Thanks to PP from Oldskoolsuzuki .This chart is a useful starting point for anyone wanting to replace the standard shock in their bike. You will obviously need to match up length and stroke of your bikes shock as closely s possible - be careful though, this chart does not cover top and bottom shock mount types, reservoir type and position, spring rates or internal valving
Great chart! Wish I had it a couple of months ago. I got my shock situation sorted out though. It just took a little time and a lot of searches on the net!
you guys are smarter than the bike shops so i come here to ask.I have a question i want to lower my 07 fz6 but the only kit i can find is only a inch. i'm 5'6" and wounder what shock will lower it.thanks for any help:runovasmiley:
a gsxr 1000 07 will fit a gsxr 750 94 , but you will have to make some spacers becouse it is bigger in the coil diameter and it will not go throw the wishbones. It will work just fine whit spacers
Here you go, at 317mm it is only a few mm longer, bolted right in no mods and stiffens up the rear real nice arty-smiley: a perfect match for 91 gsxr 750 and on the cheap:rock:
I've got an 05 gsxr 1000 on my 94 1100. Great fit but very soft at 8.1 kg/mm. I'm 200lbs and racetech calls for a 9.4kg/mm spring. So I just ordered an 07 750 that comes with a 9.4. Should be a good fit.
If you want something stiffer the 07/08 gsxr 1000 has a 10.1kg/mm same dimensions as the 06/07 gsxr 600/750 (correct me if i'm wrong)
Ok i didn't find this Thread till after i posted Here, but does anyone know the dimensions of the CBR600F3 1998 or their bolt on compatible front ends/Shocks?
What does the + and - numbers mean. Are the free eye to eye length externally adjustable? Or would you have to break into the shock and change things around? Or is it not even adjustable?
I'd give you rep if we still could. Props to ya for that. Now who's going to verify all the info is correct? lol
Related Threads
1.6M posts
40.4K members
Since 2006
