Smoker's Custom Motard - Page 154 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Smoker's Custom Motard
Old Streetfighter Motorcycle Forum Post 10-26-2019, 02:23 PM   #1531
shinyribs
Local Time: 10:25 PM
Flip Offs: 58
Default Re: Smoker's Custom Motard
Man, I've had so many bikes with zero fuses. Uhh...8 right off the top of my head
Definitely not a bad idea, though.
Old Streetfighter Motorcycle Forum Post 10-27-2019, 02:34 PM   #1532
Mongoose
Local Time: 07:25 PM
never been a fan of those screw on fuse holders.. they never close as well as they should, and you end up cranking them on.. never to be undone..
i would say.. look at revivals stuff, they have make your own fuse blocks.. maybe someone here knows what these are called and know if a single fuse type..https://shop.revivalcycles.com/water...ay-fuse-block/
being a munit you only really need one fuse.. then you can run a solid state or breaker fuse.. https://shop.revivalcycles.com/solid...-reset-20-amp/
Old Streetfighter Motorcycle Forum Post 10-27-2019, 11:28 PM   #1533
Smoker
BLACK BELT
Flip Offs: 36
Main problem with installing an inline main fuse is there's no place to put it. Didn't plan ahead.
Trying to figure out what wire to order. Will probably use 4rcustomswire.com. (Recommended by Mike.) Thinking I could get by with 18 gauge wire for almost everything.
Old Streetfighter Motorcycle Forum Post 10-27-2019, 11:44 PM   #1534
Mongoose
18 should be good depending on what you're running...
i did 90% of my bike with 22 ga wire.
Old Streetfighter Motorcycle Forum Post 10-28-2019, 04:52 AM   #1535
Auser6guy
Active Member
Fighter
Local Time: 09:25 PM
Auser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to all
Default
Fusable link ? Maybe just crimp a fancy 2 pole connector on a link one side goes to battery and the other to the m-unit. Make a few spares...
https://www.rkssales.com.au/product_...hp?prodID=1607
Auser6guy is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Auser6guy!
Old Streetfighter Motorcycle Forum Post 10-28-2019, 11:12 AM   #1536
Smoker
BLACK BELT
Flip Offs: 36
It's a clean idea.
Had to look up fusable wire. Never seen it before.
Maybe as last resort. I could see it going wrong, in a big way.
Fancy 2 pole connector? No idea what that looks like, even after searching.
If wiring was an event in the Special Olympics, I'd probably come in last.
Old Streetfighter Motorcycle Forum Post 10-28-2019, 01:28 PM   #1537
Smoker
BLACK BELT
Flip Offs: 36
Any good CF threads on wiring?
Found this one. Sure there's more.
https://www.customfighters.com/forum...=Wiring&page=6
Old Streetfighter Motorcycle Forum Post 10-28-2019, 01:48 PM   #1538
Smoker
BLACK BELT
Flip Offs: 36
Was thinking about 22 gauge, but would hate to put it in the wrong place.
All of the inputs on the left side of the m-unit should be good to go with 26 gauge, or larger. 22 gauge is the smallest gauge sold in bulk on 4rcustomswire.com, so that's fine.
Appreciate any and all help, tips, and advice.
Old Streetfighter Motorcycle Forum Post 10-28-2019, 02:29 PM   #1539
Larry02ACR
Senior Member
Fighterer
Larry02ACR's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!
22 gauge would probably be fine on the input side of the m-unit, although I'd probably use 20 (or even 18) if I was wiring it, just based upon it generally being stronger and easier to crimp connectors to, not so much on current capacity.
If you are trying to hide a bunch of wires to your controls, you can find multi-strand wiring "bundles" that are all wrapped up in one insulator, like so:
I'd use at least 16 gauge on the 10A circuits on the right, and 10 gauge on the starter circuit.
Aux would depend on what I was wiring and how many amps it needed, but 12 gauge should handle the 16 amps max it specs.
Larry02ACR is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Larry02ACR!
Old Streetfighter Motorcycle Forum Post 10-28-2019, 02:36 PM   #1540
Mongoose
I think my horns are even wired on 22.. My fans are on 16.. My main grounds are 16 cuz the all go back to the battery.. I have no chassis grounds.. Leds are ok on 22.. Imo..
I bought a multiwire kit on amazon.. Not the best wire.. But its copper and cheap.. And 6 colours 25ft each
This user High Fived Mongoose!
Thank you for viewing Smoker's Custom Motard in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Smoker's Custom Motard on Custom Fighters Streetfighter Motorcycle Forum
