RZV500 Two-Stroke Roller - Page 12 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > RZV500 Two-Stroke Roller
Old Streetfighter Motorcycle Forum Post 09-30-2015, 01:34 PM   #111
Smoker
BLACK BELT
Local Time: 10:47 PM
Flip Offs: 34
Default Re: RZV500 Two-Stroke Roller
Still working on obtaining the aluminum to brace the frame.
In the mean time, I scored a tank plug. Should receive it in about a week.
I saw 3 RZ500 tanks for sale. Two were around $800 and one was $2,000. Fucking crazy!!
I was lucky to snag a rusted out tank from an RZ500 mechanic in the midwest. Got it for $138 shipped and not complaining.
I was going to try a Ducati or MVA tank, but the frame shape is not even close. So, my idea is to mod the OEM plug tank. Will probably cut out the front for a steering damper mount and ignition key, plus relocate and change the fuel cap.
The tank plug will be used to make a tank cover or monocoque body with a fuel cell underneath.
Old Streetfighter Motorcycle Forum Post 10-29-2015, 05:18 AM   #112
Smoker
BLACK BELT
Flip Offs: 34
Trying to get the titanium suspension parts done.
Also working on a theme with some of the hardware.
Aluminum magnetic oil drain bolt:
Old Streetfighter Motorcycle Forum Post 10-31-2015, 03:45 AM   #113
Smoker
BLACK BELT
Flip Offs: 34
I don't want my roller on naked wheels.
Working on suspension parts this weekend.
Old Streetfighter Motorcycle Forum Post 10-31-2015, 12:58 PM   #114
Smoker
BLACK BELT
Flip Offs: 34
Got a cheap upper triple from ebay to use temporarily.
Old Streetfighter Motorcycle Forum Post 10-31-2015, 11:10 PM   #115
MikeGyver
MikeGyver's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 310
Flipped Off 172 Times in 148 Posts
MikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too much
Default Medal Fighter of the Month
Plug as in carbon or fiberglass?
'98 Ducati 916
'00 Ducati 996
'03 SV650(sold)
Skully Stickers
Originally Posted by Danbuc View Post
yell, "Built not bought mother fucker!" in there face and then spit on their bike and walk off.
MikeGyver is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 11-01-2015, 01:08 AM   #116
Smoker
BLACK BELT
Flip Offs: 34
Well, I'm calling the rusted tank "the plug".
I'd like to modify the shape of this steel tank, and use it to make a mold for a carbon tank cover or monocoque.
That way, I don't have to start from scratch.
Old Streetfighter Motorcycle Forum Post 11-02-2015, 03:24 AM   #117
Smoker
BLACK BELT
Flip Offs: 34
Sat down to take measurements for the new suspension parts - and decided to change the design.
The long M10 titanium bolt I bought is 20mm too short for the new design. Fine for replicating an OEM length bolt - but now I need another one.
The titanium relay arm bushings I made are also too short for the new design. They are OEM size. Need to buy raw titanium and remachine those.
The raw titanium I bought to make the M10 bushings and tube nut is too small in diameter for the new design. Need to buy larger titanium and machine those parts.
The OEM M10 bushings are 35mm, but the bore length is only 25mm - plus the bushing sits over 1.5mm out of the bore - so the contact area is just over 23mm.
The M10 bushings I designed are supported for the full length (40mm) and have 2 different O.D.s.
Not sure everything will work out, but we'll see.
Ordering more supplies now.
Old Streetfighter Motorcycle Forum Post 11-05-2015, 10:59 PM   #118
Smoker
BLACK BELT
Flip Offs: 34
Got the titanium to cut new suspension bushings. Also got the M10 x 240 titanium bolt for the linkage.
Picked up an oil filler bolt to match the oil drain bolt. Had to machine off the logos and will polish that part.
Old Streetfighter Motorcycle Forum Post 11-06-2015, 01:49 AM   #119
MikeGyver
Flip Offs: 310
I'm so lost on your build at this point. Now I'm just here to oogle over the bling parts
'98 Ducati 916
'00 Ducati 996
'03 SV650(sold)
Skully Stickers
Old Streetfighter Motorcycle Forum Post 11-06-2015, 02:28 AM   #120
Smoker
BLACK BELT
Flip Offs: 34
The main things I want to do now are adding the 1 inch tubing to the frame, which includes chopping and moving the subframe; making the modified titanium rear suspension pieces; and doing custom triples with a steering dampener. Plus, getting other necessary parts for the roller.
Somehow I started getting a few nuts with that cut-out design. So, now if I see any nuts or bolts I can use with that cut-out design - I grab those too. Even if they're not strictly for the roller.
My builds are unplanned and very unorganized. My hope is that if I keep making parts - eventually there will be enough parts for a whole motorcycle!
This user High Fived Smoker!
Thank you for viewing RZV500 Two-Stroke Roller in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - RZV500 Two-Stroke Roller on Custom Fighters Streetfighter Motorcycle Forum
