titans project skip build - Page 6 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > 2020 Winter Build-off > 2020 Winter Build-off Build Threads
2020 Winter Build-off Build Threads Only post here if you are the builder! Comments in the Discussion threads please.
CustomFighters.com Streetfighter Motorcycle Forum > titans project skip build
Old Streetfighter Motorcycle Forum Post 02-04-2020, 04:59 PM   #51
Local Time: 09:00 AM
Default Re: titans project skip build
As I blow all my build budget this month on a 3d printer I best get some stuff designed to print.
So first up is a rear light bracket. Now I have no idea what I'm doing or if I'm doing it right but all the measurements are right. What I do have is time through the week (work away) to play on fusion so making the most of it.
Printer is somewhere in the Netherlands so not long now
Sent from my SM-G973F using Tapatalk
These people High Fived titan!
Old Streetfighter Motorcycle Forum Post 02-08-2020, 11:01 AM   #52
Always one to jump in with both feet. Printer running great so swap out the filament for some nice blue, and printed off the light bracket. Fits perfect so I'll get the lights ordered at some point and make sure they fit then I'll do final print in better filament (once I work out what that is).
Old Streetfighter Motorcycle Forum Post 02-08-2020, 02:33 PM   #53
Front light all tacked up,and in place. Next job Speedo mount
Old Streetfighter Motorcycle Forum Post 02-10-2020, 03:47 PM   #54
XxGRYMMxX
Breaking shit...
XxGRYMMxX's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 8
Flipped Off 13 Times in 10 Posts
XxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on here
no support on the bottom?
They can ban, outlaw, and restrict whatever they please. I'll keep doing whatever the fuck I'm doing, because I don't really give a shit. The only thing that will change is that I'll be breaking their made up bullshit rules while doing it, and I'm comfortable with that.
My Build http://www.customfighters.com/forums...d.php?t=118649
XxGRYMMxX is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived XxGRYMMxX!
Old Streetfighter Motorcycle Forum Post 02-10-2020, 04:07 PM   #55
Local Time: 04:00 PM
Flipped Off 34 Times in 22 Posts
If the upper ones are sturdy enough it's not necessary. I used the same trick with the triumph's split mask headlight version.
Mattson is online now   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Mattson!
Old Streetfighter Motorcycle Forum Post 02-10-2020, 05:37 PM   #56
Nope the light weights less then the mount lol. I will be adding two horizontal bolts taped into the top triple once I sorted out the Speedo bracket. Should be fine
If not should be easy enough to add something to the bottom
Old Streetfighter Motorcycle Forum Post 02-13-2020, 07:55 PM   #57
need to relocate the speedo bracket, the orignal sides from the front, i need it to slide from the back so i can add a mounting point to the rear. so using my new skills to see if i can print one. this will be the test print, make sure all the dimentions work then i'll fine tune it and add the fixing point.
Name:	speedo bracket mk2.png
Old Streetfighter Motorcycle Forum Post 02-14-2020, 07:44 PM   #58
Double failure tonight but it's to be expected.
Print was shit as for some reason I messed up the settings... And where I moved the point the wire goes through the bracket to the other side I had not calculated the point the wire was on the actual Speedo. But I'm now running off version two, the rest of the measurements look good but want to check then I can work out the bracket part.
Old Streetfighter Motorcycle Forum Post 02-16-2020, 11:51 AM   #59
Weather is terrible, so I striped down the front end to work out what size spacers I'll need for the top yoke.
They should do it
Old Streetfighter Motorcycle Forum Post 02-23-2020, 08:14 AM   #60
Speedo mount V5 in print
Thank you for viewing titans project skip build in the 2020 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2020 Winter Build-off Build Threads - titans project skip build on Custom Fighters Streetfighter Motorcycle Forum
