2012 Yamaha R1 rear shock dimensions - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Brakes and Suspension
Brakes and Suspension Anything to do with fabricating and modifying brakes and suspension goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > 2012 Yamaha R1 rear shock dimensions
Old Streetfighter Motorcycle Forum Post 05-23-2019, 06:00 PM   #1
Auser6guy
Local Time: 01:56 AM
Auser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of light
Default 2012 Yamaha R1 rear shock dimensions
Dont know if anyone needs it but the 2012 Yamaha r1 shock is high speed and low speed adjustable. Has adjustable rebound and hydraulic preload. It makes a pretty good retrofit if you need something adjustable without paying megabucks for a name brand.
Some stats
Its 300mm eye to eye. The eyes are 10mm.
It takes a 55mm id spring thatís 6.5 inches long when uncompressed.
Im swaping it in to my Ninja 650, ive bought an Eibach spring 600.225.1100 and its about 0.5 inches too short but needs collars to fit up as its larger id(58mm ish). Ive taken the bushings out and replaced them with an off the shelf spherical bearing on the bottom(reservoir end) 26mm OD, 12mm ID. The top end is a needle bearing 25mm OD 12mm ID 24mm wide.
Ive measured everything on the shock, but if somethings missing let me know...
ID:	105124   Click image for larger version
ID:	105126   Click image for larger version
ID:	105128   Click image for larger version
ID:	105130   Click image for larger version
Auser6guy is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Auser6guy!
Old Streetfighter Motorcycle Forum Post 05-23-2019, 06:03 PM   #2
Auser6guy
Default Re: 2012 Yamaha R1 rear shock dimensions
Few more
ID:	105136   Click image for larger version
ID:	105138   Click image for larger version
ID:	105140   Click image for larger version
ID:	105142   Click image for larger version
Old Streetfighter Motorcycle Forum Post 05-23-2019, 06:10 PM   #3
Auser6guy
Yet more again
ID:	105146   Click image for larger version
ID:	105148   Click image for larger version
ID:	105150   Click image for larger version
ID:	105152   Click image for larger version
Old Streetfighter Motorcycle Forum Post 05-23-2019, 06:19 PM   #4
Auser6guy
Its worth noting that the bottom bushing near the reservoir is a spherical bearing 26mm OD and 14mm ID. The original bearing has two top hat bushings pressed i from either side and these extend inside the OD of the bearing to narrow it down to 10mm. If you have 14mm bolts for your shock then you can likely just knock the top hats out and use as is. I did it the hard way removing the spherical bearing and replacing with a new one with the correct ID for me(12mm)
Many people on Versys forums just press in some PU bushings...
This user High Fived Auser6guy!
Old Streetfighter Motorcycle Forum Post 05-23-2019, 10:40 PM   #5
Local Time: 12:56 AM
Thanks for sharing this. Rep!
Old Streetfighter Motorcycle Forum Post 05-24-2019, 09:33 AM   #6
Local Time: 11:56 PM
Junkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to all
I'd be surprised if the damping rates on the R1 shock are reasonable for the Versys. The R1 spring is 10kg/mm while the Versys wants somewhere on the order of 17kg/mm. I'd want to revalve it too.
Bikes: naked SV1000 with all the possible bling, WR450SM street legal, 450XCF SM trackbike
Old Streetfighter Motorcycle Forum Post 05-24-2019, 04:47 PM   #7
Auser6guy
Youíre more than likely right. Do you think its an insurmountable problem?
I cant comment yet personally as I havenít ridden with it on the bike, however most people who do the swap (its a common mod) swear blind that although its way off its still much better than the standard effort from Kawasaki. They could all of course be absolutely mad
Once its on the bike ill comment, My intention is to ride it as is before sending it off to be revalved.
Old Streetfighter Motorcycle Forum Post 05-26-2019, 10:13 PM   #8
I suspect it can be revalved to work reasonably.
As is, there's a good chance having the clickers full stiff won't be enough.
Old Streetfighter Motorcycle Forum Post 06-01-2019, 07:55 AM   #9
Auser6guy
So resprung with an 1100lb spring. Still have 10 fingers
Old Streetfighter Motorcycle Forum Post 06-10-2019, 01:20 AM   #10
Local Time: 02:56 AM
it has to be revalved to work properly. seen countless threads with this.
Thank you for viewing 2012 Yamaha R1 rear shock dimensions in the Brakes and Suspension section of our streetfighter motorcycle forum. I hope you found it useful!
Brakes and Suspension - 2012 Yamaha R1 rear shock dimensions on Custom Fighters Streetfighter Motorcycle Forum
