B12 jetting problem, BST40 - Page 2 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Making Power
Making Power Anything to do with fabricating and modifying engines, carbs, ignition, etc. goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > B12 jetting problem, BST40
Old Streetfighter Motorcycle Forum Post 08-08-2017, 11:30 AM   #11
scottyp
str8 stoopid
CF Lover
scottyp's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 03:45 AM
Flip Offs: 10
scottyp is an amazingly helpful member with a good attitude!scottyp is an amazingly helpful member with a good attitude!scottyp is an amazingly helpful member with a good attitude!scottyp is an amazingly helpful member with a good attitude!scottyp is an amazingly helpful member with a good attitude!scottyp is an amazingly helpful member with a good attitude!scottyp is an amazingly helpful member with a good attitude!scottyp is an amazingly helpful member with a good attitude!scottyp is an amazingly helpful member with a good attitude!scottyp is an amazingly helpful member with a good attitude!scottyp is an amazingly helpful member with a good attitude!
Default Re: B12 jetting problem, BST40
Part of the issue is you're trying to tune 4 carburetors off of 1 AFR meter and rpm range.
What percentage is your throttle at from 2k-4k? What are your stock jet sizes?
From the symptoms you're describing, It sounds like your issue is more with your butterflies and emulsion tubes. throw it up on the stand, change the e-tubes and use the color tune to check your work on all 4 cylinders in that throttle range (I'm guessing between 15-30% up to 60% when you blip it for a wheelie)and adjust your needles from there. if it's still leaning out on you, Its the butterflies. I run my pilots a little rich just to match my mains.
Ideally, you're jetting should look like this, and you may have to switch to this after changing the tubes for a good baseline:
Pilot: +2 sizes over stock, so 45
Main: +6 over stock
Main Air Jet(not pilot air jet): Stock, but it doesn't hurt to have +1 and -1 sized on hand
Emulsion tubes and needles, I would also get 1 of each richer and leaner. Keep in mind your inner carbs may have leaner emulsion tubes and needles and that could be the entirety of your problem.
All of this is based off of elevation below 6000 feet. you'll need leaner jets if over 6000
Also it should be noted that you're gonna have to play around with configurations all over again once you change your tubes or needles. Remember to bench synch your carbs everytime you make any jet change.
Originally Posted by Guest
festivus
Fuck it, dying of old age sounds boring anyway...
Gunslinger Customs FB page
scottyp is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 08-08-2017, 11:35 AM   #12
scottyp
str8 stoopid
CF Lover
Flip Offs: 10
Here's another really good tuning guide, complete with pictures for guys like me who don't read good.
http://www.dansmc.com/carbs2.htm
festivus
Thank you for viewing B12 jetting problem, BST40 in the Making Power section of our streetfighter motorcycle forum. I hope you found it useful!
Making Power - B12 jetting problem, BST40 on Custom Fighters Streetfighter Motorcycle Forum
