Need advice on a suzuki RF900 build - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Beginner Streetfighter Questions
Beginner Streetfighter Questions This is the place to ask all beginner questions with no fear of being flamed. This section will be HEAVILY MODERATED! Any fighter related question is allowed, no matter how simple!
CustomFighters.com Streetfighter Motorcycle Forum > Need advice on a suzuki RF900 build
Old Streetfighter Motorcycle Forum Post 11-27-2019, 02:46 PM   #1
Cat- sling
NoObie
Noobie
Local Time: 09:22 PM
Cat- sling is a NOOB
Default Need advice on a suzuki RF900 build
I want to change the swing so i want to find out if a busa swing arm will fit. I want to swop the standard front end for a suzuki k4 or a yamaha R1. Any advice on what will work if this parts does not work.
Cat- sling is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 12-03-2019, 12:15 AM   #2
Casper
The friendly Ghost.
Local Time: 07:22 PM
Flip Offs: 189
Default Re: Need advice on a suzuki RF900 build
I haven't seen too many RFs come through the forums, not as much information about what parts are easily swapped.
A few details with the swingarm to pay attention to:
Swingarm Pivot Width (Spacers or shaving)
Swingarm Pivot Bolt Diameter (Bearings)
Shock Mounting / Dogbone Mounting Motion / Location
A few details with the forks to pay attention to:
Steering Stem Bearings (All Balls Racing has a good list of bearings to use.)
Steering Stem Length (You can get one made or make a mix of parts to use RF stem on GSXR triples.)
Overall Wheel to Triples Height (If you go too short, you lose your ground clearance and make your steering more twitchy.)
Look around the site for other builders who have used the Hayabusa swingarm or the GSXR forks. You can usually find some measurements for the parts you are looking at or someone here may have the measurements stashed in a dark corner.
The best way in my opinion is to get the parts you want and then we'll help you sort the minor details out.
Old Streetfighter Motorcycle Forum Post 12-09-2019, 11:44 PM   #3
shift1313
shift1313's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flipped Off 6 Times in 6 Posts
shift1313 is a wicked helpful, well liked member!shift1313 is a wicked helpful, well liked member!shift1313 is a wicked helpful, well liked member!shift1313 is a wicked helpful, well liked member!shift1313 is a wicked helpful, well liked member!shift1313 is a wicked helpful, well liked member!shift1313 is a wicked helpful, well liked member!shift1313 is a wicked helpful, well liked member!shift1313 is a wicked helpful, well liked member!shift1313 is a wicked helpful, well liked member!shift1313 is a wicked helpful, well liked member!
So sadly the RF suspension and frame stuff was not "budget" but it wasn't like a gsxr. 96+ 900 got upgraded forks but the "hot ticket" was just throwing racetech goldvalves in them. Worked much better.
So despite the looks the frames on those bikes were steel. The engine is the same oil boiler found on the gsxr and bandits. Well the bottom end of the 600/900 is the 1100 case from the gsxr1100/bandit1200. Why? i don't know. I think the rf400 was based on the early 91/92 gsxr 600case/bandit 600 case. So the pivot diameter and how it fits is likely very similar to that found on "slingshot" gsxrs. Might be a good place to look for what arms people put on those 2nd gen GSXR builds for an idea. I ran a 95 arm on my kaw so i know the arms from 88-96 were interchangable but got bracing in the later years. 96+ SRAD gsxrs i believe also fit but the "dog bone" linkage mount went from the top of the arm from 95 to the bottom of the arm in 96. The RF bikes had the linkage mount on top like the slingshot gsxrs(which also makes me think those arms likely swap).
Are you trying to upgrade for looks or some performance?
also quick google search.
https://www.customfighters.com/forum...ad.php?t=52934
part way through the bike got a gsxr subframe and tail and a USD front but updates stopped in 2014.
shift1313 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 12-18-2019, 11:51 AM   #4
929_adam
929_adam's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 10:22 PM
Flip Offs: 501
Flipped Off 166 Times in 132 Posts
929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!
We had a rf900 builder on here ... lives locally to me...wtf was his user name. Mike D’Angelo where you at?
Gavin Wayne Butts - Greencheezeeta - 10/5/83 - 9/8/09 RIP My Brother
Originally Posted by mpls|cafe|racer
"Knowledge is knowing that you know nothing." That's a motto to live by. There's always someone out there better, more knowledgable, faster, etc. and you can always learn and improve...
AFF.COM
929_adam is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-13-2020, 02:32 PM   #5
Cat- sling
NoObie
Noobie
Default
Hi
Sorry for the late reply. The upgrades i want to do is for a bit of both. This is a RF900 head with a 1100 sub. I want to build a bike that is nice to drive and nice to play with... i will post pics as it develops. Just had the carbs redone and balanced. I have to decide to do the standard shocks or replace them with upgrade ones.
Old Streetfighter Motorcycle Forum Post 03-16-2020, 03:49 AM   #6
Mick
Noobie
Mick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to all
Pretty sure bandit swingers and rf900 are very similar if not interchangeable, if you want to fit any of the newer gsxr braced swing arms then the linkage mounts will be in the wrong spot, you’ll have to do some re engineering of the frame to accomodate. The pivot diameter is different but can be sleeved and the gsxr pivot is wider so would need trimming, I’ve put a k6 750 swing arm in a bandit, little bit of work but not hard if you’re down to the frame and can weld.
Have a look for my build to see some pics
I cut it twice and itís still too short
Mick is offline   Reply With Quote on our streetfighter motorcycle forum
Thank you for viewing Need advice on a suzuki RF900 build in the Beginner Streetfighter Questions section of our streetfighter motorcycle forum. I hope you found it useful!
Beginner Streetfighter Questions - Need advice on a suzuki RF900 build on Custom Fighters Streetfighter Motorcycle Forum
