RZV500 Two-Stroke Roller - Page 46 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > RZV500 Two-Stroke Roller
Old Streetfighter Motorcycle Forum Post 05-19-2018, 02:09 PM   #451
busa1300
CF Lover
busa1300's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 07:12 AM
Flip Offs: 1
Flipped Off 5 Times in 3 Posts
busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!
Fighter of the Month Fighter of the Month Fighter of the Month
Default Re: RZV500 Two-Stroke Roller
I just got my second box of parts for my RZV from Megazip today (about $500 worth of unavailable in USA parts)....no issues like that.
All parts look basically freshly minted...
They ship pretty fast and almost always have anything you need in stock, if still listed....with only one exception....(I tried to get some float bowl gaskets, but they would have held up the shipment about 3 weeks)
Time is not as much an issue with my build, as I know you want to get your project moving as fast as possible. But it only took a week from Tokyo to my house
https://www.megazip.net/zapchasti-dl...962/1ge-773877
It is for a 1GE RD500....or you can type in the number you need from the 51X parts book as well.
2019 winter build off bike RZV500R
https://www.customfighters.com/forum...d.php?t=136718
__________MY TWO STROKE ADDICTION_____________
RGV VJ21 L____________GT 750 J__sold _____
RGV VJ22 FL_________ GT 750 long term cafe project___
RGV VJ22 N ______________RS 250 Cup Bike_________
RGV VJ23 T__________And one for the water...SX-R 800_
RZ 350_______________The cherry popper...KD 80_____
___________________RZV500R____________________
busa1300 is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived busa1300!
Old Streetfighter Motorcycle Forum Post 05-31-2018, 05:23 PM   #452
Smoker
BLACK BELT
Local Time: 04:12 AM
Flip Offs: 34
Never tried to design a swingarm, so I'm learning a lot.
Looks like reducing the length of the (R6 style) arm will cause the upper brace to hit the frame. Lowering the upper brace puts it closer to the chain. Also, moving the sprocket forward puts the chain closer to the upper brace. Need to do some careful measuring before making changes.
Pulled out & split the casings to install the bearing, output shaft & front sprocket. Now, I can measure from the chain run.
Was thinking about gullwing in this style, but not right for this bike. There's no shock in the swingarm, so, all 4 tubes can be centered and welded to the pivot tube. Much better for clearance issues. Could still gullwing the lower tube.
Still waiting on OEM pivot tube parts. Sent the jacked up parts back and ordered new ones.
Old Streetfighter Motorcycle Forum Post 05-31-2018, 05:44 PM   #453
Smoker
BLACK BELT
Flip Offs: 34
R6 chain guard on top, RZ500 on the bottom.
Not sure if the RZ500 chain guard can be fitted to the tubular arm. May want a custom guard.
Old Streetfighter Motorcycle Forum Post 05-31-2018, 05:55 PM   #454
TURNIP
CF Lover
TURNIP's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 1
Flipped Off 1 Time in 1 Post
TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!
I bought some molybdenum-impregnated 1/4" plastic sheet and I cut and bend my chain slider bits out of it. Forms nicely enough with a little heat.
Isaac Newton was a bastard when he invented gravity!
TURNIP is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived TURNIP!
Old Streetfighter Motorcycle Forum Post 05-31-2018, 06:29 PM   #455
yantosh
Local Time: 12:12 PM
Flip Offs: 14
it'll fit fine
This user High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 05-31-2018, 09:33 PM   #456
Smoker
BLACK BELT
Flip Offs: 34
Wish I could find these:
Pretty sure it's a Chinese version. Probably Brombos.
This user High Fived Smoker!
Old Streetfighter Motorcycle Forum Post 05-31-2018, 11:33 PM   #457
Smoker
BLACK BELT
Flip Offs: 34
Thinking about having a tool made for the custom arm.
Aluminum collar about 1.5 inch wide and .125 thick to slip over the rear axle. Weld a tab on the side with 2 holes. Bolt on a length of aluminum bar that replicates the circumfrence of the tire.
Would help with placement of the upper brace, and the crossbar between the 2 lower arms.
Might even be able to place a piece on the end of the bar that simulates the curve of the tread.
Old Streetfighter Motorcycle Forum Post 06-01-2018, 12:08 AM   #458
shinyribs
Flip Offs: 58
That made me laugh. Also made me think about the "Brembo's" on the new BWM 310 GS. They are ByBre's, which is literally shorthand for By Brembo. Why they don't just call them Brembo, I don't understand. I guess their ego won't let them put Brembo on an Asian built bike. I think the Indian built KTM's use ByBre's, too?
Old Streetfighter Motorcycle Forum Post 06-01-2018, 12:26 AM   #459
SEBSPEED
V4's FTW
Flip Offs: 53
Why not use a full size wheel and tire?
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Old Streetfighter Motorcycle Forum Post 06-01-2018, 12:35 AM   #460
Smoker
BLACK BELT
Flip Offs: 34
The only R6 rear wheel I have is the new BST.
I could ship the tool, instead of the wheel & tire.
For measuring and fabrication.
Thank you for viewing RZV500 Two-Stroke Roller in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - RZV500 Two-Stroke Roller on Custom Fighters Streetfighter Motorcycle Forum
