ROBBO ~ ugly big ole GL 1100 hondah ! - Page 2 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > 2019 Winter Build-off > 2019 Winter Build-off Build Threads
2019 Winter Build-off Build Threads Only post here if you are the builder! Comments in the Discussion threads please.
CustomFighters.com Streetfighter Motorcycle Forum > ROBBO ~ ugly big ole GL 1100 hondah !
Old Streetfighter Motorcycle Forum Post 12-13-2018, 10:46 AM   #11
ROBBO
MAJOR FOOKIN' CATASTROPHY
Local Time: 04:45 PM
Flip Offs: 643
Default Re: ROBBO ~ ugly big ole GL 1100 hondah !
Off with the old
On with the nu (to me)
The CBX clutch perch gives a much better cable run so it can wing past the headlamp(when fitted )
I done away with the choke cable setup so I can cut off the lever setup on the perch finish it up to be less bulky and paint to finish..
ROBBO' 2009
Old Streetfighter Motorcycle Forum Post 12-17-2018, 10:55 AM   #12
ROBBO
Flip Offs: 643
evry ounce counts !
ROBBO' 2009
Old Streetfighter Motorcycle Forum Post 12-23-2018, 10:02 AM   #13
ROBBO
Flip Offs: 643
Fixed a tag bracket up and all is good to go on the tail (ecxept paint)
ROBBO' 2009
These people High Fived ROBBO!
Old Streetfighter Motorcycle Forum Post 12-23-2018, 10:13 AM   #14
ROBBO
Flip Offs: 643
Went to do a charging test ,it was turning over slower and slower as of late. Was getting around only 7-8 volts across the terminals. Looked a wee bit closer at the wiring running up by the battery and noticed a bit of discolouration on the alternator to loom connector. When I tried to pull the sucker apart it was almost plastic welded together!
Found this! Lucky I didn't have a darn fire methinks .
Cut the wires back and my finger wide open ,joined solderd heat shrink tape and done !
Upon checking up on the problem it seems its a common happening with these.Lesson learnt.
ROBBO' 2009
Old Streetfighter Motorcycle Forum Post 12-23-2018, 08:32 PM   #15
ROBBO
Flip Offs: 643
I will of course be driling a substancial number of speed holes in this ata later date along with PICS! Mikey !
ROBBO' 2009
Old Streetfighter Motorcycle Forum Post 12-25-2018, 06:48 AM   #16
ROBBO
Flip Offs: 643
Swiss cheese - Mikeys and shinys faverite
ROBBO' 2009
Old Streetfighter Motorcycle Forum Post 12-27-2018, 08:13 PM   #17
ROBBO
Flip Offs: 643
Now to this project.
This is a CBX perch ,angles the clutch cable perfectly and I have removed the choke cable/mechanism .So I need to trim off the excess aluminium shite
ROBBO' 2009
Old Streetfighter Motorcycle Forum Post 12-27-2018, 08:21 PM   #18
ROBBO
Flip Offs: 643
From this
going to tap threds in the choke lever hole for the mirror and remove the mirror boss.
Of course the tap is a special size so extra buy
well pleased with that and saved a shiteload of extra weight !
ROBBO' 2009
Old Streetfighter Motorcycle Forum Post 12-28-2018, 07:20 AM   #19
ROBBO
Flip Offs: 643
Me boy ha like father like son.
ROBBO' 2009
Old Streetfighter Motorcycle Forum Post 12-28-2018, 01:39 PM   #20
ROBBO
Flip Offs: 643
I have to convert the OEM brake system. The rear brake operates one of the front calipers as well as the rear one ! Weird setup eh ?So it all has to come out and be replaced. Hoses arrived today so on they will go tonight .
It has this splitter under the swing arm corroded all to fook !
Regular hoses for the time being ,SS is not in my budget ATM .
ROBBO' 2009
Thank you for viewing ROBBO ~ ugly big ole GL 1100 hondah ! in the 2019 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2019 Winter Build-off Build Threads - ROBBO ~ ugly big ole GL 1100 hondah ! on Custom Fighters Streetfighter Motorcycle Forum
