SSSA Dimensions on ALL SSSA's...(no pics just descriptions) - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Street Fighter Swaps > Swingarm Swaps
Swingarm Swaps Swingarm and Rear End Swap Discussion goes here
CustomFighters.com Streetfighter Motorcycle Forum > SSSA Dimensions on ALL SSSA's...(no pics just descriptions)
Old Streetfighter Motorcycle Forum Post 11-18-2013, 03:56 PM   #1
GSX750_SF
King Ding-A-Ling
CF Lover
GSX750_SF's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:50 PM
Flip Offs: 20
Flipped Off 7 Times in 7 Posts
GSX750_SF is an amazingly helpful member with a good attitude!GSX750_SF is an amazingly helpful member with a good attitude!GSX750_SF is an amazingly helpful member with a good attitude!GSX750_SF is an amazingly helpful member with a good attitude!GSX750_SF is an amazingly helpful member with a good attitude!GSX750_SF is an amazingly helpful member with a good attitude!GSX750_SF is an amazingly helpful member with a good attitude!GSX750_SF is an amazingly helpful member with a good attitude!GSX750_SF is an amazingly helpful member with a good attitude!GSX750_SF is an amazingly helpful member with a good attitude!GSX750_SF is an amazingly helpful member with a good attitude!
Thumbs up SSSA Dimensions on ALL SSSA's...(no pics just descriptions)
I've been doing a LOT of research on SSSA's for my Kat build, and have amassed quit the repertoire of dimensions/measurements on a plethora of swingarms. There's no sense in keeping this wealth of knowledge to myself, so I figured I would share it on here for those of you that are hoping to mount one of these beauties o nyou build. Unfortunately, I do not have pics, so maybe the measurements/descriptions will help. So, here are some additional SSSA dimensions on just about every SSSA manufactured in addition to Cookie's write-up.
Here is some info on other sssa's...ENJOY!
Ducati 748/916/996/998 - 243mm
Ducati 848= 260mm (10.2 inches)
Honda VFR750 (1990-93) - 242mm
Honda VFR750 (1994-97) - 227mm
VFR400 - 192mm
RVR400 - 202mm
Hawk NT650 - 235mm
RC30 - 235mm
RC45 - 250mm
VFR800 - 280mm
MV Agusta F4 - 255mm
Triumph Daytona 955i - 284mm
92-97 Katana - 235mm
98-12 Katana - 240mm
Honda VFR ('90-'2003+), Hawk, RC30/45, NSR250 all use the same relative rear wheel offset. i.e. mix and match wheels amongst the various models and so long as the spindle face is unmolested the wheels will remain centered.
90-93 VFR (shock linkage mount is two lobes on bottom of swingarm)(shock end is a 'fork')
Length: 565
Pivot width: 242 (+3.5 thrust collar)
Pivot diameter: 20
Eccentric outside diameter: 105
Eccentric width: 70 (+3 crenelated 'edge')
Caliper carrier diameter: 75
Caliper carrier width: 14
Brake rotor diameter: 255
Brake rotor mount diameter: 110
Sprocket mount diameter: 175
Wheel drive diameter: 100
94-97 VFR (shock linkage mount is one lobe on bottom of swingarm)(shock end is an 'eye')
Length: 560
Pivot width: 227 (+3.5 thrust collar)
Pivot diameter: 20
Hawk (shock is direct-mounted to top of swingarm)(shock end is an 'eye')
Length: 545
Pivot width: 235
Pivot diameter (right): 15
Pivot diameter (left): <22
Brake rotor diameter: 240
Brake rotor mount diameter: 100
Sprocket mount diameter: 165
RC30 (shock linkage mount is two lobes on bottom of swingarm)(shock end is a 'fork')
Length: 530
Pivot width: 235
Pivot diameter: 20
Caliper carrier diameter: 76
Caliper carrier width: 13
Brake rotor diameter: 220
Sprocket mount diameter: 140
Wheel drive diameter: 85
RC45 (shock linkage mount is two lobes on bottom of swingarm)(shock end is a 'fork')
Length: 540
Pivot width: 250
Pivot diameter: 20
Eccentric outside diameter: 117
Eccentric width: 77 (+3 crenelated 'edge')
RVF400 (shock linkage mount is two lobes on bottom of swingarm)(shock end is a 'fork')
Length: 540 (??)
Pivot width: 215
Pivot diameter: 20
Eccentric outside diameter: 105 (??)
Eccentric width: 60 (+3 crenelated 'edge')
Caliper carrier diameter: 76 (??)
Caliper carrier width: 15
NSR250 / mc28
MV Agusta F4 (shock linkage mount is bolt on, under swingarm. linkage arrangement is similar to Ducati 916)
Length: 545
Pivot width: 255
Pivot diameter: 20
Eccentric width: 76
FINALLY for all you Katana owners out there: The pre-98 Katana Swingarm Dimensions/PICS!!!
***'94 GSX750F StreetFighter Under Con/(de)struction here>>> http://www.customfighters.com/forums...ad.php?t=72545***
Kate Beckinsale is a bad bitch...I'd drag my nuts through a mile of broken glass to hear her fart into a walkie-talkie. True talk.
GSX750_SF is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived GSX750_SF!
Old Streetfighter Motorcycle Forum Post 11-18-2013, 05:41 PM   #2
scrappy610
Senior Fighterer
scrappy610's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 06:50 PM
scrappy610 is an amazingly helpful member with a good attitude!scrappy610 is an amazingly helpful member with a good attitude!scrappy610 is an amazingly helpful member with a good attitude!scrappy610 is an amazingly helpful member with a good attitude!scrappy610 is an amazingly helpful member with a good attitude!scrappy610 is an amazingly helpful member with a good attitude!scrappy610 is an amazingly helpful member with a good attitude!scrappy610 is an amazingly helpful member with a good attitude!scrappy610 is an amazingly helpful member with a good attitude!scrappy610 is an amazingly helpful member with a good attitude!scrappy610 is an amazingly helpful member with a good attitude!
Default Re: SSSA Dimensions on ALL SSSA's...(no pics just descriptions)
Thanks for the research, this and cookies thread are book marked...
Repd
scrappy610 is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived scrappy610!
Old Streetfighter Motorcycle Forum Post 11-19-2013, 09:08 PM   #3
GSX750_SF
King Ding-A-Ling
CF Lover
Flip Offs: 20
New measurements added in OP for Katana's 92-98
This user High Fived GSX750_SF!
Old Streetfighter Motorcycle Forum Post 11-19-2013, 09:19 PM   #4
MikeGyver
MikeGyver's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 03:50 PM
Flip Offs: 312
Flipped Off 173 Times in 149 Posts
MikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too much
Default Medal Fighter of the Month
848/1x98 measurements?
'98 Ducati 916
'00 Ducati 996
'03 SV650(sold)
Skully Stickers
Originally Posted by Danbuc View Post
yell, "Built not bought mother fucker!" in there face and then spit on their bike and walk off.
MikeGyver is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 11-19-2013, 10:04 PM   #5
GSX750_SF
King Ding-A-Ling
CF Lover
Flip Offs: 20
Swingarm Pivot for the Ducati 848= 260mm (10.2 inches)
*EDIT* Added to the OP...
Old Streetfighter Motorcycle Forum Post 12-03-2013, 03:50 PM   #6
GSX750_SF
King Ding-A-Ling
CF Lover
Flip Offs: 20
Looking for JUST swingarm measurements? (not SSSA's?) Abraa Cadabra!!!!*poof*
GT500 '76 185mm
SV650 K5 240mm
VFR400 192mm
RVR400 202mm
NS400R 205mm
XS650 190mm
FZR250 200mm
MC21 NSR250 205mm
GSF600 bandit 220mm
CB400F 205mm
MC18 NSR250 197mm
'86 FZ600 215mm (without spacers/covers)
RZ350 205mm
05 GSXR 1000 225mm
Z900/Z1000 235mm (frame width at pivot)
Z650/Z750 230mm (frame width at pivot)
LC RD350 200mm
YPVS RD350 205mm
Gen 1-3 ZX10R 257mm
XL600R 200mm
MV Agusta F4 255mm
VTR SUPERHAWK (all years) 165mm
CBR 954 RR (2002-2003) 180mm
CBR 929 (2000-2001) 180mm
VFR 800 (1998-2001) 165mm
RC51 SP2 (2002-?) 180mm
RC30 235mm
RC45 250mm
Old Streetfighter Motorcycle Forum Post 06-16-2014, 06:41 PM   #7
ROBBO
MAJOR FOOKIN' CATASTROPHY
Flip Offs: 643
this info is soooo good ta have !
ROBBO' 2009
Thank you for viewing SSSA Dimensions on ALL SSSA's...(no pics just descriptions) in the Swingarm Swaps section of our streetfighter motorcycle forum. I hope you found it useful!
Swingarm Swaps - SSSA Dimensions on ALL SSSA's...(no pics just descriptions) on Custom Fighters Streetfighter Motorcycle Forum
