How to HEADER WRAP with Q&A and PICTURES - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Making Power
Making Power Anything to do with fabricating and modifying engines, carbs, ignition, etc. goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > How to HEADER WRAP with Q&A and PICTURES
Old Streetfighter Motorcycle Forum Post 03-11-2011, 02:11 PM   #1
jvanguard
KILROY WAS HERE
jvanguard's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 03:52 PM
Flip Offs: 244
Flipped Off 194 Times in 40 Posts
jvanguard has much to be proud ofjvanguard has much to be proud ofjvanguard has much to be proud ofjvanguard has much to be proud ofjvanguard has much to be proud ofjvanguard has much to be proud ofjvanguard has much to be proud ofjvanguard has much to be proud ofjvanguard has much to be proud ofjvanguard has much to be proud ofjvanguard has much to be proud of
Default How to HEADER WRAP with Q&A and PICTURES
I wrapped my headers this weekend, and took some pictures to share. I couldn't find all my Header wrap answers on CF, so I found it elsewhere and will now whore my findings to my CF mates.
The pros and cons of wrapping
PRO:
Think of exhaust gases as a heavy liquid such as an oil additive. If the liquid were traveling down a tubular system in a cold state, it would move very slowly. If you were to heat the liquid, the density of the fluid changes. The liquid responds to the heat increasing Its velocity. Exhaust gases respond In the same manner. Higher temperatures in a system increases the flow of the system. If the liquid is allowed to cool in the system, It slows down the flow of the liquid. By this explanation, you can now understand the importance of maintaining higher temperatures in a exhaust system.
(http://www.hondaddy.com/forum/viewtopic.php?f=12&t=66)
CON:
Wrap can hold moisture, oil, and grime next to the pipe to cause "rotting."
Extra heat can cause the pipes to become brittle.....Cool air needs to be around the header, and insulating it with a wrap to hold exhaust heat in makes the header material temperatures near molten. When you wrap the header you trap the heat in the header, but also in the material that needs to breathe to dissipate heat for it's own survival.
(http://www.centuryperformance.com/ex...e-spg-138.html)
MY 2 cents:
If I had some fancy race headers I would probably go the Ceramic Coating route...(http://www.madscientistcoating.com/t...r-coating.html) but I don't so I'm not too worried as I have stock headers, and if they crack or crap out I'll get thos fancy race headers
MATERIALS:
1. Header Wrap
2. Hose Clamps (or stainless zip ties)
3. Hi Heat Coating for Wrap
TOOLS:
1. Wife's sewing tape measure
2. Knife
3. Bucket-o-water
4. Gloves
5. Screwdriver
6. Ipod and Beer
PROCEDURE
1. Gather all your materials and tools.
2. Get your wrap and soak it in that bucket of water, this stuff is itchy as a mofo. The water also helps you wrap it tighter, and will shrink it tighter when it dries.
3. Get the sewing tape and figure out what lengths you need. Figure 8 inches extra per bend too.
sidenote: I also painted the cross overs with header paint prior since I knew I wouldn't be able to wrap em
4. Pre cut your pieces, wrap em up like an "ace bandage"
5. Put a wrap and a half around the uppermost part of the Header, secure with clamp. Note: make sure the flange is all the way up or you'll get to the bend and realize your a dumbass. Like here.
dumbass.
6. Wrap it tight....think Bullrider, you know when he gets on the huge freaking bull and the only thing he can hold on to is that little rope he is wrapping his hand in. Yes, that tight.
7. Finish up, header wrap must be dry before applying coating.
8. Also note that when you take off your headers you need new gaskets at the exhaust ports. You've been warned. By the way this stuff stinks like burning waffles and will smoke like a salty one legged sailor for the first few.
jvanguard is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-11-2011, 04:40 PM   #2
ROBBO
MAJOR FOOKIN' CATASTROPHY
Local Time: 06:52 PM
Flip Offs: 643
Default Re: How to HEADER WRAP with Q&A and PICTURES
Good stuff mate. I like tools as described in No 6
ROBBO' 2009
Old Streetfighter Motorcycle Forum Post 03-11-2011, 04:41 PM   #3
ROBBO
Flip Offs: 643
Pics of finished job on bike?
ROBBO' 2009
Old Streetfighter Motorcycle Forum Post 03-11-2011, 04:46 PM   #4
jvanguard
KILROY WAS HERE
Flip Offs: 244
Waiting for gaskets. Bike should be up and running shortly after.
This user High Fived jvanguard!
Old Streetfighter Motorcycle Forum Post 03-11-2011, 10:18 PM   #5
Spazpunk
Cpt. Obvious
Spazpunk's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 07:52 PM
Flip Offs: 60
Flipped Off 30 Times in 10 Posts
Spazpunk has much to be proud ofSpazpunk has much to be proud ofSpazpunk has much to be proud ofSpazpunk has much to be proud ofSpazpunk has much to be proud ofSpazpunk has much to be proud ofSpazpunk has much to be proud ofSpazpunk has much to be proud ofSpazpunk has much to be proud ofSpazpunk has much to be proud ofSpazpunk has much to be proud of
Good job and +1 rep.....
96 bandit build.
Originally Posted by DecepticonDon View Post
yeah, something that can go 150 mph, but has to be held up with a stick while stationary......is bound to fall over
The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over.
Hunter S. Thompson
Spazpunk is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Spazpunk!
Old Streetfighter Motorcycle Forum Post 03-12-2011, 04:01 AM   #6
ROBBO
Flip Offs: 643
+ REP mate !
ROBBO' 2009
Old Streetfighter Motorcycle Forum Post 03-12-2011, 06:31 AM   #7
Fathead_03
Flashburnt
Fathead_03's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 04:52 PM
Flip Offs: 145
Flipped Off 35 Times in 30 Posts
Fathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud of
Good on you man! + Rep! This shit gets asked all the time!
Build Threads
2009 Winter Buildoff CBR Build Thread
After-Buildoff CBR Build Thread
CB750 Hardtail Bobber Build "Old's Cool"
Originally Posted by Denvgasm View Post
someone died ban everything
Originally Posted by vbwstripes View Post
I like carbon peaking through the paint. It's like side boob.
Fathead_03 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-21-2011, 11:54 PM   #8
QuiCkSiLv3R
jamal avatar #1
QuiCkSiLv3R's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 44
Flipped Off 78 Times in 44 Posts
QuiCkSiLv3R is an amazingly helpful member with a good attitude!QuiCkSiLv3R is an amazingly helpful member with a good attitude!QuiCkSiLv3R is an amazingly helpful member with a good attitude!QuiCkSiLv3R is an amazingly helpful member with a good attitude!QuiCkSiLv3R is an amazingly helpful member with a good attitude!QuiCkSiLv3R is an amazingly helpful member with a good attitude!QuiCkSiLv3R is an amazingly helpful member with a good attitude!QuiCkSiLv3R is an amazingly helpful member with a good attitude!QuiCkSiLv3R is an amazingly helpful member with a good attitude!QuiCkSiLv3R is an amazingly helpful member with a good attitude!QuiCkSiLv3R is an amazingly helpful member with a good attitude!
i dont know why, but this diy makes wrapping look like complex rocket science lmao, well for what it is.
just playin very detailed steps. its a useful thing to have for many. your contribution to society has been noted with "rep"
Driving a motorcycle during the winters in the US North East has taught me one thing, you can't buy respect.
QuiCkSiLv3R is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived QuiCkSiLv3R!
Old Streetfighter Motorcycle Forum Post 03-22-2011, 02:34 AM   #9
cruuz
Triple nutter
CF Lover
cruuz's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 3
Flipped Off 6 Times in 4 Posts
cruuz is a name known to allcruuz is a name known to allcruuz is a name known to allcruuz is a name known to allcruuz is a name known to allcruuz is a name known to allcruuz is a name known to allcruuz is a name known to allcruuz is a name known to allcruuz is a name known to allcruuz is a name known to all
for those interested in doing wrap, also consider 'titanium wrap' from DEI. i used it on my pipes and love the way it looks. plus the HUGE perk of this wrap is there's no wetting/soaking/spraying involved, just wrap it on and done. i'll put up a pic but i'm on the wrong computer now
cruuz is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived cruuz!
Old Streetfighter Motorcycle Forum Post 03-22-2011, 03:31 AM   #10
Spazpunk
Cpt. Obvious
Flip Offs: 60
The only problem with that is the money. But damn if I could afford it I would go with titanium wrap. I hear it doesn't even smoke for the first few miles and no gloves required to put it on.
96 bandit build.
Hunter S. Thompson
Thank you for viewing How to HEADER WRAP with Q&A and PICTURES in the Making Power section of our streetfighter motorcycle forum. I hope you found it useful!
Making Power - How to HEADER WRAP with Q&A and PICTURES on Custom Fighters Streetfighter Motorcycle Forum
