Chat with an ASE Master Technician - Page 7 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Off Topic > Open Discussion
Open Discussion Anything non-motorcycle related goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > Chat with an ASE Master Technician
Old Streetfighter Motorcycle Forum Post 09-13-2010, 09:50 PM   #61
mikey
Redneck Dumbass
mikey's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 10:43 PM
Flip Offs: 21
Flipped Off 36 Times in 32 Posts
mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!
Default Re: Chat with an ASE Master Technician
Originally Posted by Ruff View Post
With that motor I'd guess you're boring it whether you want to or not.
Edzakly
Project: Moneypit
Originally Posted by spoonfedd View Post
i would rather have "fear my ass" primer than "fuk my ass" purple
Originally Posted by super View Post
you two fags need to give up the charade and go camping already
Originally Posted by Peter Gaulke
When a shark appears in the area sea lions will leave the water immediately. Luckily there are no tigers on the shore waiting for him, or he wouldn't know what the fuck to do.
mikey is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-13-2010, 09:58 PM   #62
Ruff
Rable Rable Rable
Ruff's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 12:43 AM
Flip Offs: 97
Flipped Off 138 Times in 105 Posts
Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!Ruff is an amazingly helpful member with a good attitude!
Would an Evo block work?
Ruff is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-13-2010, 11:16 PM   #63
mikey
Redneck Dumbass
Flip Offs: 21
No idea. I'll have to do some looking into it.
Project: Moneypit
Old Streetfighter Motorcycle Forum Post 05-02-2011, 04:17 PM   #64
mikey
Redneck Dumbass
Flip Offs: 21
Questions:
I have my eye on a '67 C10 with a "crate engine" 350 small block. Guy says the trans is OK, but no OD. Also says a swapped intake increased vacuum and caused the trans to have to have the engine revved to engage in gear, and toggles back and forth between 2nd and 3rd. I can get a TH700 for cheapo ($200-$300), and a rebuild kit for under $150.
My questions are:
1 - I'd have thought an increased vacuum would have allowed to slip in gear EASIER, but the 2nd/3rd issue I'm unsure of. Does this sound more like too much vacuum, or a leak due to an incorrectly installed intake (which is what I'm thinking)?
2 - If I do decide to go with a TH700 for the overdrive, is there a cross ref I can use to see what fits based on block numbers from the engine??
Thanks in advance experts.
Project: Moneypit
Old Streetfighter Motorcycle Forum Post 07-20-2011, 01:51 AM   #65
Ruff
Rable Rable Rable
Flip Offs: 97
What's the general opinion of the GM L92?
Old Streetfighter Motorcycle Forum Post 07-20-2011, 01:56 AM   #66
dogbreath
Function IS Form
dogbreath's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 01:43 AM
Flip Offs: 27
Flipped Off 329 Times in 225 Posts
dogbreath is an amazingly helpful member with a good attitude!dogbreath is an amazingly helpful member with a good attitude!dogbreath is an amazingly helpful member with a good attitude!dogbreath is an amazingly helpful member with a good attitude!dogbreath is an amazingly helpful member with a good attitude!dogbreath is an amazingly helpful member with a good attitude!dogbreath is an amazingly helpful member with a good attitude!dogbreath is an amazingly helpful member with a good attitude!dogbreath is an amazingly helpful member with a good attitude!dogbreath is an amazingly helpful member with a good attitude!dogbreath is an amazingly helpful member with a good attitude!
2007 Streetfighter Buildoff - Head Turner Award
Edit: woops wrong engine
Dedication > Guts > Money > Luck > Talent
dogbreath is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 08-01-2011, 05:26 PM   #67
Drew S.
Fighter In Training
Drew S. is a good noobieDrew S. is a good noobie
okay i have a problem i need help with,
Vehicle: 2004 Infiniti G35 Coupe
Problem: vehicle will not go over 25mph without being restarted
Symptoms: VDC off light on, Slip light on, limp home mode engaged
checked: Brake Fluid level, brakes and all other fluids.
check engine light and tpms lights come on occasionally but always go away before i get to a reader
Drew S. is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 08-01-2011, 05:44 PM   #68
twr3cks
twr3cks's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 6
Flipped Off 32 Times in 7 Posts
twr3cks has a brilliant futuretwr3cks has a brilliant futuretwr3cks has a brilliant futuretwr3cks has a brilliant futuretwr3cks has a brilliant futuretwr3cks has a brilliant futuretwr3cks has a brilliant futuretwr3cks has a brilliant futuretwr3cks has a brilliant futuretwr3cks has a brilliant futuretwr3cks has a brilliant future
pretty awesome of you amigo to offer your help, etc.
twr3cks is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-15-2011, 11:38 AM   #69
stuntninja
Fucking Newb...Oh wait
stuntninja's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 07:43 AM
Flip Offs: 89
Flipped Off 93 Times in 69 Posts
stuntninja is an amazingly helpful member with a good attitude!stuntninja is an amazingly helpful member with a good attitude!stuntninja is an amazingly helpful member with a good attitude!stuntninja is an amazingly helpful member with a good attitude!stuntninja is an amazingly helpful member with a good attitude!stuntninja is an amazingly helpful member with a good attitude!stuntninja is an amazingly helpful member with a good attitude!stuntninja is an amazingly helpful member with a good attitude!stuntninja is an amazingly helpful member with a good attitude!stuntninja is an amazingly helpful member with a good attitude!stuntninja is an amazingly helpful member with a good attitude!
I'm back. New office hours, 6 hours ahead of EST... Lol
stuntninja is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived stuntninja!
Old Streetfighter Motorcycle Forum Post 05-23-2012, 02:43 PM   #70
gsf1200R
ShamanFighter
gsf1200R's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 485
Flipped Off 802 Times in 365 Posts
gsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympus
dead thread
Goal: Promote streetfighters to the custom motorcycle scene in America.
Plan: Spread the word to motorcycle enthusiasts through our forum & blog.
gsf1200R is offline   Reply With Quote on our streetfighter motorcycle forum
Thank you for viewing Chat with an ASE Master Technician in the Open Discussion section of our streetfighter motorcycle forum. I hope you found it useful!
Open Discussion - Chat with an ASE Master Technician on Custom Fighters Streetfighter Motorcycle Forum
