SV1000Reptilia - Page 13 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > SV1000Reptilia
Old Streetfighter Motorcycle Forum Post 03-14-2020, 08:11 PM   #121
Leroy
Leroy's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 04:42 AM
Flip Offs: 1
Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!
Winter Buildoff Winner Fighter of the Month
Default Re: SV1000Reptilia
Engine is in!
With fresh powder coated flywheel and clutch covers
and a clean, degreased engine
Got risers from a BMW R9 but it wasn't a straight fit.
Drilled an made new threads to fit to my yoke
And now I have a roller!
Leroy is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-18-2020, 04:29 AM   #122
Leroy
Flip Offs: 1
Done some work the last days.
Glued the headlight protectors to the cowl
I received a rear fender of a R6. Chopped and fited. Needs more trimming
Also received a silicone hose kit
I wish I had it a week earlier
It would be much more easy to fit it with the engine off the frame
Then I tryed to make the mounts for the cowl
That needs some more work. Pics later
A sheet of heat shield will keep the fuel a litle more cooler
The electric components are in place
I've bought some connectors for the tip over sensor, starter relay solenoid and the ecu to make an extension of the harness
Haven't do that yet
At the upper right of the picture you can see the tank breather I will use
I had a plan to fit the ecu here
But the male conector isn't waterproof
I could solder the wires one by one and then seal it with epoxy glue
I will try to avoid that if I can fit it somewere ealse
That's how she is siting right now
I'm thinking leave the subframe and tank like that or buy some kydex sheet and fit it under the subframe to hide the tank. Does anyone know if the kydex sheet can be paint?
These people High Fived Leroy!
Old Streetfighter Motorcycle Forum Post 03-18-2020, 05:18 PM   #123
Leroy
Flip Offs: 1
Harness extention for tip over sensor and starter relay solenoid done
Heat shield wrap on header done
Rear fender trimming done
The mailman brought those footpegs today
It's not too big... But, I could use it for frame sliders if I want
I might trim it later a bit...
Old Streetfighter Motorcycle Forum Post 03-19-2020, 10:26 AM   #124
Smoker
BLACK BELT
Local Time: 06:42 PM
Flip Offs: 34
I like the view of the fuel tank through the subframe.
Looks cool.
Old Streetfighter Motorcycle Forum Post 03-19-2020, 06:10 PM   #125
Leroy
Flip Offs: 1
I like it too! I hate the idea of all that dirt that will end up in there...
I might put a sheet under the tail and leave it like that
Old Streetfighter Motorcycle Forum Post 03-19-2020, 06:49 PM   #126
XxGRYMMxX
Breaking shit...
Local Time: 09:42 PM
Flip Offs: 8
clear plastic infill panels maybe? keep it clean but visible too.
Old Streetfighter Motorcycle Forum Post 03-19-2020, 07:17 PM   #127
Leroy
Flip Offs: 1
lights are in. Wrapped the mounts of the led converters with self vulcanized tape to add some grip.
I need the eagle eye leds for the indicators and an H4 adapter to finish the forth light. The other 3 bulbs are ready
Tail lights are ready. I only need the connectors for the indicators
Everything looks good! Now I need a battery, the air filter and some fresh oil to fire it up!
Old Streetfighter Motorcycle Forum Post 03-19-2020, 07:20 PM   #128
Leroy
Flip Offs: 1
Not a bad idea to consider
Old Streetfighter Motorcycle Forum Post 03-20-2020, 02:46 AM   #129
yantosh
Local Time: 02:42 AM
Flip Offs: 14
looking good sir
Old Streetfighter Motorcycle Forum Post 03-20-2020, 04:52 AM   #130
Leroy
Flip Offs: 1
Thank you sir!
Thank you for viewing SV1000Reptilia in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - SV1000Reptilia on Custom Fighters Streetfighter Motorcycle Forum
