Is Smoking Permitted? - Page 165 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Is Smoking Permitted?
Old Streetfighter Motorcycle Forum Post 11-06-2011, 11:51 PM   #1641
Smoker
BLACK BELT
Local Time: 05:24 PM
Flip Offs: 34
Default Re: Is Smoking Permitted?
I want to get a titanium spring for the rear shock, but not sure what rate to choose.
The bike should be around 300lbs, I'm 156lbs, and the fork springs are .700.
The Ohlins racing spring is way too stiff (600lbs/10.7kg).
Any help is appreciated. :smt006
Old Streetfighter Motorcycle Forum Post 11-07-2011, 08:24 PM   #1642
make that thing forkless
forks and valves... WTF?
Senior Fighterer
make that thing forkless's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 07:24 PM
Flipped Off 3 Times in 3 Posts
make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!
Fighter of the Month Fighter of the Month
Pete, I can help you with this, however it isn't straight forward.
The first step is to determine what "axle rate" is desired. This is the stiffness that you feel when you push down on the bike. Knowing what the correct number should be is the key. It is based on bike weight, rider weight, and riding style... however very little has has ever been published on target numbers for axle rate. You won't find good numbers in magazines as you will for rake and trail and those such numbers. So, this can be a bit tricky to determine and optimize.
The second step is to back calculate from the theoretical desired axle rate to the actual rate of the suspension spring. This calculation takes into account the geometry (linkage, etc) of the suspension system, and thus can vary greatly from bike to bike. Luckily there is good suspension software available to do these complex calcs for most of the common suspension types.
The only alternative is experimentation. If your RZs suspension is relatively stock in terms of the linkage geometry and how the shock is actuated, then I would start with the stock RZ spring and experiment from there getting stiffer or softer, depending on how the bike handles.
600lb/in spring is about right for an RZ350. Is the pre-load jacked up, or has the suspension geometry been changed? ...otherwise it should be okay.
Just an FYI - Back when I was doing the original suspension design for my forkless RZ I did a lot research into this and ended up developing my own software to plot the rate curves (the stock RZ350 has a very rapid rising rate by the way). One thing I noticed was that very slight changes to the linkage in terms of length of dog bones and linkage joint, or the mounting locations on the frame or swingarm could have very significant changes to the (axle) rate curve and thus greatly effect the ride characteristics of the bike.
Julian
make that thing forkless is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived make that thing forkless!
Old Streetfighter Motorcycle Forum Post 11-07-2011, 11:04 PM   #1643
Smoker
BLACK BELT
Flip Offs: 34
Thanks for that, forkless!
Unfortunately, my rear suspension link and dogbones aren't stock, and they aren't identical to the OEM pieces.
Maybe a good place to start is to compare the measurements on my suspension pieces to the OEM ones. This may give an idea of whether to go heavier or lighter on the spring (compared to OEM).
The 600 lb Ohlins racing spring is too heavy for my use.
I wish I could experiment with a few different springs, but I don't want to keep changing the spring out and scratch up all the newly finished parts. Was thinking about getting some used steel springs to test before buying titanium - but what a big job.
Might just have to make my best guess and go with it.
Seems VERY difficult to get the right spring. I think the titanium springs are available in differences of .2kg (7.2 - 7.4 - 7.6 - etc). They also cost A LOT!!! So, getting the right one is pretty important.
Old Streetfighter Motorcycle Forum Post 11-07-2011, 11:24 PM   #1644
Ruff
Rable Rable Rable
Ruff's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 97
Flipped Off 138 Times in 105 Posts
Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!
I'd try a couple steel springs in the range you suspect you want, then buy the titanium spring that has your favorite rate. You could always math it out, but in the end there's no guarantee you'll like the feel of the spring you got.
This is my least favorite part of engineering, expensive guesses.
Ruff is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Ruff!
Old Streetfighter Motorcycle Forum Post 11-08-2011, 01:05 AM   #1645
Senior Fighterer
If the 600lb/in spring is too stiff and you know that the dog bones and link aren't stock length anymore, then it is likely that the dog bones and/or the link are shorter than stock. This geometry would yeild a great mechanical advanatge to the shock/spring and this would feel stiffer. Can you confirm the length of these parts (compared to stock)?
If they are in fact of different length (shorter or longer) then the rate curve is sure to be different than stock. To know what the new rate curve is, we would need to (CAD) model the suspension in a simulation. From there we could also model the stock geometry, compare curves and extrapolate from there to find the correct spring rate. The unfortunate part is most likely the slope and progression of the curve is also likely to change, so the axle rate is not going to match the stock RZ over the full range of the curve even if we get a corrected spring.
Anyway, try to determine if the individual dog bones and linkage got shorter or longer than stock and we'll go from there. Also need to consider where the dogbones attach to your new swingarm... is it in the same location as on the stock swingarm? Keep in mind that a few milimeters difference in any one piece of the puzzle can make a big difference in what you feel on the bike.
J.
Old Streetfighter Motorcycle Forum Post 11-08-2011, 05:16 AM   #1646
Marginly-Mad-Mike
Senior Member
Fighterer
Marginly-Mad-Mike's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 2
Flipped Off 1 Time in 1 Post
Marginly-Mad-Mike is a glorious beacon of lightMarginly-Mad-Mike is a glorious beacon of lightMarginly-Mad-Mike is a glorious beacon of lightMarginly-Mad-Mike is a glorious beacon of lightMarginly-Mad-Mike is a glorious beacon of lightMarginly-Mad-Mike is a glorious beacon of lightMarginly-Mad-Mike is a glorious beacon of lightMarginly-Mad-Mike is a glorious beacon of lightMarginly-Mad-Mike is a glorious beacon of light
WHAT HE SAID LOL
Power without control is equal to pissing in the wind and you dont want piss in your face do you now.
MY FIRST BUILD PROJECT REBIRTH nsr 125 alcast
http://www.customfighters.com/forums...ad.php?t=50253
Marginly-Mad-Mike is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 11-08-2011, 02:57 PM   #1647
cabbie
OLD FART
Flip Offs: 17
Flipped Off 51 Times in 29 Posts
cabbie has much to be proud ofcabbie has much to be proud ofcabbie has much to be proud ofcabbie has much to be proud ofcabbie has much to be proud ofcabbie has much to be proud ofcabbie has much to be proud ofcabbie has much to be proud ofcabbie has much to be proud ofcabbie has much to be proud ofcabbie has much to be proud of
Fighter of the Month Fighter of the Month Fighter of the Month
I'm 156lbs
By the time you finish this bike you'll be a little old man and weigh half that!
Some members give me shit for doing things different, I give them shit back for doing things the same!!!!!
cabbie is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived cabbie!
Old Streetfighter Motorcycle Forum Post 11-08-2011, 03:01 PM   #1648
pineapple
Brhaap!
pineapple's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 02:24 PM
Flip Offs: 207
Flipped Off 164 Times in 50 Posts
pineapple is an amazingly helpful member with a good attitude!pineapple is an amazingly helpful member with a good attitude!pineapple is an amazingly helpful member with a good attitude!pineapple is an amazingly helpful member with a good attitude!pineapple is an amazingly helpful member with a good attitude!pineapple is an amazingly helpful member with a good attitude!pineapple is an amazingly helpful member with a good attitude!pineapple is an amazingly helpful member with a good attitude!pineapple is an amazingly helpful member with a good attitude!pineapple is an amazingly helpful member with a good attitude!pineapple is an amazingly helpful member with a good attitude!
pineapple is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived pineapple!
Old Streetfighter Motorcycle Forum Post 11-08-2011, 07:59 PM   #1649
Smoker
BLACK BELT
Flip Offs: 34
I'm already a little old man!
This whole year I've been putting in big hours at my regular job.
This user High Fived Smoker!
Old Streetfighter Motorcycle Forum Post 11-08-2011, 08:12 PM   #1650
Smoker
BLACK BELT
Flip Offs: 34
I'm going to get good measurements on the new pieces and the OEM pieces to get an idea of how things should have changed.
Also going to put the shock back together with the 10.7kg spring - or maybe get one used 8.0kg - 9.0kg spring so I can get some initial sag settings with the new suspension parts. Then I can make a better guess on the Ti spring.
So, I'll have to swap out the spring at least once.
Tags
ewoks stole my boxers
Thank you for viewing Is Smoking Permitted? in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Is Smoking Permitted? on Custom Fighters Streetfighter Motorcycle Forum
