Boneheads V-tec - Page 7 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > 2019 Winter Build-off > 2019 Winter Build-off Build Threads
2019 Winter Build-off Build Threads Only post here if you are the builder! Comments in the Discussion threads please.
CustomFighters.com Streetfighter Motorcycle Forum > Boneheads V-tec
Old Streetfighter Motorcycle Forum Post 05-14-2019, 07:14 PM   #61
bonehead
Fucking Retard
Fighter
Local Time: 02:39 PM
Flip Offs: 3
Flipped Off 5 Times in 3 Posts
bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!
Default Re: Boneheads V-tec
I'm calling finished, the rear brake was dragging from the exhaust bracket fitted behind the brake peddle, just needed slight bending and reaming.
Got somes stripes and some new bar end indicators, and some spares, and as much as I did like the mirror mounts that I made the round mirrors looked like lolly pops, so I found some that suit the bike better, and are not like Leroys .
I think they look ducati ish, and just like ducati mirrors, kind of useless but look good, wanted black but white showed up and don't look to bad.
It starts, it stops, it goes, will do the stalks indicators, and a new back tyre (after I wear this one out.
I can't say that I thought it would end up this way when I started, but......
and one with the lolly pops
bonehead is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived bonehead!
Old Streetfighter Motorcycle Forum Post 05-14-2019, 08:00 PM   #62
bonehead
Fucking Retard
Fighter
Flip Offs: 3
and here is my parts and price list
2006 VFR800 $450
CBR929 front end $600
CBR929 riser top triple clamp $110
Handle bars $27.90
Hand grips $11.00
Risers unused $22
SV 650 radiator $75
Amber led strips x many $20
Toyota lear indicator lenses $15
Licence plate led light x 4 $13
Rear tail light $9
Bar end indicators x 2, 3 $14
Grom headlight unused $100
Fz something headlight $37
Oil Cooler, (sebspeed) $100
Oil Lines and fittings $60
New air filter $35
New oil filter $22
motor oil $50
Brake fluid $20
CBR 929 rear shock $68
Seat vinyl $34
6061 aluminium bar stock $50
Paint stripper , felt like it $500
Used throttle cables $20
Brake, clutch lines $80
Rear brake master (it works) $15
CBR600 footpegs $14
100 x 50SHS steel $40
40mm aluminium flat bar $20
30 x 30 SHS shock adaptor $10
25 x 25 SHS $50
under tail sheet metal free
20mm stainless flat bar $6
gloss black carbon vinyl $24
mat white carbon vinyl $20
hipflask expansion tank $12
staintune exhaust of other bike -
New fuel pump gasket $14
90 degree radiator hose $9
Pinch weld $14
Front axle spacer metal $5
New front wheel bearings $38
Interceptor stickers $7.50
Black racing stripes $5
Nuts and bolts $70
Welding rods, probably more $50
Grinding wheels, $100*
12mm threaded rod and nuts $20
Paint, primer $200
valve caps $2
Electrical connectors $16
Front axle sliders, tested $28
Frame slidere, needed aswell $14
CBR 1000rr front fender $60
Licence plate red reflector $3.50
NX700 rear wheel hugger $31
Exhaust wrap 30m $22
CBR1100xx brake rotors $255
Antigravity battery $220
Rectangular mirrors white $21
2014 VFR800 radiator cap -
So thats about $3,400.00.
I got the oil cooler adaptors welded by a friend, thanks Sean, everything else by myself, at least twice, how many times with that undertail.....fuck, all with the encouragement from many members here.....thank you
Thought you might like some Australian bush
Thank you for viewing Boneheads V-tec in the 2019 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2019 Winter Build-off Build Threads - Boneheads V-tec on Custom Fighters Streetfighter Motorcycle Forum
