Rex Saugerty RC31 junkyard track motorcycle temptation part II - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Rex Saugerty RC31 junkyard track motorcycle temptation part II
Old Streetfighter Motorcycle Forum Post 11-02-2017, 04:38 PM   #1
rex_saugerty
V four honda whore
Local Time: 07:20 PM
Flip Offs: 3
Default Rex Saugerty RC31 junkyard track motorcycle temptation part II
So here i am, alot further than before
story so far
and finished product would like to have around this
pics from yesterday, with my ladies phone with a date
anyway, today i went to garage to clean it up and get some room freed up for all bikes and comfortable winter working
then i looked up at fireblade frame i have lying around and noticed, that it has some parts i needed for bros. so i took them off for usage on frame mount
after that i fitted staightened triples back on, after picking them up yesterday. and thought that that is it for working around bike. then i looked at 900rr subframe that had been a bit chopped before i got it and canibalized it for parts to build subframe on bike. but that will be after iļl cut out tail out of styrofoam and make a decent working tail for bike
on the left cleaned from welding seams, on the right before
looks good on bike
still trying to sort out car selling to fund all the parts i need.
-clutch backet with plates
-CDI
-coils
-chain and sprockets
-tyres
-rearsets
-rear brakes
-clipons
also i need to sort out
-wheel spacers
-ignition wiring from lithium battery
-get tail done
-get fuel cell done
-sort out rear shock after
-paint that bitch
actually im quite optimistic about getting it done this year
rex_saugerty is online now   Reply With Quote on our streetfighter motorcycle forum
These people High Fived rex_saugerty!
Old Streetfighter Motorcycle Forum Post 11-03-2017, 02:04 PM   #2
rex_saugerty
V four honda whore
Flip Offs: 3
Default Re: Rex Saugerty RC31 junkyard track motorcycle temptation part II
So about rear shock.
Looked around and found that closest length of shock that is mounted without linkages are er6 at length of 285mm instead of 265mm I have now. So in true spirit of customization I drilled two holes im wood plank at length of 285mm, then fitted on bike
Keep in mind that there will be a sag with actual shock mounted. Also there are lowering kits for er6 available as spring retainers or springs itself
Edit: Also front isnt bolted on accordingly. Front of bike will be a bit higher
Old Streetfighter Motorcycle Forum Post 11-06-2017, 07:31 AM   #3
rex_saugerty
V four honda whore
Flip Offs: 3
so from photoshop mockup i made a vector file and printed it out on 5 a4 sized sheets and cut out a shape of tail templetate
it seems a bit too short on seat, so i extended it to the maximum for my styrofoam block, you can always cut off
we had some troubles with our hotwire setum. i reckon it is the wrong wire material, or maybe we need bigger car battery. so we had to cut it by hand, allowing wire to stretch. not the smoothest surface, but i'll sand it anyway to make more smooth round shape
now i need to draw top shape on block and cut it out. tank is a bit closer to back of seat than it would be. but to be honest it felt really nice to sit on it. arse pressed onback of seat and you can lean on tank comfortable
maybe will go there and draw lines today. maybe cut too... then i need to mock up tank brackets and test fit it all on bike. so tail and tank has neat lines that goes with rest of bike
Old Streetfighter Motorcycle Forum Post 11-06-2017, 03:16 PM   #4
rex_saugerty
V four honda whore
Flip Offs: 3
Default
Did some rough cutting. Not the prettiest, but will be alright. Now i need to buy some sandpaper and maybe one of those files for working on rigips(i know that name so ill go with it)
Yes it looks bulky, but ill smooth it out, and it will be allright. Better leave more than having not enough space
Old Streetfighter Motorcycle Forum Post 11-20-2017, 01:46 PM   #5
rex_saugerty
V four honda whore
Flip Offs: 3
so for the last week i' ve been busy and spent all free time to shape that piece of block into something i wouls call a tail.
when i thought i am done with it, i placed it on bike and realized i have failed, because it was too wide and to fat for that bike
so today i ended up narrowing it down and cutting underside a bit off. with fairing looks a lot better. that black tank doesnt help with looks, but i dont thing i' ve gone far too off in size from my original thought. shape is a bit different though. keep in mind tail will be about 4cm forward and 2cm lower
need to take sandpaper and sand it down, fill some unwanted holes and ready for first layer of fiberglass
Old Streetfighter Motorcycle Forum Post 11-26-2017, 03:23 PM   #6
rex_saugerty
V four honda whore
Flip Offs: 3
finally got to the garage today. with kid tho, so no powertools. she is scared of angle grinder. also didnt wanted to ruin her loungs with sanding and forming tail. so i took the front end off to get stem rethreaded a bit, so it fits bros head better. and sprocket carrier got studs removed. because i'll get it mashined a bit, because it is too high and i dont have space to align rear wheel. Little one helped to take studs out. she actually has quite the strenght to turn wrenches. tomorrow gonna give parts to my lathe guy to get machined
Old Streetfighter Motorcycle Forum Post 11-27-2017, 04:24 PM   #7
rex_saugerty
V four honda whore
Flip Offs: 3
Shortened the tail to the approximate seat lenght of rc45. And started to smoothen it out a bit. Also started to assemble the fort. Gonna have to buy some tape so I can drive the seals in and fill with oil
Old Streetfighter Motorcycle Forum Post 11-30-2017, 09:29 AM   #8
rex_saugerty
V four honda whore
Flip Offs: 3
Default
Changed the oil seals on forks, but dust seals are 1mm too big for forks itself. Is it normal!? I got a set for 900rr 45mm forks. Kinda confused here. Can i sand the diameter off? Inner lip fits great. Its just it wont fit the fork lower
Old Streetfighter Motorcycle Forum Post 12-01-2017, 08:51 AM   #9
rex_saugerty
V four honda whore
Flip Offs: 3
nevermind. lubed it it
Old Streetfighter Motorcycle Forum Post 12-12-2017, 12:49 PM   #10
rex_saugerty
V four honda whore
Flip Offs: 3
picked up something nice today
now need to find time to bend them into shape i need
also got my sprocket carrier shaved a bit, so i can actually fit the rear wheel within swingarm and find the center position
waiting for front steering stem to be remade so it fits bike. then gonna install 900rr forks.
also in middle of trying to score fiberglass and resin. got offered a nice price, but unsure about resin type
Thank you for viewing Rex Saugerty RC31 junkyard track motorcycle temptation part II in the Bike Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
Bike Build Threads - Rex Saugerty RC31 junkyard track motorcycle temptation part II on Custom Fighters Streetfighter Motorcycle Forum
