370steve goes EFeeeeeeeeeeeee - Page 16 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > 370steve goes EFeeeeeeeeeeeee
Old Streetfighter Motorcycle Forum Post 04-26-2020, 05:10 PM   #151
370steve
old fart
Local Time: 08:38 AM
Flip Offs: 30
Default Re: 370steve goes EFeeeeeeeeeeeee
sorted fitment of engine mounts and bolts today after getting spacers and frame inserts from Taff
Then played around with the rear m/cylinder/hose attachment, ended up with the hose going down the back.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 04-27-2020, 07:29 AM   #152
370steve
old fart
Flip Offs: 30
More Ti goodness arrived in the post this morning where i dont have facilities,machines or ability to make bits myself, i will make all efforts to gather the best bits i can afford from wherever i can, might as well whilst i have the chance, this one is a keeper.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 04-28-2020, 09:11 AM   #153
370steve
old fart
Flip Offs: 30
work so far today has all been about test fitting the oil cooler and head cooler to gauge lock stop/cooler/wheel/exhaust clearances, Head cooler has been mounted directly to the main cooler mounting bracket (going to have Ducati rubber mounts)
cooler has lots of clearance from exhaust headers (using Yoshi Bandit headers) but dont see any problems as i am going to get Racefit to make me a system.
I like the idea of the two center header pipes staying inside the down tubes and then the outside two passing behind the frame down tubes and into the collector. will have to talk to Jon on the idea.
clearance of head cooler and yokes at full lock, (lock determined by fork to tank clearance)
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 04-28-2020, 12:48 PM   #154
370steve
old fart
Flip Offs: 30
plus i am in the process of measuring up for a fan on the rear of the main cooler
for use in slow traffic in hot weather, there seems to be loads of room, watch this space
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 04-29-2020, 08:14 AM   #155
370steve
old fart
Flip Offs: 30
found an as new radiator fan from a CBR/CB, fan fits in the space between the down tubes very nicely, blades are a little deep, but i am sure that
i will be able to cut them down without too much effort, but looks to be a working answer to the problem.
got oil cooler mounts to be modified to take some Ducati radiator rubber mounts this afternoon.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-01-2020, 06:06 AM   #156
370steve
old fart
Flip Offs: 30
Thanks to the feed back (good, bad or other wise) i have gleaned the information that i needed for fitment of the oil cooler fan, it would appear that every day is indeed a "Skool Day"
I have ordered a Spal Axial Fan, VA39-A101-45A, 12v (Pull) 5.5" (140mm) with the bigger of the two Ampage motors,
will be fitting it with a remote switch, unless i can find a temp switch to work at a high temp of the oil cooled motor (110-120deg +)
I will need to remove a bracket from under the steering head bracing to give me the required clearance for the fan, and then get some mounting tabs welded on for it to fit to.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-01-2020, 08:09 AM   #157
370steve
old fart
Flip Offs: 30
just ordered one of these adjustable in line switches and AN10 adapter to go with it *
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-02-2020, 01:06 PM   #158
370steve
old fart
Flip Offs: 30
had a play around with the oil cooler fixtures and fittings, happy now with how i will sort the pipework for both coolers
test fit of fender and brake lines.
ordered some more Ti bits and bobs whilst i was at it
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-03-2020, 04:10 PM   #159
370steve
old fart
Flip Offs: 30
As i am happy with the motor fitment and alloy mounting plates i had made, i have ordered some 8mm Ti GR5 plate to make some
finished items, need to find someone with a plasma cutter so they will have a "proper" finish/look once cut.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-06-2020, 04:41 AM   #160
370steve
old fart
Flip Offs: 30
been told water jet cutting will give me the best finish, so off to see if i can find one close.
SHIT HAPPENS!!!!!
Thank you for viewing 370steve goes EFeeeeeeeeeeeee in the 2020 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2020 Winter Build-off Build Threads - 370steve goes EFeeeeeeeeeeeee on Custom Fighters Streetfighter Motorcycle Forum
