Post an Interesting Motorcycle Pic or Two - Page 586 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Streetfighter Motorcycle Discussion > Streetfighter pics
Streetfighter pics Post up pics of streetfighters in here!
CustomFighters.com Streetfighter Motorcycle Forum > Post an Interesting Motorcycle Pic or Two
Old Streetfighter Motorcycle Forum Post 06-30-2013, 09:42 PM   #5851
n0regret5
Commander Cool
n0regret5's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 04:35 PM
Flip Offs: 488
Flipped Off 214 Times in 150 Posts
n0regret5 is an amazingly helpful member with a good attitude!n0regret5 is an amazingly helpful member with a good attitude!n0regret5 is an amazingly helpful member with a good attitude!n0regret5 is an amazingly helpful member with a good attitude!n0regret5 is an amazingly helpful member with a good attitude!n0regret5 is an amazingly helpful member with a good attitude!n0regret5 is an amazingly helpful member with a good attitude!n0regret5 is an amazingly helpful member with a good attitude!n0regret5 is an amazingly helpful member with a good attitude!n0regret5 is an amazingly helpful member with a good attitude!n0regret5 is an amazingly helpful member with a good attitude!
Default Re: Post an Interesting Motorcycle Pic or Two
Originally Posted by Candyman View Post
Because Fuck Cornering
n0regret5 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 06-30-2013, 09:49 PM   #5852
Ahks
Feckin Eejit!
Ahks's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 11:35 PM
Location: Hiding in my own shadow near post apocalyptia.
Flip Offs: 28
Flipped Off 24 Times in 22 Posts
Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!
Could you imagine the straight line traction on dirt? Dirt rooster tail of doom.
Ahks is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 06-30-2013, 11:45 PM   #5853
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
sebwiers's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 12:35 AM
Flip Offs: 21
Flipped Off 36 Times in 19 Posts
sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!
Thanks for that, I was worried that subtlely questionable piece of engineering slipped by in the glaring light of a design that's gonna wear faster than a normal headset.
Agreed... Those joints aren't really intended to be used like that.
I assume you mean lateral loading on a rod end? That should be well below tolerance; there's maybe 300 lbs on the thing static, and another 1200 dynamic would mean there's 5 g's slamming into the rider's arms.... that's a hell of a bump. Its not hard to find rod ends the size that can handle 1500lbs lateral load.
Brake forces, however, are gonna feed into the rod ends as radial loads... exactly what they ARE intended to handle.
I was actually really tempted to try this for my Hossack fork design, but couldn't find rod ends with enough angular motion (at least not ones that were better suited than even the rather over-sized ball joints I got).
sebwiers is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived sebwiers!
Old Streetfighter Motorcycle Forum Post 07-01-2013, 12:30 AM   #5854
DecepticonDon
Elbow Grease is Cheap
DecepticonDon's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 301
Flipped Off 143 Times in 38 Posts
DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!
Still, fatigue and failure can happen to any metal component. Also cornering while braking would introduce more complex forces.
As I said before...single point of failure.
Looks easy to swap front ends and would weigh less. If the MotoGP engineers aren't interested in this on prototype machines that are rebuilt continually, then there must be a reason why.
Originally Posted by robsroadeater View Post
dont want no skanky slagbag hangin offa yer short arm mate
Project: Daytona 675
Operation: Kwak Attack
1991 Tidecraft B.O.A.T. build
DecepticonDon is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 07-01-2013, 01:01 AM   #5855
blensen
blensen's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 10:35 PM
Flip Offs: 12
Flipped Off 4 Times in 4 Posts
blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!
Obviously you can do whatever you want, but there's a reason why those joints aren't typically used in high lateral load scenarios.
Originally Posted by ultimate fighter
my throttle response was as fast as an old man with parkinsons trying to put his keys in the door
blensen is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived blensen!
Old Streetfighter Motorcycle Forum Post 07-01-2013, 01:45 AM   #5856
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
Flip Offs: 21
Probably weighs more if you want to get the same stiffness and strength, and unless the bearings are really good you might have slop that leads to speed wobbles.
Much more "interesting" than "good". It may (probably does, as you noted its not common) work like crap in the real world.
Old Streetfighter Motorcycle Forum Post 07-01-2013, 07:42 AM   #5857
GreY2231
GreY2231's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 06:35 AM
Flip Offs: 2
GreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to behold
Also the bearings assist in steering damping. They need to be torqued to a specific load and with these you cannot they are just free spin
GreY2231 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 07-01-2013, 08:09 AM   #5858
fslflint
fighter transplant in NC
fslflint's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 92
Flipped Off 225 Times in 69 Posts
fslflint is an amazingly helpful member with a good attitude!fslflint is an amazingly helpful member with a good attitude!fslflint is an amazingly helpful member with a good attitude!fslflint is an amazingly helpful member with a good attitude!fslflint is an amazingly helpful member with a good attitude!fslflint is an amazingly helpful member with a good attitude!fslflint is an amazingly helpful member with a good attitude!fslflint is an amazingly helpful member with a good attitude!fslflint is an amazingly helpful member with a good attitude!fslflint is an amazingly helpful member with a good attitude!fslflint is an amazingly helpful member with a good attitude!
I'd ride it. if I built it, I would have went a couple sizes up on the joints.
Gavin, I know you are in heaven. Please don't modify it too much!
RIP brother
Hard pressed on my right. My center is yielding. Impossible to maneuver. Situation excellent. I am attacking.
--Ferdinand Foch-- at the Battle of the Marne
fslflint is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived fslflint!
Old Streetfighter Motorcycle Forum Post 07-01-2013, 08:23 AM   #5859
Jokermachine
Will have a bike... soon
Jokermachine's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 08:35 AM
Flip Offs: 9
Flipped Off 223 Times in 86 Posts
Jokermachine is an amazingly helpful member with a good attitude!Jokermachine is an amazingly helpful member with a good attitude!Jokermachine is an amazingly helpful member with a good attitude!Jokermachine is an amazingly helpful member with a good attitude!Jokermachine is an amazingly helpful member with a good attitude!Jokermachine is an amazingly helpful member with a good attitude!Jokermachine is an amazingly helpful member with a good attitude!Jokermachine is an amazingly helpful member with a good attitude!Jokermachine is an amazingly helpful member with a good attitude!Jokermachine is an amazingly helpful member with a good attitude!Jokermachine is an amazingly helpful member with a good attitude!
That just looks scary. one point of failure and you're fucked like a blonde on prom night
I read the whole conversation after this post, but this is still the post I agree with the most. It may be engineered to work just fine but from a purely "gut instinct" point of view that shit looks sketchy as fuck.
Off-topic - damn I love this color scheme.
Originally Posted by Jokermachine View Post
Is that supercharger belt held together with 3 staples?
Originally Posted by Motohorho View Post
No it Isn't
There's actually 5 staples
Jokermachine is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Jokermachine!
Old Streetfighter Motorcycle Forum Post 07-01-2013, 10:24 PM   #5860
Fate
GURU of da poo poo
Flip Offs: 138
Flipped Off 106 Times in 61 Posts
Fate is an amazingly helpful member with a good attitude!Fate is an amazingly helpful member with a good attitude!Fate is an amazingly helpful member with a good attitude!Fate is an amazingly helpful member with a good attitude!Fate is an amazingly helpful member with a good attitude!Fate is an amazingly helpful member with a good attitude!Fate is an amazingly helpful member with a good attitude!Fate is an amazingly helpful member with a good attitude!Fate is an amazingly helpful member with a good attitude!Fate is an amazingly helpful member with a good attitude!Fate is an amazingly helpful member with a good attitude!
Fighter of the Month Supporter of the Streetfighter Build for Charity
Fate is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Fate!
Tags
bike porn
Thank you for viewing Post an Interesting Motorcycle Pic or Two in the Streetfighter pics section of our streetfighter motorcycle forum. I hope you found it useful!
Streetfighter pics - Post an Interesting Motorcycle Pic or Two on Custom Fighters Streetfighter Motorcycle Forum
