blow thru vs draw thru? - Page 2 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Making Power
Making Power Anything to do with fabricating and modifying engines, carbs, ignition, etc. goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > blow thru vs draw thru?
Old Streetfighter Motorcycle Forum Post 12-23-2017, 12:13 PM   #11
FrenchFries
Local Time: 01:33 AM
Flipped Off 1 Time in 1 Post
FrenchFries is an amazingly helpful member with a good attitude!FrenchFries is an amazingly helpful member with a good attitude!FrenchFries is an amazingly helpful member with a good attitude!FrenchFries is an amazingly helpful member with a good attitude!FrenchFries is an amazingly helpful member with a good attitude!FrenchFries is an amazingly helpful member with a good attitude!FrenchFries is an amazingly helpful member with a good attitude!FrenchFries is an amazingly helpful member with a good attitude!FrenchFries is an amazingly helpful member with a good attitude!FrenchFries is an amazingly helpful member with a good attitude!FrenchFries is an amazingly helpful member with a good attitude!
Default Re: blow thru vs draw thru?
https://www.youtube.com/watch?v=lPD9V8cIuf8
can draw thru be ridden like that?
FrenchFries is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived FrenchFries!
Old Streetfighter Motorcycle Forum Post 12-23-2017, 01:52 PM   #12
RatFighter
UnicycleMode
Flip Offs: 190
For sure. Takes a steady hand to keep it up like that on a draw through, but the first bike I ever knew of that held a speed wheelie record was a draw through Bandit.
Can't find the pics of it, but this video is a slideshow of the pics...
The main issue with draw through bikes is that when the throttle is shut completely, it stacks the boost pressure back against the turbine wheel and slows the turbo immensely, resulting in a huge lack of boost when you get back into it, with a steady hand you can limit the stacking to a point that the video you posted is more than normal for the setup to achieve, just don't dump the throttle to full closed and open it back up expecting the same power, gonna have to wait until the turbo spools back up for that. Nice smooth throttle transitions will see to a good draw through setup holding the front wheel off the ground for miles and miles.
Getting kinda aggravated by youtube's changes in video results... used to be a video of a draw through GSXR1100 doing passes by a camera through a set of corners and it was actually really smooth off and on throttle transitions, reinforced my idea that even though they can be pretty sloppy, they are still pretty damn nice when tuned well. Loads of shim and jet changes later, they can be pretty civil no matter how hard you ride them.
This user High Fived RatFighter!
Old Streetfighter Motorcycle Forum Post 12-23-2017, 02:23 PM   #13
Mongoose
Local Time: 11:33 PM
can't you just fit a blow off valve on the manifold to negate that?
nvm i just realized that would be bad lol
These people High Fived Mongoose!
Old Streetfighter Motorcycle Forum Post 12-23-2017, 08:14 PM   #14
Racing Geek
lb/hp is what it's about!
Racing Geek's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 168
Flipped Off 83 Times in 73 Posts
Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!
Scavenger Hunt
That would be horrible but if you want to try it I'll definitely watch the video.
Racing Geek is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Racing Geek!
Old Streetfighter Motorcycle Forum Post 12-23-2017, 08:36 PM   #15
Mongoose
il'l dump it straight into the exhaust.
Old Streetfighter Motorcycle Forum Post 12-24-2017, 12:16 AM   #16
RatFighter
UnicycleMode
Flip Offs: 190
Holy shit I can't even imagine what igniting the Air/Fuel mix between the turbo and intake would be like... probably a really big boom and a ton of plumbing that isn't attached anymore. Turbine wheel chunks all over the place. Probably blow the carb right off the turbo too!
(At least that's the consensus I come to from stories I've heard about the early draw through and n2o days)
dindu, looking back at that craigslist ad I notice that bike also has a lockup clutch too. That's a serious bit of kit worth every penny if it starts and runs good. If I was closer I would be doing everything in my power to get my hands on it myself if you weren't serious about it.
Old Streetfighter Motorcycle Forum Post 12-24-2017, 12:32 AM   #17
FrenchFries
kinda far for me atm. I will need to at least sit on it till tuesday when enterprise opens again.
I am immersing myself in the crypto hype right now trying to figure out whats the next big hitter to get in on right now. balancing that with christmas and trying to people... And bike buying. And moms refinancing the house or whatever so the appraiser is coming next week. It's a whole busy stressful time. We shall see.
Old Streetfighter Motorcycle Forum Post 01-11-2018, 05:31 PM   #18
TurboXJR
Noobie
TurboXJR is a good noobieTurboXJR is a good noobie
Got both the draw through is a more powerful option as little pressure is lost from turbo to cylinders better for the strip as road riding is more difficult to manage i run a T25 Garret straight off a single HSR 42mm Mikuni race carb with a fuel regulator and a facet fuel pump to keep up feeding to thing .. My other is a blow through not quite as viscious and more useable on the street this ne is not quite finished yet and have alot of jiggery pokery to do with it but here they both are so to speak ...
and then theres the new one should have this one finished in a month or two
And ceramic turbos are the way forward
TurboXJR is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived TurboXJR!
Old Streetfighter Motorcycle Forum Post 01-25-2018, 08:58 PM   #19
beezwiz
Flip Offs: 7
Flipped Off 15 Times in 9 Posts
beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!
Beautiful bikes my man!
Thank you for viewing blow thru vs draw thru? in the Making Power section of our streetfighter motorcycle forum. I hope you found it useful!
Making Power - blow thru vs draw thru? on Custom Fighters Streetfighter Motorcycle Forum
