Boneheads V-tec - Page 3 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > 2019 Winter Build-off > 2019 Winter Build-off Build Threads
2019 Winter Build-off Build Threads Only post here if you are the builder! Comments in the Discussion threads please.
CustomFighters.com Streetfighter Motorcycle Forum > Boneheads V-tec
Old Streetfighter Motorcycle Forum Post 01-10-2019, 06:55 AM   #21
bonehead
Fucking Retard
Fighter
Local Time: 05:22 AM
Flip Offs: 3
Flipped Off 5 Times in 3 Posts
bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!
Default Re: Boneheads V-tec
Double post.
Bought some different L.E.D strips, going to use the middle ones.
Cut some nice holes in my undertail, these are what was causing some frustration.
And cut up my clear Toyota indicator diffusers.
Hooked up a temp battery, and end up up with this
Like it when a plan comes together.
bonehead is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-17-2019, 07:14 AM   #22
bonehead
Fucking Retard
Fighter
Flip Offs: 3
Waiting for some vinyl wrap before putting the frame back on the motor ...
So I figure I may as well clean a bit more.
These people High Fived bonehead!
Old Streetfighter Motorcycle Forum Post 01-17-2019, 07:30 AM   #23
bonehead
Fucking Retard
Fighter
Flip Offs: 3
And since I had it apart, ..
etch primer
Made some block off, sorry Titan, graves plates
Valve cover paint selection via whatever I had lying around
That a bit better?
Re-greased all the swing arm bearings and put it back on, poked a stainless steel brake line through it, mounted a trail bike rear brake master, CBR 600 pegs.
Time to start putting it back together
Old Streetfighter Motorcycle Forum Post 01-21-2019, 04:43 AM   #24
bonehead
Fucking Retard
Fighter
Flip Offs: 3
I made some stainless brackets to rotate the COPS around so they don't protrude out as much and push the front mount radiator out as much and installed a SEBSPEED oil cooler.
I put some mat wrap on the undertail to hopefully not show as many imperfections.
Used some pinchweld around the edges.
Made a plate and repositioned the regulator rectifier
Old Streetfighter Motorcycle Forum Post 01-21-2019, 05:15 AM   #25
bonehead
Fucking Retard
Fighter
Flip Offs: 3
Got me an anything but an MT-03 headlight, not that there's anything wrong with them, maybe they're to popular?
And still want to use the original speedo, I want a temp gauge that's accurate and a flashing HISS red light .
Some template action
Oh no.....back to the drawing board
Made some filler pieces for the headlight to get an attachment onto the fork.
Old Streetfighter Motorcycle Forum Post 01-24-2019, 01:09 AM   #26
bonehead
Fucking Retard
Fighter
Flip Offs: 3
Spent more time staring at the headlight, which I must use and the OEM speedo which I really want to use, so polished my petrol cap thinking about options.
Before
After
Thinking about a stripe down the middle as well as the headlight now.
Old Streetfighter Motorcycle Forum Post 01-27-2019, 06:44 AM   #27
bonehead
Fucking Retard
Fighter
Flip Offs: 3
Australia Day in these parts, some call it invasion day, I call it a long weekend.
Painted my lower triple, realised that I hadn't replaced the lock stops I chopped off
Got my head light mounting brackets finished.
Fished out the speedo surround which I hadn't/haven't considered using, couldn't find it,
cut, heated and bent it to suit the new headlight profile.
That old valley iron came to the rescue again contributing to making two of these.
Which go here.
No.No.No
No mickey ...no,
your not so fine
Adamant that I will be using that headlight and that speedo
Old Streetfighter Motorcycle Forum Post 01-28-2019, 04:36 AM   #28
bonehead
Fucking Retard
Fighter
Flip Offs: 3
Made a chain guard
Run out of vinyl to wrap the top, would prefer less aluminium to polish
Old Streetfighter Motorcycle Forum Post 01-31-2019, 05:47 PM   #29
bonehead
Fucking Retard
Fighter
Flip Offs: 3
I have my answer.
Name:	C.F.29 - Copy (2) - Copy.jpg
Headlight + OEM speedo =
Old Streetfighter Motorcycle Forum Post 02-03-2019, 05:25 AM   #30
bonehead
Fucking Retard
Fighter
Flip Offs: 3
Excellent weekend, excellent weather.
From cardboard to sheet metal in a couple of hours.
Valley iron to the rescue again.
Tried to add some "flourish" , detail down the side.
Making the first side wasn't too hard, I had been watching some youtube sheet metal works whilst doing the sub frame undertail.
Making the second mirror image was mucho challenge, took a few goes
Good enough for me, just needs some filler, prep and paint.
Thank you for viewing Boneheads V-tec in the 2019 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2019 Winter Build-off Build Threads - Boneheads V-tec on Custom Fighters Streetfighter Motorcycle Forum
