First one is the hardest.. - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > First one is the hardest..
Old Streetfighter Motorcycle Forum Post 12-03-2019, 03:29 PM   #1
Mongoose
Local Time: 05:31 AM
Default First one is the hardest..
So first project is welding tubes of 6061 to the stock inlets which are cast...
Never welded cast before... I was gonna soak em in acetone and cook them.. Could also dip them in lye.. The internet is also devided about which rod to use..
Mongoose is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 12-03-2019, 03:41 PM   #2
yantosh
Local Time: 01:31 PM
Flip Offs: 14
Default Re: First one is the hardest..
i use 4043 for everything, weld wheels, cast frame sections, engine covers, new tube
This user High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 12-03-2019, 04:39 PM   #3
SEBSPEED
V4's FTW
Local Time: 08:31 AM
Flip Offs: 53
Dish detergent + warm water + clean stainless wire brush is a good prep for new and cast aluminum. Depending on thickness, you can preheat the part with a heat gun.
I also use 4043 for 99% of my AL welds, but I do have some 5356 for parts that might live outside and/or in salty climes.
Stay away from chlorinated brake cleaners for weld prep - acetone is fine provided you make sure it's all flashed off prior to welding.
ETA - I started using automotive aluminum cleaner for critical welds. Mild phosphoric acid in a pump spray bottle, find it at car parts stores.
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
This user High Fived SEBSPEED!
Old Streetfighter Motorcycle Forum Post 12-03-2019, 09:43 PM   #4
shinyribs
Flip Offs: 58
I also use 4043. No particular reason. It's what the welding shop had and I haven't had any failures, so I don't rock the boat.
I cook really dirty castings in the oven after degreasing, blasting or whatever. Otherwise I'll just scuff and use acetone or alcohol.
Thank you for viewing First one is the hardest.. in the Heavy Metal section of our streetfighter motorcycle forum. I hope you found it useful!
Heavy Metal - First one is the hardest.. on Custom Fighters Streetfighter Motorcycle Forum
