brake pads not retracting - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Brakes and Suspension
Brakes and Suspension Anything to do with fabricating and modifying brakes and suspension goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > brake pads not retracting
Old Streetfighter Motorcycle Forum Post 04-25-2019, 05:20 PM   #1
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
sebwiers's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 12:18 AM
Flip Offs: 21
Flipped Off 36 Times in 19 Posts
sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!
Default brake pads not retracting
So... on the Secapocalypse, one of the (blue dot r1/r6) calipers locks up.
Used to be BOTH of them, but that was me running the (old stock cable actuated) MC lever overly tight, preventing fluid from going back into the reservoir when heat built up. Adjusting that properly served me well for 4,000 miles or so... right up until my trip to Wasteland Weekend, where the left(?) caliper locked its ass up while I was riding around the desert.
So now just that ONE locks up. What's the likely cause and solution?
I was thinking I'll probably have to force the pistons out with the compressed air and zip tie trick, clean and grease it all, look for corrosion, foreign material in the lines / caliper passages, etc?
sebwiers is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-25-2019, 05:54 PM   #2
Junkie
re-tarded
Local Time: 09:18 PM
Flip Offs: 3
Default Re: brake pads not retracting
Start out by pulling the pistons, cleaning them of any corrosion, pulling the seals, cleaning them (and the bodies) of any gunk
there's probably gunk on the seals causing sticking
These people High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 04-25-2019, 06:03 PM   #3
shinyribs
Local Time: 01:18 AM
Flip Offs: 58
What Junkie said. Grit build up around the dust seal is famous for that. But sometimes age just does it's thing and the seals can start to swell on ya.
Old Streetfighter Motorcycle Forum Post 04-25-2019, 06:50 PM   #4
XxGRYMMxX
Breaking shit...
Flip Offs: 8
hows the brake hose look? if its old, it may be worth replacing. just had a Honda Element (car, i know) that locked up the left front caliper. caliper slide pins and the piston moved fine, even pressed the piston back by hand once the hose was removed. turned out the hose deteriorated internally and caused a clog. just something to check.
These people High Fived XxGRYMMxX!
Old Streetfighter Motorcycle Forum Post 04-25-2019, 07:31 PM   #5
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
Flip Offs: 21
The brake hoses are the stock hoses from 1981. So yeah, if its possible for shit to shake loose off them, riding in the desert would have done that. In fact, the issues started shortly after I ripped about 15 miles down and back on a dirt "road" at speeds that tested my suspension and construction pretty severely. Bike handled better than it had rights to, but I guess I found a failure point.
Might be an interesting excuse to do the trick with running full hard lines I wanted to try...
Old Streetfighter Motorcycle Forum Post 04-26-2019, 02:16 AM   #6
a_morti
Local Time: 07:18 AM
Flip Offs: 24
As above, caliper strip and clean is step 1.
Is there anywhere the hoses could have become kinked or pinched while riding off road? The suspension will have been moving further in its travel than usual, maybe the hoses stretched? Maybe time to consider hard lines, and/or stainless lines at least for flex points.
This user High Fived a_morti!
Old Streetfighter Motorcycle Forum Post 04-27-2019, 06:26 PM   #7
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
Flip Offs: 21
Default
Pulled the pots out and cleaned em. The outer last 1/8" or so of each was flithy and at least one could not be forced to retract. Pad wear was also visibly uneven.
After cleaning I tested the action with air pressure, seems more even and can be easily made to retract by hand.
I don't think the hoses are an issue. The rubber looks great for its age (is why I used them) and there's no way they could kink due to supension motion because the hoses don't move relative to the brake - I could run hard lines all the way from the MC (cable actuated and fork mounted) to the brakes if I had the fittings!
This user High Fived sebwiers!
Thank you for viewing brake pads not retracting in the Brakes and Suspension section of our streetfighter motorcycle forum. I hope you found it useful!
Brakes and Suspension - brake pads not retracting on Custom Fighters Streetfighter Motorcycle Forum
