Is Smoking Permitted? - Page 51 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Is Smoking Permitted?
Old Streetfighter Motorcycle Forum Post 05-08-2009, 01:39 PM   #501
cyclic
Stiff Member
Senior Fighterer
Local Time: 08:34 PM
Flip Offs: 5
cyclic is a glorious beacon of lightcyclic is a glorious beacon of lightcyclic is a glorious beacon of lightcyclic is a glorious beacon of lightcyclic is a glorious beacon of lightcyclic is a glorious beacon of lightcyclic is a glorious beacon of lightcyclic is a glorious beacon of lightcyclic is a glorious beacon of light
Default Re: Is Smoking Permitted?
With your frame bracing I don't see why you couldn't make the down tubes removable for engine removal. They would work nicely and allow complete access.
http://www.ballisticfabrication.com/...mp_p_1467.html
cyclic is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-09-2009, 08:28 AM   #502
Smoker
BLACK BELT
Local Time: 06:34 PM
Flip Offs: 35
Thanks for the idea. Moving the engine in and out of the frame after it's powder coated is not going to be fun.
Not sure it would be good for this frame, because the engine mounts on the lower cradle, instead of hanging off the upper rails like newer engines.
Old Streetfighter Motorcycle Forum Post 05-09-2009, 09:00 AM   #503
Smoker
BLACK BELT
Flip Offs: 35
When I started having problems fitting the link, I should have known right away where the problem lies.
One more time:
DON"T BUY A SWINGARM FROM JMC!!!
In this pic, you can see that the arms on the swinger aren't aligned with the dogbones.
The link and shock are centered to the frame, so I'll take a little material off the base of the new left dogbone and add some material to the base of the new right dogbone.
If the whole swingarm is off by around 2mm, then I may have to get another offset front sprocket made. After I get the rear suspension installed, I'll check the rear wheel alignment to the front wheel and frame.
Old Streetfighter Motorcycle Forum Post 05-09-2009, 01:07 PM   #504
Truckinduc
I been fightin' gravity
Truckinduc's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 6
Flipped Off 21 Times in 18 Posts
Truckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond repute
Winter Buildoff Winner Supporter of the Streetfighter Build for Charity
man FUCK JMC
Truckinduc is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-10-2009, 11:16 PM   #505
Smoker
BLACK BELT
Flip Offs: 35
Originally Posted by Truckinduc View Post
man FUCK JMC
My feelings exactly.
After doing a lot of sanding, I decided to take the tank down to the metal. Did some chemical stripping, but will probably take it to a media blaster.
Old Streetfighter Motorcycle Forum Post 05-11-2009, 01:46 AM   #506
929_adam
929_adam's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 09:34 PM
Flip Offs: 501
Flipped Off 166 Times in 132 Posts
929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!
wow. any chance of a return on that swinger?
Gavin Wayne Butts - Greencheezeeta - 10/5/83 - 9/8/09 RIP My Brother
Originally Posted by mpls|cafe|racer
"Knowledge is knowing that you know nothing." That's a motto to live by. There's always someone out there better, more knowledgable, faster, etc. and you can always learn and improve...
AFF.COM
929_adam is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-11-2009, 09:17 AM   #507
Phoebe
Swamp Witch
Phoebe's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 86
Flipped Off 17 Times in 15 Posts
Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!
I can't believe that swingarm is that bad. What a ripoff!
Phoebe is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-11-2009, 10:01 AM   #508
spoonfedd
Backwoods Prophet
spoonfedd's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 30
Flipped Off 16 Times in 15 Posts
spoonfedd is a glorious beacon of lightspoonfedd is a glorious beacon of lightspoonfedd is a glorious beacon of lightspoonfedd is a glorious beacon of lightspoonfedd is a glorious beacon of lightspoonfedd is a glorious beacon of lightspoonfedd is a glorious beacon of lightspoonfedd is a glorious beacon of lightspoonfedd is a glorious beacon of lightspoonfedd is a glorious beacon of lightspoonfedd is a glorious beacon of light
Coming soon .. "The Resurgence"
spoonfedd is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-11-2009, 03:10 PM   #509
Truckinduc
Flip Offs: 6
if you have 3 years to wait for another one that wont be any better.
Old Streetfighter Motorcycle Forum Post 05-11-2009, 04:39 PM   #510
Smoker
BLACK BELT
Flip Offs: 35
Exactly!!
Tags
ewoks stole my boxers
Thank you for viewing Is Smoking Permitted? in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Is Smoking Permitted? on Custom Fighters Streetfighter Motorcycle Forum
