$175 Gamble - Page 2 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > $175 Gamble
Old Streetfighter Motorcycle Forum Post 12-08-2016, 11:26 AM   #11
fredycruger
fuck your face
CF Lover
fredycruger's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 12:31 PM
Flip Offs: 8
Flipped Off 10 Times in 6 Posts
fredycruger has much to be proud offredycruger has much to be proud offredycruger has much to be proud offredycruger has much to be proud offredycruger has much to be proud offredycruger has much to be proud offredycruger has much to be proud offredycruger has much to be proud offredycruger has much to be proud offredycruger has much to be proud offredycruger has much to be proud of
Winter Buildoff Winner
Default Re: $175 Gamble
for sure LOL
fredycruger is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 12-12-2016, 02:41 PM   #12
fredycruger
fuck your face
CF Lover
Flip Offs: 8
pulled the bike inside the shop and tear the engine down.
everything was going very easy till I had to take off exhaust and intake
looks pretty good up top
exhaust had no room to put socket on bottom bolt and open end wrench turned it about 1/8th at the time,
and off course it spun whole stud instead just nut
intake had one bolt on top of the manifold,
with no access to the bolt straight allen wrench wouldn't seat right in the bolt hole
I didn't have ball type wrench so I had to make my own tool with little bend in it
tool
I used dremel with cut off wheel clamped to vice and just turned the Allen wrench
These people High Fived fredycruger!
Old Streetfighter Motorcycle Forum Post 12-12-2016, 02:46 PM   #13
fredycruger
fuck your face
CF Lover
Flip Offs: 8
had to take the intake manifold to clear cross member
head would hit it
I didn't want to pull engine out so I just tilt it forward leaving one of the bolts in back in
in the end it doesn't matter bc crank bearing need to be replaced
I was hoping it would be just top end
Old Streetfighter Motorcycle Forum Post 12-12-2016, 04:06 PM   #14
fredycruger
fuck your face
CF Lover
Flip Offs: 8
should I dump it or get used engine for it
there's few complete engines on ebay from bmw f 650 bikes that should fit
they all around grand
Old Streetfighter Motorcycle Forum Post 12-13-2016, 12:15 AM   #15
shinyribs
Flip Offs: 58
Is it to expensive to rebuild what's there? Or swap in another engine altogether.
Old Streetfighter Motorcycle Forum Post 12-13-2016, 08:26 AM   #16
fredycruger
fuck your face
CF Lover
Flip Offs: 8
in the long run I think it will be better to get whole motor
crank bearing is shot
piston hit exhaust valves and bent them
jug is fucked, piston as well it only had 50 psi when I did the compression test
I might just dump the whole thing
or do streetbike motor in my spare time (oh .... I got no spare time lol)
This user High Fived fredycruger!
Old Streetfighter Motorcycle Forum Post 12-13-2016, 12:45 PM   #17
a_morti
Local Time: 06:31 PM
Flip Offs: 24
Looking at how tight the stock motor is in the chassis, you'll be limited on different motors, certain anything bigger. I'd be looking for a low miles crashed 650gs, the later model year the better. Even then a swift Google says the heads aren't the same so you'll at least be making a header and intake manifold.
Old Streetfighter Motorcycle Forum Post 12-13-2016, 12:51 PM   #18
a_morti
Flip Offs: 24
Having said later is better, the early one (funduro) has twin ports inlet and outlet similar to yours, so maybe the intake and exhaust would even fit. Depends if you prefer older, probably cheaper, and maybe simpler, or newer and more economical and powerful, but making manifolds.
Old Streetfighter Motorcycle Forum Post 12-13-2016, 01:28 PM   #19
fredycruger
fuck your face
CF Lover
Flip Offs: 8
yeah the earlier bikes are exact fit
that's the easiest and fastest way out but than I would have bike gears vs atv gears idk if that's problem
I can have 97 engine from bike for 700$ I think that's pretty pricey
Old Streetfighter Motorcycle Forum Post 12-13-2016, 01:30 PM   #20
fredycruger
fuck your face
CF Lover
Flip Offs: 8
motorcycle engine swap would be pretty hard too bikes usually have chain on left side this engine has sprockets on right
Thank you for viewing $175 Gamble in the Other Motorcycle Discussion section of our streetfighter motorcycle forum. I hope you found it useful!
Other Motorcycle Discussion - $175 Gamble on Custom Fighters Streetfighter Motorcycle Forum
