Smoker's Custom Motard - Page 150 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Smoker's Custom Motard
Old Streetfighter Motorcycle Forum Post 08-31-2019, 12:43 PM   #1491
Smoker
BLACK BELT
Local Time: 07:54 PM
Flip Offs: 36
Default Re: Smoker's Custom Motard
Any more on this? I'm waiting to steal your idea
Okay, bro. I'll get back on it.
I've been slacking on the projects, and everything else. Situation is not looking good.
No matter what happens, I want to fight and build bikes. To the end of my life, or the end of my money, whatever happens first.
I know my friends, and I too, have big expectations. If I don't finish these bikes, the story of Smoker will be unfinished and sad. We can't let that happen.
I'll get back on the radiator and fans. Thanks for the push.
Old Streetfighter Motorcycle Forum Post 08-31-2019, 06:05 PM   #1492
Auser6guy
Active Member
Fighter
Local Time: 09:54 PM
Auser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to all
Default
Fuck bro. I hope not only that you finish the bikes but you also get to enjoy them. If there’s anything that any of us can do to help just ask. Happy to send money(you have paypal ?) , ideas and encouragement.
For the fans, if you find that they aren’t pushing enough air the Ducati panigale has a high spec fan attached to the oil cooler (I think) that might be good. It looks small enough but it is Italian... is that allowed ?
https://rover.ebay.com/rover/0/0/0?m...2F283438208127
Auser6guy is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Auser6guy!
Old Streetfighter Motorcycle Forum Post 09-01-2019, 07:04 PM   #1493
Smoker
BLACK BELT
Flip Offs: 36
Who are you again?
Just kidding, bro. I see your post count is low.
One of the nicest things I've read.
All I need at the moment is encouragement and friendship from my bros.
...and some help now and then to make cool parts.
Hang in there with me, dude. The best part of these long-ass threads may be coming soon.
Old Streetfighter Motorcycle Forum Post 09-16-2019, 05:04 PM   #1494
Smoker
BLACK BELT
Flip Offs: 36
Would look something like this. What I don't like is the coolant fitting is in the center, on top. Just think a center fan would be better. Still could be enough cooling.
Not sure if this is possible because of clearance for the thermostat, but I'm working on it.
Fans are 80x80x25mm.
Will also see what I can do with an actual motorcycle fan.
Old Streetfighter Motorcycle Forum Post 09-16-2019, 08:01 PM   #1495
Larry02ACR
Senior Member
Fighterer
Larry02ACR's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!
This guy thinks one is enough:
http://2stroketuner.com/fan%20kit/index.htm
Larry02ACR is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Larry02ACR!
Old Streetfighter Motorcycle Forum Post 09-18-2019, 12:35 PM   #1496
Smoker
BLACK BELT
Flip Offs: 36
Yeah. Most common fan used is from the 2002-2005 R6. That one looks like a Spal or other aftermarket R6 fan.
I was hoping a Spal 4" puller fan would fit. It'll work, but would push the radiator 60mm away from the cradle.
The CPU fans are only 25mm thick, but may not be strong enough. The Spal 4" fanblade is 96mm and puts out 147CFM. The CPU fanblades are 74mm and put out 31CFM each.
If I could use only 2 fans (none in the center), I could mount the radiator close to the cradle. Best option. Also saw an 80mm CPU fan that had a claimed output of 70CFM @2700 RPM. Didn't like the way it looked, but there may be a stronger fan I could use.
Charging up a battery, so I can do some simple testing.
This user High Fived Smoker!
Old Streetfighter Motorcycle Forum Post 09-18-2019, 01:41 PM   #1497
Casper
The friendly Ghost.
Flip Offs: 190
One thing to note with CPU fans is the environment that they are meant to be run at tops out 30°C-40°C below the average coolant temperature from an engine. might be worth while to heat a bit of steel in boiling water and set it on the fans to see if their casing melts at 100°C.
2011 Suzuki DRZ400S, 2006 Suzuki SV650N, 1994 Yamaha XJ600S and 1979 Suzuki GS750LN
Can't leave them alone...
Time to find a nice VStrom 1000 to round me up to 5...
Casper is online now   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Casper!
Old Streetfighter Motorcycle Forum Post 09-18-2019, 03:49 PM   #1498
Mattson
Stressed Member
Local Time: 05:54 AM
Flip Offs: 25
Hate to be "that guy" but I have serious doubts a couple confuser fans move anywhere near enough air to cool an engine...
Yamaha XJR 1300 `99
Ex:Bashan BS200-S7 '07 Street Quad
Ex: Benelli Tornado 900 '06
Ex:Triumph Daytona 955i DSSA '02
Ex:Honda CBR 600 F2 '91
Mattson is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-18-2019, 04:01 PM   #1499
Smoker
BLACK BELT
Flip Offs: 36
Not too worried about the plastic melting.
Very worried about the cheapo bearing and fan motor tolerating the heat.
If these fans last 50 hours on the bike, I'll be happy.
Paid $16 usd for a 5-pack of these fans.
Worried they might not last more than one ride.
If I go with CPU fans, I'll need a backup plan.
Old Streetfighter Motorcycle Forum Post 09-18-2019, 04:06 PM   #1500
Smoker
BLACK BELT
Flip Offs: 36
Got any serious knowledge to back that up?
How much air needs to be moved, to cool my +4mm RZ378 engine?
Thank you for viewing Smoker's Custom Motard in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Smoker's Custom Motard on Custom Fighters Streetfighter Motorcycle Forum
