How To Attach a Subframe. - Page 3 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > How To Attach a Subframe.
Old Streetfighter Motorcycle Forum Post 08-04-2019, 06:26 AM   #21
yantosh
Local Time: 12:22 PM
Flip Offs: 14
Default Re: How To Attach a Subframe.
look at my CB1300 build, i made it to look like ally joined to steel , can still have ally subframe, just needs bolted on
This user High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 08-04-2019, 02:10 PM   #22
remfanuk
Senior Member
Fighter
Local Time: 06:22 AM
remfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to all
Aye...see what you did there...interesting paint trickery stored for future use.
Sent from my SM-G960F using Tapatalk
remfanuk is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 08-04-2019, 02:41 PM   #23
yantosh
Flip Offs: 14
steel sleeve with subframe inserted
Old Streetfighter Motorcycle Forum Post 08-04-2019, 05:46 PM   #24
Mongoose
Local Time: 04:22 AM
why not make a bolt on sub frame like every bike out there... ezpz
Mongoose is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 08-04-2019, 06:29 PM   #25
Mattson
Stressed Member
Local Time: 02:22 PM
Flip Offs: 25
Fun fact: in Finland if you have a welded-on subframe that`s hallowed ground you cannot touch it. IF however your subbie is a bolt-on you CAN WELD UP one then bolt it on, I`ve done it so I`d know. And since we`re not some track-hugging gram-wankers here I`ll bet my next lunch you cannot tell the difference weight wise if you`re sitting on alu or steel while riding.
Old Streetfighter Motorcycle Forum Post 08-06-2019, 12:24 AM   #26
rex_saugerty
V four honda whore
Flip Offs: 3
We get fingered when showing up at inspection with welded subframe. Thats the reason i prefered to get a bike with bilt on subframe. Not a big trouble to bolt some stuff once in two years
rex_saugerty is online now   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 08-06-2019, 06:57 AM   #27
yantosh
Flip Offs: 14
hope getting fingered isn't the same thing as it is here
Old Streetfighter Motorcycle Forum Post 08-06-2019, 11:28 AM   #28
rex_saugerty
V four honda whore
Flip Offs: 3
that was a colored expression
Old Streetfighter Motorcycle Forum Post 08-06-2019, 12:23 PM   #29
remfanuk
Senior Member
Fighter
Not sure we have the same grief with a welded subby here in the UK. The bolted on solution that I have seen on other bikes seems complex and out of my league...passing a subframe idea to a welder seemed like the best option. Earlier in this thread it was explained what would be needed in terms of a bolt on solution with inserted slugs half cut through to allow an ally inversely cut slug which seems a lot of work that might be unfamiliar to potential welders?
Old Streetfighter Motorcycle Forum Post 08-06-2019, 01:43 PM   #30
yantosh
Flip Offs: 14
no grief here with welding on subby
Thank you for viewing How To Attach a Subframe. in the Heavy Metal section of our streetfighter motorcycle forum. I hope you found it useful!
Heavy Metal - How To Attach a Subframe. on Custom Fighters Streetfighter Motorcycle Forum
