Smoker's Custom Motard - Page 149 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Smoker's Custom Motard
Old Streetfighter Motorcycle Forum Post 08-16-2019, 03:41 PM   #1481
Smoker
BLACK BELT
Local Time: 08:16 PM
Flip Offs: 36
Default Re: Smoker's Custom Motard
Thanks for posting that good info.
I've had quite an experience with anodizing, myself.
Not having a clue, I took everything for aluminum anodizing. One off parts, aftermarket parts, OEM parts, anything. All parts were mirror polished.
Had a wide variety of results. IMO, it all comes down to how hard the aluminum is. The same alloy, from different manufactures, or even different batches from the same manufacturer can end up with differences in anodizing color. Harder/less porous = lighter color, Softer/more porous = darker color.
All cast pieces went in with a mirror polish, all came out with flat finish.
This user High Fived Smoker!
Old Streetfighter Motorcycle Forum Post 08-16-2019, 09:02 PM   #1482
Smoker
BLACK BELT
Flip Offs: 36
Originally Posted by XxGRYMMxX View Post
could it be stripped and re-anodized?
Because of time and cost, I was hoping to find another $8 usd cap with darker blue.
Old Streetfighter Motorcycle Forum Post 08-17-2019, 08:05 PM   #1483
Junkie
re-tarded
Flip Offs: 3
yeah, I bet you'd spend 10 times that having it reanodized
This user High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 08-23-2019, 09:18 AM   #1484
Smoker
BLACK BELT
Flip Offs: 36
Trying to find these rear suspension bolts in titanium.
Not having any luck. Trying to avoid paying for one-offs.
Did find this, but doubt they'll have anything that will match up. Sending email.
Old Streetfighter Motorcycle Forum Post 08-23-2019, 03:10 PM   #1485
Mongoose
could you run a washer to take up the fixed rotation space and run a normal bolt?
Old Streetfighter Motorcycle Forum Post 08-23-2019, 04:37 PM   #1486
Junkie
re-tarded
Flip Offs: 3
That'd be a LOT cheaper vs making them from titanium bar stock
hell, even if you have to weld the washer on, I bet the price would be significantly less vs starting with a bar big enough to include the washer. that's a lotta $$$$ chips on the floor.
Old Streetfighter Motorcycle Forum Post 08-24-2019, 05:35 PM   #1487
Auser6guy
Active Member
Fighter
Local Time: 10:16 PM
Auser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to all
This is why we cant have nice things...
Auser6guy is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Auser6guy!
Old Streetfighter Motorcycle Forum Post 08-26-2019, 11:21 AM   #1488
Smoker
BLACK BELT
Flip Offs: 36
I could buy some thinner-walled tubing, but might be able to make this work.
For sure, no one else is using this tubing with RZ parts, so may as well give it a try.
The tubing is so thick, there's no way to use individual hose clamps.
Took some time and drew up a clamp that might work.
Thought about it, and I'm going to start over. The clamp is next to the custom radiator cap. The radiator cap matches the 2 caps on the overflow bottle, so may as well try to make a matching clamp.
Wish I was smarter, so I wouldn't have to do everything 2 or 10 times.
Old Streetfighter Motorcycle Forum Post 08-26-2019, 02:24 PM   #1489
TURNIP
CF Lover
TURNIP's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 11:16 PM
Flip Offs: 1
Flipped Off 1 Time in 1 Post
TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!TURNIP is an amazingly helpful member with a good attitude!
For sure, no one else using this tubing with RZ parts, so may as well give it a try.
The worst is when you solve something on a current problem and in the process realize that to be happy you're going to have to un-solve and then re-solve stuff you thought you had had settled down for good and all months or years previously.
I'm super close, again, after putting probably hundreds of hours of work in real life and on the computer into getting the tail of my forever-project close to something I can live with, to scrapping the whole thing, chopping off what's there and starting from scratch. :P
FWIW, when I have run into annoyances with clamp clearancing etc I've just safety-wired the hoses. It'll eventually cut into the material if it's done too tight but it works well for awkward tight clearance areas sometimes.
You could also use CV boot clamps (I think they're the same as the SS zips used to secure exhaust wrap) I've used those to secure hoses when I wanted something a little prettier than wire, and some also have rolled edges to prevent damaging the rubber.
This space intentionally left blank.
TURNIP is online now   Reply With Quote on our streetfighter motorcycle forum
This user High Fived TURNIP!
Old Streetfighter Motorcycle Forum Post 08-31-2019, 02:30 AM   #1490
RS_Raz
Dickhead
Senior Fighterer
Local Time: 04:16 AM
Flip Offs: 10
Got something interesting in the mail today.
Each fan puts out 31 CFM/52.7 m/h (@ 2 000 RPM).
Any more on this? I'm waiting to steal your idea
Thank you for viewing Smoker's Custom Motard in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Smoker's Custom Motard on Custom Fighters Streetfighter Motorcycle Forum
