Carbs? And not the potato kind.. - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Making Power
Making Power Anything to do with fabricating and modifying engines, carbs, ignition, etc. goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > Carbs? And not the potato kind..
Old Streetfighter Motorcycle Forum Post 06-23-2017, 12:31 PM   #1
Mongoose
Local Time: 02:20 PM
Default Carbs? And not the potato kind..
So after riding around last night.. Got some readings need some input..
Idle dead lean 18:1
Cruise was around 11.5-12+ a bit
Half throttle/6k it leaned out 14.5-15
Full throttle was round 12-12.5
Carbs have one size up pilots
2 shims on the stock needles
One size up on the mains
8mm float height vs 7mm stock.
I was gonna add another shim? Not sure if i should pony out for a jet kit.. Thoughts? Opinions?
Mongoose is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 06-23-2017, 02:31 PM   #2
CK 187
CAPTAIN AWESOMEŽ
CK 187's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:20 PM
Flip Offs: 631
Flipped Off 470 Times in 171 Posts
CK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too much
Default Medal Supporter of the Streetfighter Build for Charity Supporter of the Streetfighter Build for Charity
Default Re: Carbs? And not the potato kind..
Tapered needles that'll come with a kit are the way to go
CK 187 is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived CK 187!
Old Streetfighter Motorcycle Forum Post 06-23-2017, 04:02 PM   #3
ultimate fighter
Remi's Dad
ultimate fighter's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 1,427
Flipped Off 875 Times in 399 Posts
ultimate fighter sits atop olympusultimate fighter sits atop olympusultimate fighter sits atop olympusultimate fighter sits atop olympusultimate fighter sits atop olympusultimate fighter sits atop olympusultimate fighter sits atop olympusultimate fighter sits atop olympusultimate fighter sits atop olympusultimate fighter sits atop olympusultimate fighter sits atop olympus
needles will fix it. mid range is all needle function, not about the height when the needle disengages further from the main BUT rather the taper will feed a more atomized amount instead of blasting it rich with too many shims or leaning out in a certain range
UF's 2017 winter buildoff MOE POWA
talk about my junk
Originally Posted by yantosh View Post
CB is cool as fuck , proper old skool kick your cunt in for looking at it funny
ultimate fighter is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived ultimate fighter!
Old Streetfighter Motorcycle Forum Post 06-23-2017, 05:17 PM   #4
shinyribs
Flip Offs: 58
CK and UF are on the money IMO. Raising the stock needles typically just moves the "richer" area of the needle lower in the rpm band, but it's still the same fuel curve.
I vote for more aggressive needles, too.
Old Streetfighter Motorcycle Forum Post 06-23-2017, 05:37 PM   #5
Mongoose
Yeah.. Kinda why i was debating on weather a shim woukd do fuck all... Are dyno jet needles ok? Factory pro doesnt make or at least stock one for my carbs any more.
Looks like a full weekend.. Finding a jet ket and cct..
Old Streetfighter Motorcycle Forum Post 06-23-2017, 06:01 PM   #6
a_morti
Local Time: 11:20 PM
Flip Offs: 24
That is very lean at idle. You can adjust that a bit with the air screws, which should also make it start easier.
Needles should help as that lot said. Probably not worth planning anything else in til you've done the needles as you won't know which way to go. Different brands of main jets aren't measured the same, eg dyno jet aren't based on the same system as keihin. So if you get a dyno jet kit, the numbers on the main jets you get in there should be treated with care.
a_morti is online now   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 06-23-2017, 10:03 PM   #7
Mongoose
idle reading has to be wrong.. either sucking in air of just not enough air flow? i mean how can i go from 19 and idle to 11 at 1/8th throttle cruise...
Old Streetfighter Motorcycle Forum Post 06-24-2017, 03:46 PM   #8
a_morti
Flip Offs: 24
Air screw too lean, pilot jet too rich.
This user High Fived a_morti!
Thank you for viewing Carbs? And not the potato kind.. in the Making Power section of our streetfighter motorcycle forum. I hope you found it useful!
Making Power - Carbs? And not the potato kind.. on Custom Fighters Streetfighter Motorcycle Forum
