Long Term Zed - Page 30 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Long Term Zed
Old Streetfighter Motorcycle Forum Post 05-26-2020, 07:19 AM   #291
MDM
Procrastinator
Local Time: 05:34 AM
Flip Offs: 3
Default Re: Long Term Zed
Fuck my life...
Old Streetfighter Motorcycle Forum Post 05-26-2020, 12:23 PM   #292
yantosh
Local Time: 11:34 AM
Flip Offs: 14
that bolt not a hard as a hoors heart ?
Old Streetfighter Motorcycle Forum Post 05-27-2020, 11:22 AM   #293
MDM
Procrastinator
Flip Offs: 3
Seemingly not Yan, merely as hard as a parson's stools...
This user High Fived MDM!
Old Streetfighter Motorcycle Forum Post 05-27-2020, 11:26 AM   #294
MDM
Procrastinator
Flip Offs: 3
Anyways, it seems that the stripped bolt was not down to my ham-fistedness, not this time.
The aftermarket alternator rotor apparently needs to have the bolt shortened by about 4mm, and also needs a different thrust washer at the rear (one from an earlier 1100, with a smaller OD than the one for the 1100 Unitrak). The thrust washer, upon inspection, had been forced into a cone shape because it wasn't sitting in the recess at the rear of the ring gear, as the pic here shows...
ID:	108478   Click image for larger version
Old Streetfighter Motorcycle Forum Post 05-27-2020, 11:27 AM   #295
MDM
Procrastinator
Flip Offs: 3
The bolt met the cutting disc, and the thrust washer met the belt sander, and everyone lived happily ever after...
Old Streetfighter Motorcycle Forum Post 05-27-2020, 11:28 AM   #296
MDM
Procrastinator
Flip Offs: 3
Note - I'm going to make a closer check as to how well the rotor sits on the crank taper, and I may fit a brand new thrust washer (the correct size, natch) rather than the one that'd been pushed into a cone shape...
Old Streetfighter Motorcycle Forum Post 06-15-2020, 06:38 AM   #297
MDM
Procrastinator
Flip Offs: 3
New thrust washer purchased, and waited for, received, fitted and all back together again.
And then, once the starter and alternator gubbins was all back together, I happened to find a glass jar, containing some bits...
... yep, the very bits that I had fucked about trying to find, then ordering (wrongly), re-ordering (correctly), waiting for and then fitting...
Old Streetfighter Motorcycle Forum Post 06-15-2020, 06:41 AM   #298
MDM
Procrastinator
Flip Offs: 3
This was followed by more fucking about trying to get the sprocket cover and clutch actuator fitted correctly, with some issues as the cover wasn't fitting flush to the crank cases... eventually traced down to the actuator not aligning with a slot in the cover. With this done, all was fitted, and the exhaust also bolted back on and lock-wired nice and neatly.
At which point I turned to the oiling system and realised that the exhaust would have to come back off again so I could but the oil return fitting into the turbo... Time and motion, time and motion...
These people High Fived MDM!
Old Streetfighter Motorcycle Forum Post 06-15-2020, 12:41 PM   #299
yantosh
Flip Offs: 14
2 steps forwards, one step back cha cha cha...
This user High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 06-16-2020, 04:43 AM   #300
MDM
Procrastinator
Flip Offs: 3
Oil return fitting bolted into place and, while I was there I thought I might as well fit the oil feed line as well. Er, hang on, where is the oil feed line?... it should be here somewhere?... er....
Here we go again....
Thank you for viewing Long Term Zed in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Long Term Zed on Custom Fighters Streetfighter Motorcycle Forum
