offset dogbones? - Page 2 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Brakes and Suspension
Brakes and Suspension Anything to do with fabricating and modifying brakes and suspension goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > offset dogbones?
Old Streetfighter Motorcycle Forum Post 10-27-2019, 04:57 PM   #11
makenzie71
Local Time: 02:39 PM
makenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to all
Default Re: offset dogbones?
Moving the center link around like most of those do still puts a dogbone in the middle of the rear header.
makenzie71 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 10-30-2019, 09:55 PM   #12
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
sebwiers's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 21
Flipped Off 36 Times in 19 Posts
sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!
How about something more like this? The main change is the dogbone is one piece. The inner bit is Y shaped and thicker, as it will see more stress. The outer bit is mainly for stability. You could make it from 3 pieces of flat strap steel with bends in them. If you are worried about flex when loaded (probably a valid concern) you could bridge the inner Y.
sebwiers is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived sebwiers!
Old Streetfighter Motorcycle Forum Post 11-01-2019, 12:17 AM   #13
Local Time: 12:39 PM
Flip Offs: 189
You can also cut a slot in the swingarm shock bolt mount to have two straight dog bones with the full shear strength of the swingarm shock bolt through both bearings / bushings. Just need to make sure to add a couple caps to keep dirt / dust out.
These people High Fived Casper!
Old Streetfighter Motorcycle Forum Post 11-01-2019, 09:42 AM   #14
makenzie71
The way the swingarm is made I don't think I could pull that off without cutting DEEP into the swingarm.
Old Streetfighter Motorcycle Forum Post 11-01-2019, 05:04 PM   #15
Flip Offs: 189
Okay, no cutting on the swingarm...
Instead of having the 90 bends in between the swingarm shock bolt and the knuckle (or shock eye), add a 3rd dimension to the system. Have a triangle on the left side, a tab of the dogbone on the right side coming out of your screen enough to clear the swingarm through bolt mount, a brace (round tube?) between the tab and the triangle that sits underneath the swingarm through bolt mount and another part of the dogbone going straight from the brace to the knuckle.
Thank you for viewing offset dogbones? in the Brakes and Suspension section of our streetfighter motorcycle forum. I hope you found it useful!
Brakes and Suspension - offset dogbones? on Custom Fighters Streetfighter Motorcycle Forum
