zx9 94-97 steering stem size - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > zx9 94-97 steering stem size
Old Streetfighter Motorcycle Forum Post 01-25-2013, 12:32 AM   #1
rrfighter
Senior Fighterer
rrfighter's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 09:30 AM
Flip Offs: 3
Flipped Off 7 Times in 6 Posts
rrfighter is a name known to allrrfighter is a name known to allrrfighter is a name known to allrrfighter is a name known to allrrfighter is a name known to allrrfighter is a name known to allrrfighter is a name known to allrrfighter is a name known to allrrfighter is a name known to allrrfighter is a name known to allrrfighter is a name known to all
Default zx9 94-97 steering stem size
Hey fellas i need to know what size the stem is whete it presses in the lower triple. I would like to swap some usd from a zx9 on my bandit and trying to see if i can use my bandit stem on the zx9 trips and call it a day
rrfighter is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-19-2019, 01:26 PM   #2
rabies
time is running out......
CF Lover
rabies's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 1,393
Flipped Off 39 Times in 35 Posts
rabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to behold
Default Re: zx9 94-97 steering stem size
was wondering this because the 2000 ninja 9 has a longer stem then an 04 ninja 6.
trying to put ninja 636 forks on 83 magna
rabies is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-22-2019, 11:21 AM   #3
Junkie
re-tarded
Local Time: 06:30 AM
Flip Offs: 3
https://www.allballsracing.com/forkconversion/ you can look up conversion kits. the ID of the bearing will match the stem size. Obviously that doesn't tell you length, but it tells you diameter. It lists the stock forks as a conversion option, look at that and you'll get stock stem diameter - for an 00 ZX9 it's 25mm upper 35mm lower.
This user High Fived Junkie!
Thank you for viewing zx9 94-97 steering stem size in the Streetfighter Help Needed! section of our streetfighter motorcycle forum. I hope you found it useful!
Streetfighter Help Needed! - zx9 94-97 steering stem size on Custom Fighters Streetfighter Motorcycle Forum
