Is Smoking Permitted? - Page 256 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Is Smoking Permitted?
Old Streetfighter Motorcycle Forum Post 03-10-2019, 11:24 AM   #2551
shinyribs
Local Time: 07:37 PM
Flip Offs: 58
Default Re: Is Smoking Permitted?
Billet +7mm stroker crankshaft with full ceramic bearings, ready to go.
Has a 30mm shaft, instead of the OEM 25mm.
Two stroke cranks are so weird. They look massively heavy, making you wonder how they rev so damn good. Helluva piece of hardware you got there, Smoker.
Old Streetfighter Motorcycle Forum Post 03-10-2019, 01:28 PM   #2552
Smoker
BLACK BELT
Local Time: 04:37 PM
Flip Offs: 34
Not a good pic, but these are matched plates, machined from 1/4 inch aluminum, and about 10 inches long. They bolt onto the footpeg brackets.
Appears to me that the footpeg brackets on the frame are bent. Not a lot, but noticeable.
Will bolt these plates onto the footpeg brackets, and use them to measure and square things up.
Wanted to do it before exhaust pipe fab, but didn't have time. Shouldn't matter. Pipe dimensions are off the frame and swingarm.
Old Streetfighter Motorcycle Forum Post 03-10-2019, 01:46 PM   #2553
Smoker
BLACK BELT
Flip Offs: 34
Getting this head ready for the engine build.
The one-off titanium head nuts were machined by Nigel Kimber. Noticed one of the nuts didn't have the same reflective pattern on the head. WTF???
Was looking at it and realized it's too heavy to be titanium. Has to be stainless. Took a look at the Supermoto +4mm engine, and sure enough- there was the missing titanium bolt.
Switched out the bolt. Mystery fuck up solved.
Also received the new machined thermostat cover.
Old Streetfighter Motorcycle Forum Post 03-10-2019, 02:07 PM   #2554
Smoker
BLACK BELT
Flip Offs: 34
Bad news!
When I bought these removable domes, I thought they could be machined for any crankshaft. Had them custom anodized to match the other red parts.
Now, I find out they're not the correct domes for a +7mm engine. Well, fuck. Probably won't have time to anodize the new domes. The new domes have machined ribs on the outside, so they're still strong after cutting out more material. Will get a pic, when I can.
Even more bad news. Just another error from much earlier in the build. Had one-off aluminum head washers cut and custom anodized to match.
Now, I'm more cautious, and don't want to use aluminum washers in critical locations.
Will try to get some titanium washers, but they won't have the matching red color.
This user High Fived Smoker!
Old Streetfighter Motorcycle Forum Post 03-10-2019, 06:44 PM   #2555
Larry02ACR
Senior Member
Fighterer
Larry02ACR's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 06:37 PM
Flipped Off 1 Time in 1 Post
Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!
They have to have much larger counterweight/stuffers because the air/fuel charge is drawn into the crankcase, compressed by the crank and forced through the transfer ports into the combustion chamber.
From a mass stand point, they rev well because it's twice the firing impulses. Also you have to take into account a lot of 4 strokes have counterbalancers, whereas not many 2 strokes do, making the gap between rotating mass not quite as large.
From an actual number of revs, 2 strokes rarely rev as high as their 4 stroke counterparts of the same displacement. Just sounds like a lot because of the twice as many power strokes.
For instance my KX250 maxes out at just over 10k, whereas a lot of the 250F MX bikes rev 13k-14k. But, at 10k my bike is firing 10k times, where at 14k a 4 stroke is firing 7k times.
Also why 2 strokes sound so super fucking awesome.
Larry02ACR is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Larry02ACR!
Old Streetfighter Motorcycle Forum Post 03-11-2019, 11:44 AM   #2556
Junkie
re-tarded
Local Time: 03:37 PM
Flip Offs: 3
do the domes result in excessive compression ratio with the stroker crank?
Old Streetfighter Motorcycle Forum Post 03-11-2019, 12:51 PM   #2557
Smoker
BLACK BELT
Flip Offs: 34
Excessive compression ratio is an understatement.
The pistons will crash into the domes, unless the domes are machined to accept the longer stroke.
Old Streetfighter Motorcycle Forum Post 03-11-2019, 02:18 PM   #2558
Junkie
re-tarded
Flip Offs: 3
Oh, I was assuming that the extra stroke meant you ran a longer jug, or spacer under it, or raised pin, or something of that sort leading to similar height of piston vs deck.
How do you make up for the 3.5mm extra height? You recess the combustion chamber into the head or something?
Old Streetfighter Motorcycle Forum Post 03-11-2019, 09:09 PM   #2559
Smoker
BLACK BELT
Flip Offs: 34
Yep.
Pretty sure spacers aren't good for the port timing on this engine.
Old Streetfighter Motorcycle Forum Post 03-12-2019, 10:49 AM   #2560
Junkie
re-tarded
Flip Offs: 3
Interesting. Port timing will change that way too, of course, in that it'll close earlier/open later (or am I thinking of this wrong?).
Tags
ewoks stole my boxers
Thank you for viewing Is Smoking Permitted? in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Is Smoking Permitted? on Custom Fighters Streetfighter Motorcycle Forum
