Trying engine for first time - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Making Power
Making Power Anything to do with fabricating and modifying engines, carbs, ignition, etc. goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > Trying engine for first time
Old Streetfighter Motorcycle Forum Post 09-05-2019, 11:35 AM   #1
GT550Build
NoObie
Noobie
Local Time: 05:49 PM
GT550Build is a NOOB
Default Trying engine for first time
Hi all. I've got a Kwak GT550 (1989) which was sat for 17 years. I was foolish and stripped the whole bike down without first getting it running. I have cleaned and rebuilt the carbs, fixed the wiring loom, bought a new coil and a new (used) CDI. SO basically my engine is on the floor and all the rest is in boxes.
I have tried turning the engine over by hand on the clutch; it would turn about 1/8th of a turn but then didn't want to go much further and I didn't want to force it.
Where do I go from here? I want to avoid taking the engine apart if I can help it. Should I just install the carbs, loom, tank and engine and see if it fires up? Or does it sound as if it's seized (or at least seized enough not to run properly)?
The reason I don't want to split the engine is because I'm pretty sure the gaskets will all need replacing if I do, and I'd rather keep them nicely sandwiched for now if nothing's going to leak.
Thanks,
GT550Build is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived GT550Build!
Old Streetfighter Motorcycle Forum Post 09-05-2019, 11:59 AM   #2
Junkie
re-tarded
Local Time: 02:49 PM
Flip Offs: 3
Default Re: Trying engine for first time
if it doesn't want to turn over easily, I'd start off by pulling the plugs and putting a tablespoon of Marvel Mystery Oil in each cylinder. Repeat on a daily basis for a few days and keep trying to turn it over.
This user High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 09-05-2019, 12:01 PM   #3
Junkie
re-tarded
Flip Offs: 3
...or it's possible that it doesn't want to turn much further because you're coming up to TDC, or up on a cam lobe. if you're turning it by hand on the clutch, there's no way that forcing it is going to hurt anything. using a cheater bar etc is a different story.
Old Streetfighter Motorcycle Forum Post 09-05-2019, 02:48 PM   #4
XxGRYMMxX
Breaking shit...
Local Time: 06:49 PM
Flip Offs: 8
chances are, if its sat for that long without running, the gaskets are all toast anyway. itll probably start to leak right about the time you think "hey, its been idling for a bit with no probs, I'll go for a quick spin", then oil all over...
Junkies idea with oil and working it through rotation are about all you can do without opening it up.
edit: are you turning it with plugs in or out? compression will probably stop you from turning it over by hand without tools if the plugs are in.
another thought: if that doesnt have a manual cam chain tensioner on it, Id be careful trying to turn it backwards. hydraulic and spring tensioners can go slack and timing can jump if spun backwards (at least on cars they do...)
This user High Fived XxGRYMMxX!
Old Streetfighter Motorcycle Forum Post 09-05-2019, 03:44 PM   #5
GT550Build
NoObie
Noobie
Default
Thanks everyone. I put warm diesel in it before turning it over, and took the plugs out. Yes i was worried about the cam chain and timing. Shall i just try and start it? Could it do any damage to the pistons, rings or bores?
Old Streetfighter Motorcycle Forum Post 09-05-2019, 04:43 PM   #6
Junkie
re-tarded
Flip Offs: 3
I'd get it to where you can turn it by hand (plugs out) before trying to get it to fire up
I'd also use something with a little more lubricant than diesel when trying to free it
Old Streetfighter Motorcycle Forum Post 09-06-2019, 04:29 AM   #7
GT550Build
NoObie
Noobie
So I tried it again last night, plugs out and squirted some WD40 down the bores. Tried turning on the big nut in the centre of the clutch as I did before (with a short ratchet). There was a bit of a clunk and felt as if something let go. Now the clutch just just turns around and there is very little resistance. Could it be that the cam chain has snapped? I think I have no option now but to open up and rebuild the engine. I got a glimpse of one of the valves and it looked quite rusty.
SO my plan is now to take the engine apart, order a full set of gaskets, and then see what needs replacing. I am now venturing into something that I've never done before!
Thanks for all your help up to now, it may be a while until I get around to doing this but I'll try and take some pics and update within the next couple weeks
Old Streetfighter Motorcycle Forum Post 09-10-2019, 03:04 AM   #8
Casper
The friendly Ghost.
Local Time: 03:49 PM
Flip Offs: 189
Cam chains and Primary chains are pretty beefy. I doubt you would be able to break one by trying to rotate a shaft. You may have released the stiction on the clutch pack and its not grabbing the steels any more?
There should be a cover on one side of the Crankshaft that hides a hex in the proper orientation to turn the engine over. Pull that cover first and try to turn the engine over (in neutral if you can find it) directly on the crankshaft. (No spark plugs for this; tranny oil also works well to cut the rust that builds around the rings when engines sit.)
I would personally get this engine to fire over and idle before I tore it down and replaced everything.
As for trying to start it via the starter, I would hold off on that to not burn out that motor. You should be able to get this turning over by hand using the right place to turn the crankshaft.
These people High Fived Casper!
Old Streetfighter Motorcycle Forum Post 09-10-2019, 05:49 AM   #9
GT550Build
NoObie
Noobie
Yes that sounds as what's happened, it was turning the engine over and I could see a piston moving up and down a touch, and now the clutch is just turning I think. I'll try your suggestions, thanks very much
Old Streetfighter Motorcycle Forum Post 10-16-2019, 03:56 AM   #10
GT550Build
NoObie
Noobie
Success (for now). Engine turned over fine. A friend helped me hook up the start motor which spun the engine over really well. Haven't tried it with fuel and spark yet but fingers crossed.
These people High Fived GT550Build!
Thank you for viewing Trying engine for first time in the Making Power section of our streetfighter motorcycle forum. I hope you found it useful!
Making Power - Trying engine for first time on Custom Fighters Streetfighter Motorcycle Forum
