Direct mount reservoir - Page 2 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Brakes and Suspension
Brakes and Suspension Anything to do with fabricating and modifying brakes and suspension goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > Direct mount reservoir
Old Streetfighter Motorcycle Forum Post 08-28-2019, 02:29 AM   #11
Local Time: 02:23 AM
Default Re: Direct mount reservoir
Originally Posted by Auser6guy View Post
That’d be awesome thanks! Maybe upload as an attachment so others can see it in the future too? Is there anything special about venting? I take it you used an expansion diaphragm off another tank?
Ive found some chinesium brake and clutch perches with master cylinders and integrated reservoirs for 25% of the price of a single tank. These things are ridiculously over priced for what they are
https://rover.ebay.com/rover/0/0/0?m...2F202691714030
tried putting venting holes in the lids with foam or thin rubber underneath, made them no better or worse, ally pot with a solid lid
i'll dig out drawing
Old Streetfighter Motorcycle Forum Post 08-28-2019, 05:51 AM   #12
Auser6guy
Local Time: 08:23 PM
Auser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to all
Originally Posted by yantosh View Post
i can supply a drawing if wanted
Gentleman Yantosh!
Auser6guy is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 08-28-2019, 06:00 AM   #13
Auser6guy
Originally Posted by Junkie View Post
I'm of the opinion that those are *way* too high
I don't have a good picture of the one I have on hand, but here's something
it's a 40mm AEM tank on a Brembo RCS. of course, it was way too expensive.
The RCS has the port on the side and so it sits even lower?
Ideally I’d have that, Its exactly what i want. Ill settle for having a direct mount and no bracket and no leaks.
I found chinesium AEM reproductions if anyone wants to try em
https://rover.ebay.com/rover/0/0/0?m...2F192925884600
Old Streetfighter Motorcycle Forum Post 08-28-2019, 10:41 AM   #14
Local Time: 05:23 PM
Yes, it's on the side, but there's also no hose: the nipple that's supposed to go to a hose slips into a fitting on the bottom of the reservoir.
That one isn't what I have - there's no nipple on my reservoir.
https://www.ebay.com/itm/Motorcycle-...5ULsyi_XWeoO7A or https://www.ebay.com/itm/Black-Unive...UAAOSwawtbUn13 isn't quite what I have but it's closer
This user High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 08-28-2019, 04:11 PM   #15
Auser6guy
I think I get it. I dont think I’d chance that it wouldn’t leek on those eBay ones. The aem clutch master direct mount would be closest to perfect ive seen. Small, titanium(I saved o.5gms it feels faster ) and looks great
Once yantosh shares the drawing Im going to see if it’s low enough for what I want.
Old Streetfighter Motorcycle Forum Post 08-28-2019, 04:19 PM   #16
cut a slot in the top of the thread, lets you hold it in place with a screwdriver while tightening the pot
wouldn,t go smaller than that on the pot, too easy to over fill and seize brakes
Old Streetfighter Motorcycle Forum Post 08-28-2019, 04:29 PM   #17
Auser6guy
Thanks again Yantosh that looks like it’ll be small enough. I’ll get one made up and see if it suits
Old Streetfighter Motorcycle Forum Post 09-22-2019, 05:08 AM   #18
Auser6guy
I asked several engineering places in my area to spin one of these up fro me and they all quoted well in excess of what theyre worth. Along my travels i did some research on master cylinders and figured out i could use a z1000 master(19mm) with a rizoma integrated reservoir. Its more than i wanted to pay but less than the brembo and not bad value considering.. I think im spending too much dough on this thing...Thanks for all your help all.
ID:	105986   Click image for larger version
Thank you for viewing Direct mount reservoir in the Brakes and Suspension section of our streetfighter motorcycle forum. I hope you found it useful!
Brakes and Suspension - Direct mount reservoir on Custom Fighters Streetfighter Motorcycle Forum
