Gsxr swingarm to bandit frame alignment - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Streetfighter Motorcycle Discussion > Streetfighter Help Needed!
Streetfighter Help Needed! Need help with your 'fighter? Ask for help in here!
CustomFighters.com Streetfighter Motorcycle Forum > Gsxr swingarm to bandit frame alignment
Old Streetfighter Motorcycle Forum Post 02-13-2020, 02:46 AM   #1
Mick
Local Time: 05:14 AM
Mick is a NOOB
Default Gsxr swingarm to bandit frame alignment
Ok, so hereís what Iím upto, got a bandit 1200 and am looking at putting a k6 gsxr 750 swingarm in.
Iíll be using the gsxr shock
Pivot is 22mm vs bandit 20mm, Iíve ordered some 22mm od 20mm id precision dom tube to sleeve the bandit pivot.
Tricky to ream the holes and use the gsxr pivot as the nuts are too large for the recess in the side of the frame.
Top shock mount Ďmayí be ok, it fits, hopefully front/back alignment works, bottom linkage will need to be made up - funnily enough the centerstand mount is the same width but would need some reinforcing if the position was even correct.
Swingarm pivot width, gsxr is 10.85mm wider than bandit, now initially, without thinking, i did all the measurements from the cs sprocket and chain guide, worked out that the chain side mount could stay and remove material from the brake side of the frame, the chain line would then be good.
This obviously wouldnít be great for shock and wheel alignment, next I took all measurements from the shock mount centrelines on both the frame and also both swingarms.
I came up with -4.75 on the chain side and -6.1 on the brake side (material required to be removed from swingarm frame pivot)
Now, this should allow the three shock and linkage mounts to all be in line, my question is, and I donít have a rear wheel to check, is the Center line of the shock mounts on the swingarm in line with the center of the rear wheel and are the frame shock mounts in line with the front wheel?
Basically Iím lining everything up left and right using the shock centres as datum points, chain alignment will have to be secondary - space front sprocket out 4.75mm, or rear in, or a combination.
Am I missing anything?
Thanks for any help, suggestions
I cut it twice and itís still too short
Mick is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-13-2020, 02:48 AM   #2
Mick
Mick is a NOOB
Default Re: Gsxr swingarm to bandit frame alignment
Old Streetfighter Motorcycle Forum Post 02-13-2020, 09:09 AM   #3
Iíve tried mocking up a swingarm without a wheel before. My advice, take it or leave it, is to buy the wheel setup made for that swingarm and base it off of the rimís centerline. Unless youíre using a different wheel setup than stock to the swingarm...then I would center the linkage and space the wheel as needed.
Ď74 Kawasaki H1-500 Project
Ď76 Kawasaki Kz900 'Strip-fighter Project
Ď77 Kawasaki Kz1000
Ď78 Kawasaki Kz1000 Project
'80 Cx500 Cafe/Brat Project
Ď83 Kawasaki Gpz750 (Turbo Converted) Project
Streetfighterkz is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Streetfighterkz!
Old Streetfighter Motorcycle Forum Post 02-13-2020, 09:38 AM   #4
Mick
Mick is a NOOB
Thanks Doug, Iím thinking thatís the way I may go, was originally going to make the bandit one fit, but then found a guy selling, wheels, forks and calipers...
Old Streetfighter Motorcycle Forum Post 02-13-2020, 06:38 PM   #5
Local Time: 10:14 AM
wheel can be shuffled side to side in the arm , if the arm is near enough the right place
Thank you for viewing Gsxr swingarm to bandit frame alignment in the Streetfighter Help Needed! section of our streetfighter motorcycle forum. I hope you found it useful!
Streetfighter Help Needed! - Gsxr swingarm to bandit frame alignment on Custom Fighters Streetfighter Motorcycle Forum
