Triples with 214mm fork spacing - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Streetfighter Motorcycle Discussion > Streetfighter Help Needed!
Streetfighter Help Needed! Need help with your 'fighter? Ask for help in here!
CustomFighters.com Streetfighter Motorcycle Forum > Triples with 214mm fork spacing
Old Streetfighter Motorcycle Forum Post 04-05-2019, 09:39 AM   #1
Local Time: 04:48 AM
Flipped Off 56 Times in 46 Posts
Default Triples with 214mm fork spacing
Looking for data on what bikes have triples that space forks at 214mm and have RSU (right side up), non-inverted forks.
Preferably in the Honda family to make stem swaps easier
Any help appreciated, TIA
SEBSPEED is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-06-2019, 06:15 AM   #2
a_morti
Local Time: 10:48 AM
Flipped Off 22 Times in 14 Posts
a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!
Default Re: Triples with 214mm fork spacing
Need a load more dimensions to give a good answer but this page may help to start.
https://litetek.co/Guide_USD_ForkDatabase.html
98/99 cbr900 forks have that spacing. Good forks, bit awkward getting a 17er in there.
Aaron, living in Gibraltar and riding a 2014 MSX125 (Grom) with a bunch of shiny shite on it. Slow n loud!
a_morti is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-10-2019, 06:12 AM   #3
Flipped Off 67 Times in 39 Posts
are you speaking about center to center or inner to inner?
Old Streetfighter Motorcycle Forum Post 04-10-2019, 07:11 AM   #4
Local Time: 09:48 AM
Flip Offs: 13
centre to centre, pitch between the fork legs
Old Streetfighter Motorcycle Forum Post 04-10-2019, 09:27 AM   #5
No other dimensions needed a this time. The only trouble with fitting a 17 is finding one. F2 to keep the speedo drive or F3 to dump it and gain floating rotors.
Center to center, as it will dictate the wheel/brake combo regardless of fork diameter.
Old Streetfighter Motorcycle Forum Post 04-10-2019, 01:12 PM   #6
a_morti
What parts are you wanting to use? The 214 isn't necessarily as important as you may think.
Eg the earlier cbr900 is 204 centres, but you can fit the same calipers. They only went wider in 98to allow 310 discs in a 16" wheel and less offset.
I'd be more interested in that offset; the later CBR has the forks 5mm nearer to the frame which was offset by a 5mm longer frame. 5mm in this dimension changes the handling a fair bit apparently.
Or more interested in the fork leg diameter. 45 leaves you looking mostly just at cbr9 forks, 41mm gives a lot of other options.
Old Streetfighter Motorcycle Forum Post 04-10-2019, 01:48 PM   #7
However odd it may seem - this is the only data I am interested in at this time.
Old Streetfighter Motorcycle Forum Post 04-10-2019, 02:09 PM   #8
a_morti
Fair enough! Think if you're looking for rwu honda, you've got your winner already. 214 is unusually large and was used due to the reasons above. Most other period rwu hondas had 204 spacing.
Got my curiosity piqued already
Old Streetfighter Motorcycle Forum Post 04-10-2019, 09:40 PM   #9
gonna run something fat
Thank you for viewing Triples with 214mm fork spacing in the Streetfighter Help Needed! section of our streetfighter motorcycle forum. I hope you found it useful!
Streetfighter Help Needed! - Triples with 214mm fork spacing on Custom Fighters Streetfighter Motorcycle Forum
