Mickís Bandit 1200 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Mickís Bandit 1200
Old Streetfighter Motorcycle Forum Post 02-12-2020, 06:40 AM   #1
Mick
Noobie
Local Time: 05:18 AM
Mick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to all
Default Mickís Bandit 1200
Hey everyone, Iíve had this bandit 1200 for a few years now, another wife ago Iíd sold my R1 and picked up a dirt bike, I found myself without much time to ride so decided I needed to get my riding fix by commuting to work and back.
Anyway, I was on a tight budget and found a guy selling a bandit, I almost overlooked it as an old mans bike until the guy asked if I wanted a test ride, a little heavier than i was used to I pulled up at the traffic lights, green light and I eased out the clutch and rolled on the power I was greeted with a smooth power wheelie (ok, Iíll take it!!)
I commuted on it for years in all weather, eventually I moved close to work, took it off the road etc, it wasnít worth enough to sell so it sat in my shed.
Recently Iíve had the urge and time to ride again, started looking at different bikes and figured Iíve got the workshop space and gear to make it what I want, I donít have much to lose.
Anyway, sorry for the long winded story, Iíll put in some photos and a few words!
Mick is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Mick!
Old Streetfighter Motorcycle Forum Post 02-12-2020, 06:58 AM   #2
Mick
Noobie
Default Re: Mickís Bandit 1200
Old Streetfighter Motorcycle Forum Post 02-12-2020, 07:19 AM   #3
Mick
Noobie
Old Streetfighter Motorcycle Forum Post 02-12-2020, 07:21 AM   #4
Mick
Noobie
All stock in the above photo, about to start pulling it apart
Couple of bourbons here
Old Streetfighter Motorcycle Forum Post 02-12-2020, 07:35 AM   #5
Mick
Noobie
The first cut took a little courage, oh well, done now...
Monster 821 seat, I know itís been done before, but I do like the lines.
Unlike most who do this Iím using the monster subframe, tail light and undertray, itís all pretty tidy, obviously some challenges to make it all work.
New crossmember for top subframe mount.
Top mounts, crossmember all made and tacked, subframe is slightly offset at the top due to it mounting to the head of a v-twin originally.
Trying to get a good angle, itís on the centerstand here, no bottom mounts at this point.
Old Streetfighter Motorcycle Forum Post 02-12-2020, 07:48 AM   #6
Mick
Noobie
Angle sorted, bottom mounts made, notched into the frame and tacked
K&N filters due to no room for airbox, and a short pipe as the original mounted to the passenger peg, and was huge, there wonít be any such thing on this...
Chopped off the original rear tank mount and welded on a new one, I used the Suzuki rubbers to rubber mount it, the made a stainless bracket to pick up the front of the seat.
I had a 94 gsxr shock with remote reservoir, I donít want the remote anymore, would prefer a piggyback, after checking the shock charts I picked up a cbr600rr shock, and promptly found out that the reservoir is too far offset and will foul my new frame mounts...
Next I picked up a k6 gsxr 750 shock, it came with a linkage and swingarm, hmmmm..
Looks pretty cool, plenty of mods required to fit it.
Old Streetfighter Motorcycle Forum Post 02-12-2020, 07:59 AM   #7
Mick
Noobie
Iím thinking Iíll strip off the powder coat at this stage, probably run gsxr wheels, trim 12mm from the frame pivot mounts to fit the wider pivot, make a new bottom linkage mount and sleeve the bandit 20mm pivot to 22mm.
The frame is now bare so just taking measurements and calculating.
I donít yet have a gsxr wheel but am thinking that the shock mount centrelines on both the frame and the swingarm should be in line with both the front and rear wheel centred and the steering head, if so then I need to remove a fairly even amount from each side of the frame (or swingarm) and space the countershaft sprocket out by 4mm which may be doable with a small spacer and a slight grind of the inside of the nut (thereís about 3mm of thread showing)
Old Streetfighter Motorcycle Forum Post 02-12-2020, 01:11 PM   #8
Smoker
BLACK BELT
Local Time: 03:18 AM
Flip Offs: 35
Looks like you've been busy.
Some nice work going on.
This user High Fived Smoker!
Old Streetfighter Motorcycle Forum Post 02-12-2020, 01:14 PM   #9
yantosh
Local Time: 11:18 AM
Flip Offs: 14
nice subbie mounts
Old Streetfighter Motorcycle Forum Post 02-24-2020, 06:43 AM   #10
Mick
Noobie
Slow progress, my DOM tubing arrived to sleeve the bandit swingarm pivot from 20mm upto 22mm, neat fit, looks like it will work a treat.
Next to make swinger fit into the frame, was going to trim the frame but decided it would be easier to trim the swingarm, itís probably a bit big to smuggle into work and clamp onto the mill so I got ghetto with it, set it up to have the shock mounts centralised between frame and swingarm so 5mm off each side.
Neater fit than the original >1mm clearance, nice.
The top shock mount seems to be too low and far forward, Iím thinking that the reservoir needs to fit into the cutout on the swingarm at full compression.
Next up Iím considering rear ride height, tricky at this stage, planning on k7 gsxr forks which are 740mm vs 775 for the bandit, the rear can probably sit a little lower than stock, I can trick up the linkage later if need be.
I put the bandit swinger and shock back on and took a measurement from the back of the subframe to the axle at full droop, then swapped the gsxr swinger and shock back in and set it 20mm closer to the subframe (lower to get close to the shorter forks)
Looks as though I can use the bottom centerstand mount and just make a new top mount.
Should go in here if I chop the middle of the linkage out, the bearings are 25mm which fits well between the 2 outside gaps, trim the bearing tubes, weld tube in centre, long bolt done.
Swingarm at full droop, mounts next
I cut it twice and itís still too short
Thank you for viewing Mickís Bandit 1200 in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Mickís Bandit 1200 on Custom Fighters Streetfighter Motorcycle Forum
