A noob’s 93gsxr build - Page 11 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > A noob’s 93gsxr build
Old Streetfighter Motorcycle Forum Post 04-26-2020, 11:16 PM   #101
93gsxr
Local Time: 05:45 AM
93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all
Default Re: A noob’s 93gsxr build
Carb rebuild
93gsxr is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-26-2020, 11:19 PM   #102
93gsxr
Tried some rattle can painting. Not great but will do for now.
These people High Fived 93gsxr!
Old Streetfighter Motorcycle Forum Post 04-27-2020, 12:53 AM   #103
Local Time: 03:45 AM
Flip Offs: 190
Rustoleum Metallic Blue?
This user High Fived Casper!
Old Streetfighter Motorcycle Forum Post 04-27-2020, 01:29 AM   #104
93gsxr
That’s the one.
This user High Fived 93gsxr!
Old Streetfighter Motorcycle Forum Post 05-31-2020, 01:09 PM   #105
93gsxr
Replaced my overflow tank with a generic one and had to make a bracket to mount it.
Installed the Koso DB-01RN gauge. Still need to figure out water temp. Light is on from the get go and stays on.
Since the bike came with 2 sets of fairing, one in rough shape, I decided to chop it and make a belly pan.
As you can see the pods are back on the carb. Thought it could help with the very rich setting.
It idles almost perfectly (tiny bit rich) but runs very very rich from there to 2k to 4k rpms, past that, it goes like a rocket.
If my understanding of tuning a carb is right (assuming my main jets 130 are correct)
1- start with leaning the mixture screw 1/2 turn in.
2-If that doesn’t work I will check to see if I have aftermarket needle. If yes lower the needle one notch if possible.
3- if that fails, start from the beginning with the main jet and installing the right one.
On that subject, where can you get main jets? The carb kit only comes with stock ones. Thanks!
Old Streetfighter Motorcycle Forum Post 06-03-2020, 04:05 AM   #106
93gsxr
Anyone able to identify this needle jet. Not stock and no markings of any sort.
Old Streetfighter Motorcycle Forum Post 06-04-2020, 12:39 PM   #107
93gsxr
Anyone?
Old Streetfighter Motorcycle Forum Post 06-27-2020, 05:10 PM   #108
NorthernBloke
NorthernBloke is a NOOB
I don't recognise those needles but have you checked them and the emulsion tubes for wear as that is a common problem on these carbs and gives rough running in the mid range as you describe.
NorthernBloke is offline   Reply With Quote on our streetfighter motorcycle forum
Thank you for viewing A noob’s 93gsxr build in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - A noob’s 93gsxr build on Custom Fighters Streetfighter Motorcycle Forum
