October 2019 Fighter of the Month Entry Thread - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Fighter Of The Month > 2019 Fighter Of The Month
CustomFighters.com Streetfighter Motorcycle Forum > October 2019 Fighter of the Month Entry Thread
Old Streetfighter Motorcycle Forum Post 10-02-2019, 02:58 PM   #1
Cookie2000ad
Persuasion Engineered
Cookie2000ad's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 04:42 AM
Flip Offs: 166
Flipped Off 59 Times in 27 Posts
Cookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CK
Default Medal Burnout Contest Winner Fighter of the Month
Default October 2019 Fighter of the Month Entry Thread
Enter here for the October FOTM, get your ride in the FOTM pile! Pester anyone you see in the members project sections you'd like to see here!
The rules:
- You must have a minimum of 50 posts
- 4-8 good pics of your bike (and tell us which one you want used for judging)
- List of modifications and such
- Must currently own said bike
Past entries allowed providing
1. you did not win
OR
2. you've made measurable upgrades since last time
Non-winners will be rolled over from month to month for up to 3 months throughout the year, to keep things interesting!
Non-entry posts in this thread will be deleted.
Deadline is the 21st before we start voting.
Cookie2000ad is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Cookie2000ad!
Old Streetfighter Motorcycle Forum Post 10-06-2019, 04:30 PM   #2
SOL
Shit outta Luck
Fighterer
SOL's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 11:42 PM
Flip Offs: 7
Flipped Off 10 Times in 3 Posts
SOL is a glorious beacon of lightSOL is a glorious beacon of lightSOL is a glorious beacon of lightSOL is a glorious beacon of lightSOL is a glorious beacon of lightSOL is a glorious beacon of lightSOL is a glorious beacon of lightSOL is a glorious beacon of lightSOL is a glorious beacon of lightSOL is a glorious beacon of lightSOL is a glorious beacon of light
Default Re: October 2019 Fighter of the Month Entry Thread
Bought an 82 Cb750k in April. Did some work to get it ready for the Distinguished Gentleman's ride. ( postponed until OCT 13th.)
Mods:
Modified Frame and custom hoop.
Stripped tank to bare metal.
Custom African mahogany seat cowl
cb 900 carbs with Jets
gutted exhaust
83 Kawasaki Ninja 900r front end anti-dive fully functional.
AGM battery upgrade.
LED lights
Originally Posted by endo View Post
That looks like someone screwing a Scottish Terrier lol
2018 Build Below:
http://www.customfighters.com/forums...d.php?t=135380
SOL is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 10-09-2019, 12:27 AM   #3
mcantar
Fuck it, let's do it live
Local Time: 09:42 PM
Flip Offs: 44
It occurs to me I've never entered FOTM before. Suppose I oughta throw the Busa in the running before it leaves the garage.
Forgive me, copy/pasting laundry list from my build thread...
Engine:
- 2008 Hayabusa engine
- Full ported and polished head
- APE head studs and nuts
- APE adjustable cam sprockets
- APE manual cam chain tensioner
- Vance and Hines Heavy Duty cam chain
- Vance and Hines Heavy Duty stainless valves (+1mm over OEM) and springs
- Intake cam on exhaust side, custom profile on intake side
- APE high pressure/flow oil pump gear
- APE low profile crankcase breather
- APE clutch springs
- Custom clutch cover WITH A MUTHAFUCKIN LIGHT UP SKULLY ON IT!!!!! contributed by @SEBSPEED
- DiestchWerks fuel pump
- MagnaFlow fuel filter
- Billet fuel rail
- MotionPro Revolvr cam'd throttle system with modified cables
Turbo:
- Hybrid 90mm turbo, fresh bearings, new wheels, polished shaft
- TiAL 38mm wastegate
- TurboXS BOV
- Aluminum intake piping and plenum
- 6" core air-water intercooler
- Custom heat exchanger (2nd radiator for intercooler) on isolated system with 12v pump wired to ignition power
Suspension/brakes:
- Ohlins SU406 rear shock
- Custom stainless lines from CORE moto
- Ducati Panigale brake and clutch master cylinders
Frame/bodywork/electrical:
- Trimmed frame (ram air mounts and OEM subframe mounts)
- Modified B-King triple clamps and axle blocks
- Modified billet aluminum handlebars and risers
- Ohlins steering damper
- Widened fuel tank
- Modified off-the-shelf tail from Germany
- Highsider mirrors
- Custom CNC-cut subframe/battery box
- Custom reg/rec mount
- Heavily gutted/modified wiring harness
- Koso RX1N gauge
- MT03 headlight w/custom mount
- Custom acrylic tail lights with major help from @imsolidstate designed for "total internal reflection" to have no visible light point-source
- Motogadget M-Switch (2 button) for starter and high beam toggle
- Vortex rearsets, ASV levers, & various other blingy bullshit
First pic for voting, please.
Turbo Busa v2 2017 Buildoff.
Turbo Busa v1.1
Old Streetfighter Motorcycle Forum Post 10-14-2019, 05:11 PM   #4
make that thing forkless
forks and valves... WTF?
Senior Fighterer
make that thing forkless's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!
Fighter of the Month Fighter of the Month
Okay, I'm up for a good fight.... so I'll throw my latest build into the ring. I think every FoTM should include a 2-stroker... so I present to you Julian's Dirty Rat!
The bike was built for this years Dirtbag Challenge with the guidelines of $2000(US) build budget (which I admittedly went over just a bit, but no one at DBC cared), and 2 month build window.... so as the name suggests, its a bit raty!
Some details:
Engine:
Yamaha Banshee (similar RZ350 minus the YPVS), rebuilt with fresh hone, new seals and gaskets.
Carbs: stock w/ pod filters
Heads: stock with reshaped combustion chambers by Brian Turfery
Exhaust: Lassak expansion chambers modified to GP style and better fit to the chassis.
Chassis:
Frame: RZ350 heavily chopped.
Swingarm: custom, with similar length and shape to TZR250. Dual shock.
Front suspension: custom girder with dual shocks.
Front calipers and master: R6
Rear caliper and master: SV650
Shocks (x4): Yamaha / Ohlins from Yamaha SRX snowmobile. Hyperco springs.
Wheels: front GSXR, rear SV650 w/GS500 cush drive hub.
Rear sub-frame: custom and includes a rear rack (the DBC ride included 2 nights of camping so needed a way to secure camping gear).
Foot controls: GSXR
CNC parts: (triple clamp w/tach mount, axle eccentrics, front caliper / shock mounts) from secret CNC vendor in China (dirt cheap!)
Body:
Tank: R6
Seat: R6
Headlight: mini-oval
Tail light: no idea what its off of? Somehow ended up in a box of parts. (anyone recognize what bike its from?)
Build thread here: https://www.customfighters.com/forum...d.php?t=137258
First or second photo for judging.
Thanks!
[IMG]20190901_070725 by andbike, on Flickr[/IMG]
[IMG]IMG_0729 by andbike, on Flickr[/IMG]
[IMG]20190824_182200 by andbike, on Flickr[/IMG]
[IMG]IMG_0662 by andbike, on Flickr[/IMG]
[IMG]IMG_0679 by andbike, on Flickr[/IMG]
[IMG]20190901_070048 by andbike, on Flickr[/IMG]
[IMG]20190821_181200 by andbike, on Flickr[/IMG]
[IMG]dirty rat bike 4.1 by andbike, on Flickr[/IMG]
make that thing forkless is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived make that thing forkless!
Thank you for viewing October 2019 Fighter of the Month Entry Thread in the 2019 Fighter Of The Month section of our streetfighter motorcycle forum. I hope you found it useful!
2019 Fighter Of The Month - October 2019 Fighter of the Month Entry Thread on Custom Fighters Streetfighter Motorcycle Forum
