Brake rotors with 6x80 bolt pattern, 9.75mm offset, whatever diameter? - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Street Fighter Swaps
Street Fighter Swaps From Fork Swaps to Swing Arm Swaps
CustomFighters.com Streetfighter Motorcycle Forum > Brake rotors with 6x80 bolt pattern, 9.75mm offset, whatever diameter?
Old Streetfighter Motorcycle Forum Post 02-09-2020, 12:10 AM   #1
Local Time: 02:01 AM
Flip Offs: 45
Fighter of the Year Fighter of the Month
Default Brake rotors with 6x80 bolt pattern, 9.75mm offset, whatever diameter?
As the title says. The hunt is on.
Hyper uses 5x90mm bolt pattern, 9.75mm offset, 305 diameter. BST wheel has the same mount surface spacing so need something with the same offset, but the hub has a 6x80mm pattern. Diameter would be nice to match but isn't a problem to go bigger and space the calipers.
Old Streetfighter Motorcycle Forum Post 02-09-2020, 03:03 AM   #2
Local Time: 01:01 AM
Flip Offs: 189
Default Re: Brake rotors with 6x80 bolt pattern, 9.75mm offset, whatever diameter?
You've got quite a few choices for 6 x 80 mm bolt pattern with an inner diameter of 64 mm. Two of them are 6.5 mm bolt diameters.
I can't find any that are the 305 mm with a 6 x 80 mm, but you can always turn the outside diameter down if you don't want to space your calipers out.
The numbers are in this order Outside Diameter, Inside Diameter, Bolt Hole Center, Bolt Holes, Bolt Hole Diameter, Thickness Normal, Thickness Minimum and Offset.
21.104 Floating L&R Univ. 320 64 80 6 8.5 5.0 4.5 10.0 counterbored
Ducati ABS models without tone ring
21.141 Floating L&R Univ. 320 64 80 6 8.5 5.0 4.5 10.0 counterbored with ABS
Ducati ABS models with tone ring
21.142 Floating L&R Univ. 320 64 80 6 6.5 4.0 3.6 9.8 straight
400 Monster (2000s)
600 Monster (2000s)
21.013 Floating L&R Univ. 298 64 80 6 8.5 4.0 3.5 9.5
FJ 1200 (floating)
21.015 Floating L&R Univ. 320 64 80 6 8.5 4.0 3.5 9.5
XJR 1200
FZR 1000
21.038 Floating Right 320 64 80 6 8.5 5.0 4.5 10.5 straight
YZF 750
21.076 Floating L&R Univ. 320 64 80 6 8.5 5.0 4.5 10.5 counterbored
990 Superduke
1190 RC8
These people High Fived Casper!
Old Streetfighter Motorcycle Forum Post 02-09-2020, 03:01 PM   #3
Flip Offs: 45
+Rep, thanks!
Thank you for viewing Brake rotors with 6x80 bolt pattern, 9.75mm offset, whatever diameter? in the Street Fighter Swaps section of our streetfighter motorcycle forum. I hope you found it useful!
Street Fighter Swaps - Brake rotors with 6x80 bolt pattern, 9.75mm offset, whatever diameter? on Custom Fighters Streetfighter Motorcycle Forum
