zx10r forks to zx6r stem problems - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Street Fighter Swaps > Fork Swaps
Fork Swaps Fork and Front End Swap Discussion goes here
CustomFighters.com Streetfighter Motorcycle Forum > zx10r forks to zx6r stem problems
Old Streetfighter Motorcycle Forum Post 01-22-2013, 07:26 PM   #1
Spacecataz
Fighterer
Spacecataz's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 11:04 AM
Flipped Off 1 Time in 1 Post
Spacecataz is a splendid one to beholdSpacecataz is a splendid one to beholdSpacecataz is a splendid one to beholdSpacecataz is a splendid one to beholdSpacecataz is a splendid one to beholdSpacecataz is a splendid one to beholdSpacecataz is a splendid one to beholdSpacecataz is a splendid one to beholdSpacecataz is a splendid one to beholdSpacecataz is a splendid one to beholdSpacecataz is a splendid one to behold
Default zx10r forks to zx6r stem problems
so i have a 95 zx6r and im swapping some 07 zx10r forks on to it, i have everything ready to go the problem now is the stem. I cant just swap over my stem into the 10r stem since the bottom ID is 5mm different (10r is 35mm mine is 30mm) i do have a zx6r J stem which would be perfect since it shares the top ID of my zx6r bearing (25mm) and the bottom of ID of the 10r bearing. of course a spacer is required for the top if i do the J stem. But swapping the J stem is now a problem since its about an inch too long as seen below. Any ideas on what to do? get some one to thread the stem down more? im not too sure
Spacecataz is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-22-2013, 08:06 PM   #2
rubbersdown
sickboy
rubbersdown's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 08:04 AM
Flip Offs: 37
Flipped Off 45 Times in 29 Posts
rubbersdown is an amazingly helpful member with a good attitude!rubbersdown is an amazingly helpful member with a good attitude!rubbersdown is an amazingly helpful member with a good attitude!rubbersdown is an amazingly helpful member with a good attitude!rubbersdown is an amazingly helpful member with a good attitude!rubbersdown is an amazingly helpful member with a good attitude!rubbersdown is an amazingly helpful member with a good attitude!rubbersdown is an amazingly helpful member with a good attitude!rubbersdown is an amazingly helpful member with a good attitude!rubbersdown is an amazingly helpful member with a good attitude!rubbersdown is an amazingly helpful member with a good attitude!
Default Re: zx10r forks to zx6r stem problems
either thread it down further and cut an inch off the top or cut an inch out of the middle of the stem and weld it back together.
"Sex addicts are just guys who are telling the truth." - Rodney Ruxin
rubbersdown is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-22-2013, 08:07 PM   #3
Spacecataz
Fighterer
ok im not familiar with machining but how plausible is it to match the threads? difficult or pretty easy?
Old Streetfighter Motorcycle Forum Post 01-22-2013, 08:41 PM   #4
Hillsy
Senior Member
CF Lover
Local Time: 01:04 AM
Flipped Off 9 Times in 5 Posts
Hillsy is a splendid one to beholdHillsy is a splendid one to beholdHillsy is a splendid one to beholdHillsy is a splendid one to beholdHillsy is a splendid one to beholdHillsy is a splendid one to beholdHillsy is a splendid one to beholdHillsy is a splendid one to beholdHillsy is a splendid one to beholdHillsy is a splendid one to beholdHillsy is a splendid one to behold
Have you looked at the All Balls Racing site to see if you can get another lower bearing to fit the 10r triples into the zx6 neck?
Hillsy is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-22-2013, 08:45 PM   #5
rubbersdown
sickboy
Flip Offs: 37
any machinist will be able to do it
This user High Fived rubbersdown!
Old Streetfighter Motorcycle Forum Post 01-22-2013, 08:58 PM   #6
Spacecataz
Fighterer
yea the lower one isnt the problem its the top thats too big.
Thanks!
Old Streetfighter Motorcycle Forum Post 01-22-2013, 09:28 PM   #7
Hillsy
Senior Member
CF Lover
What's the diameter of the 10r stem at the top....and what's the OD of the ZX6 frame. That's the bearing size you need to look for.
Old Streetfighter Motorcycle Forum Post 01-22-2013, 09:39 PM   #8
Spacecataz
Fighterer
already checked they dont make a bearing thats 25mm ID and 47mm OD, ill just thread the J stem.
zx10r
OD: 55mm
zx6r
OD: 47mm
Old Streetfighter Motorcycle Forum Post 01-22-2013, 09:49 PM   #9
Hillsy
Senior Member
CF Lover
If you're after this bearing ^^^^ it's a common size - all the Suzuki GS's use it as a top bearing (as well as a bunch of other bikes).
What am I missing??
Old Streetfighter Motorcycle Forum Post 01-22-2013, 09:59 PM   #10
Spacecataz
Fighterer
What am I missing??
wait im an idiot its suppose to be 35mm ID and 47mm OD
Thank you for viewing zx10r forks to zx6r stem problems in the Fork Swaps section of our streetfighter motorcycle forum. I hope you found it useful!
Fork Swaps - zx10r forks to zx6r stem problems on Custom Fighters Streetfighter Motorcycle Forum
