Which footrest hanger...home built or modified OEM? - Page 2 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Which footrest hanger...home built or modified OEM?
Old Streetfighter Motorcycle Forum Post 05-31-2019, 03:41 PM   #11
a_morti
Local Time: 05:15 AM
Flip Offs: 24
Default Re: Which footrest hanger...home built or modified OEM?
Got anything to mask the danger area? Could you cut and use the original as a guide?
Old Streetfighter Motorcycle Forum Post 05-31-2019, 03:53 PM   #12
remfanuk
Senior Member
Fighter
Local Time: 11:15 PM
remfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to all
think i might use several layers of tape topped off with some fabric loom tape to protect around the slots. trying to keep the original in one piece to sell on. I shall get a 10mm hole drilled through it and nibble gently away to make the slots.
remfanuk is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 06-02-2019, 01:35 PM   #13
remfanuk
Senior Member
Fighter
Default
Think i have been successful...will look good when sanded and smoothed. Footpeg mount hides notches around mount hole.
ID:	105264   Click image for larger version
ID:	105266   Click image for larger version
This user High Fived remfanuk!
Old Streetfighter Motorcycle Forum Post 06-02-2019, 02:51 PM   #14
Mongoose
Local Time: 08:15 PM
you could also take the nubs off... drill a couple hole and use some roll pins instead to locate it.. there shouldnt be that much rotational force in it.
Old Streetfighter Motorcycle Forum Post 06-02-2019, 02:54 PM   #15
remfanuk
Senior Member
Fighter
Default
That might have been a good way too. Thanks for the idea.
Old Streetfighter Motorcycle Forum Post 06-13-2019, 05:00 AM   #16
remfanuk
Senior Member
Fighter
Default
Decided that i was making too much of a fuck up with it so instead of trying to mill it with a pillar drill and nibble bits out of it with a Dremel.
So I thought I would just snip off the tabs on the peg mount. Anything i need to secure it with other than the bolt and Loctite? Spring washers or something?
ID:	105354   Click image for larger version
ID:	105356   Click image for larger version
Old Streetfighter Motorcycle Forum Post 06-20-2019, 02:18 PM   #17
remfanuk
Senior Member
Fighter
Default
I have now started on the heal guard...this may or not be made from carbon fibre.
Again, suggestions or comments to guide me appreciated...pointy? Stubby? Or something completely different? The heal plate will be mounted from behind into the hanger with a couple of M4 tapped holes.
And for the shits 'n' giggles the evolution of the home built footrest hanger.
ID:	105384   Click image for larger version
ID:	105388   Click image for larger version
Thank you for viewing Which footrest hanger...home built or modified OEM? in the Heavy Metal section of our streetfighter motorcycle forum. I hope you found it useful!
Heavy Metal - Which footrest hanger...home built or modified OEM? on Custom Fighters Streetfighter Motorcycle Forum
