Exhaust support - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Exhaust support
Old Streetfighter Motorcycle Forum Post 09-04-2019, 10:56 PM   #1
Ride
Fighter In Training
Ride's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 12:20 PM
Ride is a NOOB
Default Exhaust support
I removed the welded on passenger peg supports which also supported the factory muffler.
I contacted danmoto and they are telling me that a support on the muffler is necessary. That what I have now (a strap from the link pipe to the peg/rear set) is not enough.
They are saying the exhaust can will likely break or fall off.
Is it possible to pop rivet the muffler can to the interpipe/link pipe and expect it to hold up reasonably well?
Ride is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-05-2019, 03:38 AM   #2
Mattson
Stressed Member
Local Time: 03:20 PM
Flip Offs: 25
Default Re: Exhaust support
Pop rivets are soft, they'll shear off in no time. Perhaps some sort of an arm going behind the can if you don't wanna hang it off the subframe? Maybe bolt it to the back of that rearset adjuster plate?
These people High Fived Mattson!
Old Streetfighter Motorcycle Forum Post 09-05-2019, 04:05 AM   #3
a_morti
Local Time: 02:20 PM
Flip Offs: 24
Also the rubber spacer around your big P clip isn't going to last long against the heat of the link pipe.
This user High Fived a_morti!
Old Streetfighter Motorcycle Forum Post 09-05-2019, 04:41 AM   #4
Mattson
Stressed Member
Flip Offs: 25
Do they still not deburr those straps? The one that came with my JISU can was quite literally razor sharp, cut myself on it without noticing it til my hand was all red and wet.
Old Streetfighter Motorcycle Forum Post 09-05-2019, 05:08 AM   #5
a_morti
Flip Offs: 24
I guess the rubber is for vibration damping? Car exhausts are hung from rubber, OEM bike exhausts will usually be hung on a rubber bushing.
Old Streetfighter Motorcycle Forum Post 09-05-2019, 05:26 AM   #6
Mattson
Stressed Member
Flip Offs: 25
I guess so plus scratch prevention too, they just stamp the straps off a sheet and don't do anything to them, they're delivered straight and you gotta both bend it and put on the rubber strip which I guess is when I managed to cut myself on the endge that was sharp enough for me to not even feel it til I noticed my hand is wet.
Old Streetfighter Motorcycle Forum Post 09-05-2019, 01:08 PM   #7
Larry02ACR
Senior Member
Fighterer
Larry02ACR's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 07:20 AM
Flipped Off 1 Time in 1 Post
Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!
If it makes you feel any better, I've had this Dan Moto on for awhile and it hasn't fallen off or cracked yet.
I did lose one of the springs once, but those are pretty easy to source.
Larry02ACR is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-05-2019, 04:42 PM   #8
Ride
Fighter In Training
Ride is a NOOB
Is it only supported at the link pipe? I love that exhaust and in retrospect wish I had gotten it instead of the carbon fiber one.
Old Streetfighter Motorcycle Forum Post 09-05-2019, 04:42 PM   #9
Ride
Fighter In Training
Ride is a NOOB
Yes danmoto told me the same- it’s not meant for direct to pipe contact and would melt.
Old Streetfighter Motorcycle Forum Post 09-05-2019, 06:30 PM   #10
Larry02ACR
Senior Member
Fighterer
Correct, if you look halfway between the right peg and right passenger peg, you'll see a bolt head.
I cut/bent up a piece of stainless and had it welded to the mid pipe so I could bolt it there.
Basically looks like it's floating.
This user High Fived Larry02ACR!
Thank you for viewing Exhaust support in the Heavy Metal section of our streetfighter motorcycle forum. I hope you found it useful!
Heavy Metal - Exhaust support on Custom Fighters Streetfighter Motorcycle Forum
