Smoker's Custom Motard - Page 102 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Smoker's Custom Motard
Old Streetfighter Motorcycle Forum Post 07-05-2016, 04:40 AM   #1011
Cookie2000ad
Persuasion Engineered
Cookie2000ad's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 02:49 PM
Flip Offs: 166
Flipped Off 59 Times in 27 Posts
Cookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CK
Default Medal Burnout Contest Winner Fighter of the Month
Default Re: Smoker's Custom Motard
My welding is extremely luck-dependent.
HA! Same! Every time I lift the mask I think: "I think I might have got away with that!"..... well not every time. Sometimes there's some swearing.
Cookie2000ad is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Cookie2000ad!
Old Streetfighter Motorcycle Forum Post 07-27-2016, 08:11 PM   #1012
Smoker
BLACK BELT
Local Time: 06:49 AM
Flip Offs: 36
Progress on the silencer brackets. Welded, drilled and tapped for M8 bolts.
The shape and angle will match the factory brackets.
Next is drilling and tapping for helicoils which will be inserted in the aluminum silencers.
Old Streetfighter Motorcycle Forum Post 07-28-2016, 01:14 PM   #1013
XxGRYMMxX
Breaking shit...
Local Time: 09:49 AM
Flip Offs: 8
Did you do those welds? Those looks good.
This user High Fived XxGRYMMxX!
Old Streetfighter Motorcycle Forum Post 07-29-2016, 07:52 AM   #1014
CK 187
CAPTAIN AWESOMEŽ
CK 187's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 631
Flipped Off 470 Times in 171 Posts
CK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too much
Default Medal Supporter of the Streetfighter Build for Charity Supporter of the Streetfighter Build for Charity
This made me laugh
CK 187 is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived CK 187!
Old Streetfighter Motorcycle Forum Post 07-29-2016, 02:44 PM   #1015
Smoker
BLACK BELT
Flip Offs: 36
The bottom line is, my welding capabilities don't meet my build standards. I would never let a welder with my (lack of) experience work on my bikes.
I could take the time and learn to make great welds like that, but it already takes me way too long to build a bike. For now, my buddy Roger is doing the finish welding.
Once I jig up the parts for tacking, if the whole thing can be transported, I take it to Roger, otherwise I tack weld the parts myself. But, you can see on the previous page what can happen to nicely machined parts when I use the torch. Most of the time, I do okay.
This time, I drilled a 6mm hole through both parts and bolted them together for welding. After welding, I overdrilled to 8mm and used an M8 tap.
Old Streetfighter Motorcycle Forum Post 08-14-2016, 08:01 AM   #1016
Smoker
BLACK BELT
Flip Offs: 36
Before welding the bracket for the silencers, I need to make sure I can fit the in- and out-tubing.
I could try to find a company that could make these tight bends, but I'd like to do it myself.
Found some stainless tubing available online and made templates to try on the bike for the in-tubing. Takes the tightest bend I could find. 16 gauge with 1 inch O.D. and 1 inch CLR. Buying 2 U-bends to slice in half, turn one leg around to create an S-bend and weld together with a stainless ring over the cut. Hope that makes sense. Anyway, I can determine the clearance on one side.
Old Streetfighter Motorcycle Forum Post 08-20-2016, 12:58 PM   #1017
Smoker
BLACK BELT
Flip Offs: 36
Connecting the silencers to the exhaust tips is a little more complicated.
Need to work more on a jig for holding the tips in place.
Need to chop out the rest of the tube on the exhaust tips, but the mounting bracket is welded there. Won't be easy to fit and reweld the brackets to the new tubes.
Need 1" OD stainless mandrel bent tubes shaped to go around the bolt on the mounting bracket.
Now considering custom tubing for the in and out tubes, to prevent extra welds and collars. Been reading about CNC Tube Bending.
Old Streetfighter Motorcycle Forum Post 08-20-2016, 02:04 PM   #1018
XxGRYMMxX
Breaking shit...
Flip Offs: 8
[/QUOTE]
NICE!!! that looks super clean and the twin tips are perfect.
These people High Fived XxGRYMMxX!
Old Streetfighter Motorcycle Forum Post 08-21-2016, 11:13 AM   #1019
caferacerdan
CF Lover
caferacerdan's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flipped Off 1 Time in 1 Post
caferacerdan is an amazingly helpful member with a good attitude!caferacerdan is an amazingly helpful member with a good attitude!caferacerdan is an amazingly helpful member with a good attitude!caferacerdan is an amazingly helpful member with a good attitude!caferacerdan is an amazingly helpful member with a good attitude!caferacerdan is an amazingly helpful member with a good attitude!caferacerdan is an amazingly helpful member with a good attitude!caferacerdan is an amazingly helpful member with a good attitude!caferacerdan is an amazingly helpful member with a good attitude!caferacerdan is an amazingly helpful member with a good attitude!caferacerdan is an amazingly helpful member with a good attitude!
agreed!
If brute force and ignorance doesn't work...then it must be broken
2017 BUILDOFF
Bike Build: http://www.customfighters.com/forums...d.php?t=126625
Discussion Thread: http://www.customfighters.com/forums...d.php?t=126633
caferacerdan is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived caferacerdan!
Old Streetfighter Motorcycle Forum Post 08-21-2016, 12:18 PM   #1020
shinyribs
Flip Offs: 58
That is a heck of a photo. Really looking forward to see all that mounted up. Looking sharp, man.
Thank you for viewing Smoker's Custom Motard in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Smoker's Custom Motard on Custom Fighters Streetfighter Motorcycle Forum
