project: Pre-Mix Only discussion thread - Page 3 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > Past Streetfighter Buildoffs > 2011 Streetfighter Buildoff > 2011 Buildoff Discussion Threads
2011 Buildoff Discussion Threads All discussions about the 2011 Buildoff entries should go in here.
CustomFighters.com Streetfighter Motorcycle Forum > project: Pre-Mix Only discussion thread
Old Streetfighter Motorcycle Forum Post 02-17-2011, 08:25 AM   #21
sbk904
mekanik
Fighterer
sbk904's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 09:57 PM
sbk904 is making some friendssbk904 is making some friendssbk904 is making some friends
Default new topic...carbs!
OK, so i finally got around to disassembling the carbs this morning, and first off, the slides were completely seized, i spray some wd40 into there to let them sit, and decide to go ahead and remove the float bowl, and lo, there are stalactites forming in there.
it's really terrible looking in there.
i'm a cost-effective guy, the bike is far from original, i've already bought "rebuild" kits for each one, but i'm pretty sure, i'm going to need a little more than what's in the kit, and i don't mind returning the new kits i bought.
so what say you, rebuild or get another set?
anyone tried other carbs, like a stock banshee pair?
also still looking for input on the front rotor spacer...
my premix only '11 buildoff entry: http://www.customfighters.com/forums...ad.php?t=42527
discuss it here: http://www.customfighters.com/forums...ad.php?t=42528
sbk904 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-17-2011, 12:42 PM   #22
sbk904
mekanik
Fighterer
Default Re: project: Pre-Mix Only discussion thread
for what it's going to cost in parts rebuild, i just went ahead and ordered a pair of these: http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
Old Streetfighter Motorcycle Forum Post 02-17-2011, 12:48 PM   #23
Phoebe
Swamp Witch
Phoebe's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 11:57 PM
Flip Offs: 86
Flipped Off 17 Times in 15 Posts
Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!
Careful with those carbs from Asia. I had one I bought for my CB100 that literally broke apart in my hands because the casting was so bad. It was also a "Keihin". I put that in quotes because it was obviously a fake. I ended up buying a vintage carb and rebuilt it.
Phoebe is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-17-2011, 01:50 PM   #24
sbk904
mekanik
Fighterer
that's what i've read/heard, you either get a solid accurate clone, or a POS failure. i rolled the dice...
Old Streetfighter Motorcycle Forum Post 02-17-2011, 01:51 PM   #25
Phoebe
Swamp Witch
Flip Offs: 86
Good luck! I hope it works out for you
Old Streetfighter Motorcycle Forum Post 02-24-2011, 11:14 AM   #26
sbk904
mekanik
Fighterer
new progress update posted over on the build thread...i really need to work harder at taking more pics, or have a friend do it.
soooo, the next big thing is going to be the rotor spacer, need to get that sorted. after talking to an engineer buddy, having long bolts pass all the way thru the spacer will be about the same as bolting the spacer to the hub and bolting the rotor to the spacer, except cheaper and less complicated! i like simple solutions.
speaking of spacers, i need to make one for the upper triple still, as well as space the rear wheel and caliper hanger back there, and have the rotor narrowed, diameter shrunk, and cross drilled.
need to make the stingers and silencers, and plan out and build silencer supports.
need to order the CDI as well as work out either narrowing the sprockets to 520 width or ordering all-new...
still so much to do!!
Old Streetfighter Motorcycle Forum Post 02-24-2011, 12:08 PM   #27
midnight
holagan
Senior Fighterer
midnight's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 19
Flipped Off 7 Times in 5 Posts
midnight is a glorious beacon of lightmidnight is a glorious beacon of lightmidnight is a glorious beacon of lightmidnight is a glorious beacon of lightmidnight is a glorious beacon of lightmidnight is a glorious beacon of lightmidnight is a glorious beacon of lightmidnight is a glorious beacon of lightmidnight is a glorious beacon of lightmidnight is a glorious beacon of lightmidnight is a glorious beacon of light
I just picked up a 1970 rd350. So I will be following along with you. This will be my first 2 stroke bike so its going to get interesting real quick.
Nolite confidere quisquam
Be nice, polite, and have a plan to kill everyone you meet.......
midnight is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-24-2011, 01:25 PM   #28
86broncbro
motoHangar
Fighter
86broncbro's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
86broncbro is really nice86broncbro is really nice86broncbro is really nice86broncbro is really nice86broncbro is really nice86broncbro is really nice86broncbro is really nice86broncbro is really nice
Looking good man, two smokes rule!
86broncbro is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-25-2011, 02:11 PM   #29
sbk904
mekanik
Fighterer
rolled it out into the light of the day:
These people High Fived sbk904!
Old Streetfighter Motorcycle Forum Post 03-07-2011, 01:19 PM   #30
sbk904
mekanik
Fighterer
made some progress on the pipes today, re-covered the seat the other day, slapped the new OKO pwk carbs on...haha, it will be running SOON!!!
Thank you for viewing project: Pre-Mix Only discussion thread in the 2011 Buildoff Discussion Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2011 Buildoff Discussion Threads - project: Pre-Mix Only discussion thread on Custom Fighters Streetfighter Motorcycle Forum
