Frame and arm jig build - Page 4 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Frame and arm jig build
Old Streetfighter Motorcycle Forum Post 09-22-2018, 12:49 AM   #31
mcantar
Fuck it, let's do it live
Local Time: 06:34 AM
Flip Offs: 46
Flipped Off 22 Times in 21 Posts
Fighter of the Year Fighter of the Month
Default Re: Frame and arm jig build
Double check the bolt holes.
I used to run a big plasma table, making bolt-ready holes was the "grail" thing that Hypertherm and whoever else were advertising that their newest shiniest stuff could mostly do. The beveled kerf that the plasma jet makes can cause some issues with fitment and longevity.
Not a huge deal, worst case scenario you just clean up the holes with a drill, but figured it might be worth mentioning so you don't get caught off guard.
Turbo Busa v2 2017 Buildoff.
Turbo Busa v1.1
Old Streetfighter Motorcycle Forum Post 09-22-2018, 11:16 AM   #32
SEBSPEED
V4's FTW
Local Time: 08:34 AM
Flip Offs: 53
I knew going in that the periphery and holes would be shitty - I'm not a fan of plasma cutting. That said, it was cheaper and faster than my usual waterjet source and for the application, it was good enough. All the holes and slots accept the bolts, thankfully. I wasn't looking forward to buying a tapered reamer to clean them up because I definitely wasn't going to use my good drills on the shitty hardened edges.
I'm going to deburr the parts and dress the edges a little, then blast and paint.
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
This user High Fived SEBSPEED!
Old Streetfighter Motorcycle Forum Post 09-23-2018, 05:06 PM   #33
SEBSPEED
V4's FTW
Flip Offs: 53
De-slagged the plasma parts and cleaned the edges up on the sander. Deburred them and ran them through the glass bead cabinet to get most of the rust and scale off. Shot them with etch primer and satin black. No pics, too busy.
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Old Streetfighter Motorcycle Forum Post 09-24-2018, 08:46 PM   #34
SEBSPEED
V4's FTW
Flip Offs: 53
Picked up a bunch of hardware and some paint today, got a test fit of the bracket for the sliding rear post, put on some stickers but messed one up
That one will be welded around the "T", upper bolts just there to hold alignment for welding, will sit more like this
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Old Streetfighter Motorcycle Forum Post 09-27-2018, 09:10 PM   #35
SEBSPEED
V4's FTW
Flip Offs: 53
Like so
With the paint ground off I got to welding
And painted
Was running out of daylight so we skip to after I welded the other bigger pieces together, more paint
Also removed the trunnions so I can clean them up and pack with fresh grease. This fixture sat outside in the weather for a while and they're a little gummed up. I happen to have some clean leftover sae hardware that fits, so can replace all the rusty bolts. Got the larger truss section mostly prepped for paint too.
Not enough red left for the base... thinkin maybe silver
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Old Streetfighter Motorcycle Forum Post 09-30-2018, 12:43 PM   #36
Zweihammer
Misfit
Fighterer
Zweihammer's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:34 AM
Flip Offs: 1
Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!
Damn nice. I have a long time friend who builds old skool choppers, once he started making frames, demand for them took all his time, had to start turning them down to make time for anything else.
Fancy trunnions and stout frame, was this for rolling or storing material in a former life? I looked at a frame a friend offered me that used to be used in a carpet warehouse for a possible car rotisserie, it was too big to get back to my shop without hiring a rollback. Passed on it and still regretting it.
2019 Winter Build Off Bike
2019 Winter Build Off Chit Chat
Bones heal, chicks dig scars, pain is temporary, glory is forever. E. Knievel
Zweihammer is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-30-2018, 09:07 PM   #37
SEBSPEED
V4's FTW
Flip Offs: 53
Thanks. I'm really looking forward to playing with it. It was a decommissioned assembly fixture, it supported a separate aluminum assembly fixture/drill jig. Got lucky with getting it but still paying the price for moving it by myself.
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Thank you for viewing Frame and arm jig build in the Heavy Metal section of our streetfighter motorcycle forum. I hope you found it useful!
Heavy Metal - Frame and arm jig build on Custom Fighters Streetfighter Motorcycle Forum
