that the final stance has 3 degrees more rake. Is this a common understanding & use of the term?
Obviously I still have some work - it draws the bikes correctly, but they are figured out such that both effectively are treated as being in a stand with the rear axle locked in place (or equivalently, held by the engine / trans mount). This doesn't really show stance change and potentially makes calculating trail difficult, but made some of the math (much) easier and is, I assume, how modifications like up / out / neck angle change are described / measured, hence my questions above.
sebwiers is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived sebwiers!
Old Streetfighter Motorcycle Forum Post 03-06-2018, 08:24 AM   #2
SEBSPEED
V4's FTW
Local Time: 04:07 PM
Flip Offs: 53
Default Re: software 2 - what do you want to see?
Looks interesting. Most people only look at half the numbers when fork swapping they skip over the spring weight and how sag will affect height. So maybe add a disclaimer or note about that to indicate it's not included in the calc
Similar notes with shorter swingarm, monoshock, poss wheelbase change
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Old Streetfighter Motorcycle Forum Post 03-06-2018, 09:11 AM   #3
tldave
Flip Offs: 5
thats awesome.
I just slap some shit together and ride it. If it tries to kill me I adjust it.
Old Streetfighter Motorcycle Forum Post 03-06-2018, 11:55 AM   #4
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
Flip Offs: 21
Yeah, it absolutely doesn't take into account that the fork length can change when loaded with weight (or brake forces, etc). That's a different project I hope to tackle later on... right now I'm still struggling to calculate the basic shit like "are the wheels touching the ground"? But with the approach I'm taking, figuring out suspension dynamics should be fairly straight forward, because I'd already be set up to deal with changes in fork length.
Which reminds me, I wanted to include output regarding brake dive...
Old Streetfighter Motorcycle Forum Post 03-07-2018, 02:01 AM   #5
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
Flip Offs: 21
Well holy fuck. I figured out the trail / wheelbase issue, so now you see the neck rake line properly drawed for the custom setup, and get the figures listed. There's a couple numbers I still haven't worked out, but I know what I need to do to get them.
https://sebwiers.github.io/motorcycl...anner_002.html
Old Streetfighter Motorcycle Forum Post 06-11-2019, 01:24 PM   #6
rabies
time is running out......
CF Lover
rabies's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 1,393
Flipped Off 39 Times in 35 Posts
rabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to behold
curious to know at what angles is dangerous for stuff like forks.
at what point does it create headshake. speed wobble?
raising or lowering rear effects it?
rabies is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 06-11-2019, 05:10 PM   #7
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
Flip Offs: 21
Trail matters more than angles, I think. There's some builders who disagree, but here's where I got that idea from, and I've seen enough other weird bikes to believe it (both motorcycle and bicycle). There's some recent research on bicycle stability that shows all sorts of crazy setups can be stable - things like the COG of the steered system also matter.
I'm running my Hossack setup with 19 degrees rake and it seems good with just 65mm of trail. Even in theory that seems odd, but its quite stable as long as my tire pressure is good. Its possible I just actually have more trail than I think I do.
Headshake and speed wobble are IMO results of wheel disturbances and feedback loops of the same forces that cause stability. The wheel gets off center, is pulled back to center by stabilizing forces, swings past center due to momentum, and if it goes further than out that it started, the cycle will build and amplify.
Lifting the back end up decreases rake (and trail), all else staying same. You can actually test that on my chopper planner (but "up" on the planner means moving the aaxle up, so use a negative number to "raise the rear"). The link above was dead (now edited) so use https://sebwiers.github.io/motorcycl...anner_002.html
This user High Fived sebwiers!
Thank you for viewing software 2 - what do you want to see? in the Open Discussion section of our streetfighter motorcycle forum. I hope you found it useful!
Open Discussion - software 2 - what do you want to see? on Custom Fighters Streetfighter Motorcycle Forum
