'96 ZX6R by Krizzo - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > '96 ZX6R by Krizzo
Old Streetfighter Motorcycle Forum Post 05-26-2020, 07:00 PM   #1
Krizzo
Local Time: 07:40 PM
Krizzo is a NOOB
Default '96 ZX6R by Krizzo
Hello
I am currently in progress of building this 1996 ZX6R
I have initially purchased the bike for 250 and intended to build it on the cheap, however in the end I just wanted to do it sort of my "right" way, to have a reliable bike.
The works involved:
Sourcing a J1 exhaust together with a mivv carbon pipe in rough shape, I got this cheap the muffler was press on the exhaust as someone did not trim the tip, therefore they couldn't separate it and I got it as set for cheap, reconditioned the muffler and now have stainless exhaust and a decent muffler.
Fitted a yamaha fazer handlebar mounts onto the top yoke, the yoke was drilled and the mounts original bolts have been threaded all the way down to allow for bolting it to the yoke.
I have also got a renthal handlebar which was also off a fazer - although not sure if original to the bike, but the position on the bike seems good.
Bike has 40k miles on the odo, 24 years old, the radiators have seen better days and were perishing, a replacement radiator is no longer available, a company makes a replacement radiator for this bike but the price is 350, I have instead fitted a B1 new aftermarket radiator for the price of 80, I also deleted the oil radiator and will be fitting a coolant-oil heat exchanger off the J1 model, the feed and return from the oil radiator hoses are plugged with vw sump plugs, one will be used for oil temperature sensor location, the oil cooler feeds directly from oil filter and exits into the main oil rail, I believe it is safe to plug it without looping, pushing all oil via the filter and heat exchanger instead.
The new radiator uses a M20 fan switch, I will use a m20 to m16 reducer to use the original fan switch and connector, I may install an override switch on handlebars too
I adapted a J1 throttle assembly with custom length throttle cables, using the front adjusters off the J1 and keeping the original bends that attach to the carbs, together with this I installed J1 switchgears, they have the same plugs and require no modification, the choke cable seems long enough for now.
I chose a bandit aftermarket headlight, suzuki k4 indicators, will be installing a koso DB-03R dash + additional koso temperature meter for oil (dash only supports one temperature reading)
I will be using the original temperature sensor location for the koso sensor, in the cylinder head, using a m10 to 1/8 adapter.
The front brake master cylinder is off B1 model, braided lines from a suzuki bandit, stripped and cleaned brake calipers with new brake pads.
I am still waiting for parts to arrive but will hopefully update the thread as work progresses.
Krizzo is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Krizzo!
Old Streetfighter Motorcycle Forum Post 05-27-2020, 01:46 AM   #2
Local Time: 01:40 AM
Default Re: '96 ZX6R by Krizzo
welcome in
Thank you for viewing '96 ZX6R by Krizzo in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - '96 ZX6R by Krizzo on Custom Fighters Streetfighter Motorcycle Forum
